01-01-2018, 03:20 AM | #1 |
Rep 1,247
Has anyone tried this on their N57, adjusting the EGR fresh air ratio?
I'm intrigued as to whether this will work on the 30/35d as it did on my E90.
http://www.e90post.com/forums/showthread.php?t=1296190 |
02-28-2018, 10:55 AM | #3 |
Rep 1,247
There's a rough guide at the bottom of the link below.
What model do you have? http://www.bimmerfest.com/forums/sho.../topics/835572 |
02-28-2018, 01:49 PM | #4 | |
Rep 570
I have 2014 335d, did this on my previous vag cars and always felt a decent improvement Will report back once I have had a play Sully |
02-28-2018, 03:48 PM | #5 | ||
Rep 1,247
03-06-2018, 03:52 PM | #7 |
Rep 570
I have just tried with ista 4.09 and still I do t see egr adjustment under service functions.
Does anyone have any ideas as just spent 2 evenings download and setting up a newer version of ista only to find the same issue |
12-08-2018, 12:23 PM | #9 |
Rep 8,498
I had the EGR coded fully closed as part of the remap. The engine (30d) is more responsive, revs smoother, has less diesel rattle, and fuel economy improved by around 4mpg.
I appreciate the case for EGR but the effects on driveability and fuel economy outweigh that IMO.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
12-08-2018, 01:02 PM | #10 |
Rep 1,803
If you had a remap, you can't simply associate EGR closure with all those effects. Remaps change a lot of things, depending on the skill of the tuner.
Leaving everything else stock, EGR operational will get better fuel efficiency, as long as intake is clear. EGR off alone with no other changes will get worse fuel mileage.
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. |
12-08-2018, 05:51 PM | #11 | |
Rep 1,247
12-09-2018, 11:06 AM | #12 |
Rep 1,803
That's really interesting, because when turned off from tune (on 328d) the results are different. There is more turbo compensation, which results in the turbo "blocking" free exhaust flow. Of course there are many different ways to turn it off in the tune as well.
If I remember correctly, the newer ISTAs removed that feature, since all the emissions scandals. Tool32 should still be able to do it still.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. Last edited by Enabled; 12-09-2018 at 11:12 AM.. |
