M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > F10 M5 DIY Guides
      11-30-2017, 02:01 AM   #1
SalM
S1N1ST3R
SalM's Avatar
Montenegro
143
Drives: E92 M3
Need DIY for: Turbo Removal & Transmission
Hey guys anyone have a diy on a turbo swap for the S63tu and any DIY's to remove DCT Trans. My buddy is parting out needs help putting his stock turbos back in so he can sell his turbos, and I want to take his DCT with SSP clutches, can we just direct swap transmissions? He has an M6 coupe I have an F10 M5 Do we need to do any coding or such for the transmission swap? Clutch relearn for both cars anything like that ?
2012 E92 M3
World's Fastest N/A E9X M3 & Stock Motor Supercharged E9X M3
11.49 @ 121.54
10.38 @ 136.04
      11-30-2017, 02:17 PM   #2
SalM
S1N1ST3R
SalM's Avatar
Montenegro
143
Drives: E92 M3
Bump!!
2012 E92 M3
11.49 @ 121.54
10.38 @ 136.04
      11-30-2017, 04:45 PM   #3
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
The best teacher in life is experience...start unbolting, bag things and get to it.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      11-30-2017, 09:43 PM   #4
SalM
S1N1ST3R
SalM's Avatar
Montenegro
143
Drives: E92 M3
Thats kinda what I wanted to avoid hahah
2012 E92 M3
11.49 @ 121.54
10.38 @ 136.04
      12-01-2017, 12:23 AM   #5
SSPKris
SSPKris's Avatar
Drives: Nissan GTR
You cannot just swap transmissions. The transmission is VIN coded to the TCU in each of the transmissions. You will need the ISTA D scan tool with the latest software updates to get this to work.
It would be easiest just to swap clutch assemblies from one trans to the other. You will still need to use the ISTA D scan tool to do the adaptation. This is much easier and less time consuming.
We sell the clutch removal tool if you need one.
Kris
      12-01-2017, 09:09 PM   #6
m5james
m5james's Avatar
I was replying more along the lines of the turbo swap. Being that the blocks are the same, I can't see why the transmission wouldn't be an easy swap as well...it's the software/coding that are going to be the bitch. Keep all the parts you can, drivelines, mounting brackets, etc etc and keep your fingers crossed
      12-03-2017, 09:51 PM   #7
SalM
S1N1ST3R
SalM's Avatar
Montenegro
143
Drives: E92 M3
Kris
Thanks for he advice man, spoke to a few people who said the same thing. They said just swap out the clutch housings and keep your trans. it is easier and then just do the adaption.
2012 E92 M3
11.49 @ 121.54
10.38 @ 136.04
      12-04-2017, 05:44 PM   #8
allmotor_2000
F10 1/4 WR: 9.9s / 142.5mph 1/2 WR: 175.5mph
1083
Drives: 2018 RS3, 991 Turbo
ISTA D or P won't work to swap DCT's (I tried it). You have to get a new TCU (part of the mechatronics unit) from BMW with the VIN coded so that the EWS recognizes it. Alternately you can swap the mechatronics unit.
As someone stated, easier to swap the clutch assembly than the DCT.... either way everything has to be removed.
Regarding turbo swap.... I don't have pictures, but here is the way:
1. Do the DP removal steps (there is a DIY for that)
2. Remove the turbo intake, inlets and charge pipes
3. Remove the upper water IN/OUT hoses
4. Remove the wastegate vacuum references
5. Remove top oil feed lines
6. Remove the heat-shield above behind alternator to gain easier access to the oil drain lines
7. Sometimes removing the alternator makes it easier, but not necessary
8. Remove the vband at turbine inlet and remove the turbos
9. Make sure to replace all the gaskets and oil feed/drain washers (don't want leaks with those)
10. Put everything back in reverse order
Mcc420473.50
m5post
