BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding M5 display
      02-24-2018, 12:32 PM   #1
TCBKindh
Sweden
12
Drives: G30 530D
M5 display
hi
im a newbie in coding, only been using Bimmercodeapp a couple of times.
Is it possible to code the display so it will look like the new m5 ?
      02-25-2018, 04:48 AM   #2
Flyingscotsman
Scotland
186
Drives: G30 520d se
I assume it would be possible. Have a look under dkombi2 in 'Expert Mode' and see if there's anything that looks like it could enable the M5 display.
For example the alpina display is ALPINA_ENABLE and needs set to active.
I will have a look when I get the chance, but will probably be a couple of days as I'm busy with other things.
I didn't even consider looking into changing to the M5 display as I have a diesel and assumed the rev counter scale would be too high.
Osheatwo205.00
      02-26-2018, 04:38 AM   #3
valrossi
Drives: F10 523
Would like to know which parameter in DKOMBI to enable M5 display. Has been successfully enabled the ALPINA display and would like to explore more...
      02-10-2020, 12:23 AM   #4
G30Bimmer
Drives: Bmw G30 530i
U need DKOMBI4 I think ?
      02-10-2020, 05:31 AM   #5
AP
AP's Avatar
2774
Drives: G30 M550
Others can chip but thought the m5 have different hardware so not possible to code a g30 with the cluster for a m5.
      02-10-2020, 05:37 AM   #6
ejlover06
ejlover06's Avatar
Turkey
105
Drives: 2017 G30 520 1.6lt
I also wonder this. Also enabling any additional addons to HUD (turnlights, rev gauge, shift lights, etc.)
2017 G30 520 (1.6lt)
2016 S1000RR
2014 W205
      02-10-2020, 09:33 AM   #7
G30Bimmer
same 6WB cluster also cannot ? Malaysia spec using 6WB Instead of 6WA instrument cluster
      02-10-2020, 11:08 AM   #8
VirtualGuitars
VirtualGuitars's Avatar
Drives: 2024 BMW XM Label
I have the the full digital cluster and that option is not presented like the Alpina display (which is the one I use now) or the others.
      02-10-2020, 11:11 AM   #9
G30Bimmer
I can code it to alpina display but no m5 selection
      02-10-2020, 11:16 AM   #10
VirtualGuitars
That's because the option doesn't exist. Everything is different on the M5 including the shifter and the electronics, so I'm not surprised that this module on the M550i's don't have the display and coding for it.
      02-10-2020, 11:23 AM   #11
G30Bimmer
My friend's 530e can make it
      02-11-2020, 12:07 PM   #12
mrgicm
mrgicm's Avatar
441
Drives: BMW M
You need a new Live Cockpit Cluster with Idrive 7. (MY2020) than you can code the M5 cluster.
      04-15-2020, 02:29 AM   #13
radenkozoric
radenkozoric's Avatar
Switzerland
Drives: BMW G31 540i, BMW M4 F82
Is it possible to code the ///M start up animation with DKOMBI2
like shown at 0:24 in the following youtube video:
Thanks in advance!
      05-12-2020, 10:29 AM   #14
deeJayOg
deeJayOg's Avatar
14
Drives: BMW G20 330e
So far I have not seen that coding option available on standard dials. Might be the same, reserved only for M5 hardware, which is different from regular 6WB.
      05-12-2020, 11:57 AM   #15
SteveinArizona
Drives: BMW 530e
Inquiring minds (at least mine) want to know. How?
      05-17-2022, 03:40 PM   #16
gunnermanms
Drives: BMW G30 5'
I'd love to know too!
      05-17-2022, 04:02 PM   #17
HerkHealer
HerkHealer's Avatar
1716
Drives: G30/M550
You can code the "M" startup onto I drive 7, and add the M Sport gauges, but there's nothing I've seen to code Live Cockpit to a "M" startup, or change the gauges to M5 ones.
2020 M550 / Dark Graphite / Napa Saddle Brown / DHP Pkg / Exec Pkg / Luxury Pkg / Parking Asst Pkg
      06-15-2022, 12:30 AM   #18
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
https://g07.bimmerpost.com/forums/sh...6#post25079666
      07-13-2022, 04:31 PM   #19
FullBolton
FullBolton's Avatar
78
Drives: BMW G30
  [0.00]
2017 BMW 540I  [0.00]
This should do the trick!
      07-13-2022, 09:30 PM   #20
cna90
cna90's Avatar
Drives: BMW 540ix with MPPSK
I recently got my firmware updated at the dealer. I don't have HMI_brand anymore!
Use to code M5 on my idrive and now I can't!
      07-13-2022, 09:34 PM   #21
FullBolton
FullBolton's Avatar
78
Drives: BMW G30
  [0.00]
Oh man! Yeah unfortunately a few months back I fried my bdc. Had to get a new one and recode with new updates. Alot has disappeared unfortunately. I haven't updated my headunit for this exact reason.
      12-04-2023, 05:07 PM   #22
gsmarrara
Drives: 2018 BMW 530i G30
Hello. I'm new to this forum and to coding. Manage to activate and reverse the alpina cluster.
Thanks for the "trick". Can you please provide more details on how to navigate within the BimmerCode to do it?
Thanks and best,
GSM
