BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis Tire Question / 759 Wheels
      11-07-2017, 08:42 PM   #1
chasedeez1
Drives: 2017 BMW 540i
Hi,
Im curious if anyone has put different size tires on their 540i with 759 M Wheels? Im wanting to do 245 40 R 20 on the front and 275 35 R20 on the rear. Not sure it will fit? Need Feedback please
      11-12-2017, 09:29 AM   #2
Gmoney El Nene
Gmoney El Nene's Avatar
52
Drives: 2018 540i M
Originally Posted by chasedeez1 View Post
Hi,
That is the standard fitment for 20s. You should be fine.
2018 540xi MSport, Med Blue/Mocha
Exec Pack, Cove Mat, HK, Carplay, Lux Seats
19"664M, Wifi, Driving Assistant
      11-12-2017, 01:56 PM   #3
Delija
VIP
Delija's Avatar
41
Drives: G20 M340i xDrive
Nope. Standard is:
Front: 245/35 R20
Rear: 275/30 R20
Life is not measured by the number of breaths you take but by the moments that take your breath away...
      11-12-2017, 05:56 PM   #4
Gmoney El Nene
52
Drives: 2018 540i M
Originally Posted by Delija View Post
Nope. Standard is:
Front: 245/35 R20
Rear: 275/30 R20
You are correct. I state the standard for 19s.
      11-12-2017, 11:41 PM   #5
bimmer_335
Drives: 540 mSport
Hi,
why would you want to do this? it will raise your car albeit slightly.
      11-13-2017, 05:41 AM   #6
chasedeez1
Hi,
I'm waiting to use the bigger sizes to fill in the gap between tire and fender. I didn't want to lower it. I've seen the 20's at the dealership and they look rubber bands.
      11-13-2017, 10:54 AM   #7
mobilejo
mobilejo's Avatar
Drives: G06 X6 40i
If there is a functional reason for it, then i could understand the desire, but if its purely for aesthetics, don't do it. The gap doesn't look any better because the eye notices the spaces from wheel to fender more than tyre to fender. Then to top it off, the wheels 'look' smaller because of the larger tyre around them.
Decreasing the gap is to usually to give the car a more sporting look, fitting a bigger sidewall tyre does the opposite aesthetically, and it raises the entire car up higher, throws the speedo out and increases the rolling radius making the car slightly slower.
      11-13-2017, 03:19 PM   #8
Gmoney El Nene
52
Drives: 2018 540i M
Agreed. I did that on a car long ago to improve the ride. It did make the car look a little strange.
      11-13-2017, 08:22 PM   #9
chasedeez1
I appreciate that feed back guys. It actually does make sense. I think I will go OEM
      11-14-2017, 01:30 PM   #10
bimmer_335
Drives: 540 mSport
you need spacers instead...
if you add 15mm in the back and 10mm up front they take the wheel out a bit and aesthetically it will enhance the look of the car, including the gap.
      11-14-2017, 04:49 PM   #11
mobilejo
mobilejo's Avatar
Drives: G06 X6 40i
I have 15mm rear on at the moment.
I fitted 20mm rear and the 15mm up front at first but didn't like the change in steering and the rear wheels were a touch too far out for me. 15mm on the rear brings the wheel out enough to decrease that massive gap without looking aftermarket. The fronts could support 10mm and also not look OTT, but I have never liked spacers on the front due to what it does to the steering, and this car was no exception.
It does enhance the overall look to bring the wheels out a bit, but I wouldn't say it makes the gap look any less. on 20/15, it actually made the gap more noticeable IMHO, although maybe thats just because I was looking perhaps.
I'm not lowering while the car is so new and the M Sport gap isn't overly 'offensive' on OEM wheels IMO. Usually changing wheels is what makes me think "it needs lowering".
      11-14-2017, 06:56 PM   #12
chasedeez1
Thanks Guys! Im hoping to make a decision soon with all your feedback. Spacers sound almost like increasing the tire size since this changes steering or suspension no mater what I do
      11-24-2017, 05:24 AM   #13
NTTY
NTTY's Avatar
Switzerland
37
Drives: G30 M550xi
Hi,
You can't do that, the tire would be off recommended diameter.
You can go for the one size up in width (255/35 and 285/30). It also better fills the wheel arches since there's a direct relation between width and sidewall height of your tires.
Best is to remain in the 3% diameter variance:
Cheers
2018 M550i Sepia-Violet
      12-26-2017, 11:18 AM   #14
MLP17
Drives: 2023 BMW 760xi
Cheers
So you are saying that 255/35 and 285/30 would be ok? How about 255/35 and 285/35?
I cant stand the way the stock tires look, they look like rubber bands to me as well. I need a little more rubber on there and i'm not sure what the best choice of tire sizing would be. Any additional info you have would be greatly appreciated.
Thanks!
      12-26-2017, 12:57 PM   #15
Delija
VIP
Delija's Avatar
41
If you want "more tire" - buy 19" wheels.
      12-30-2017, 05:04 PM   #16
chasedeez1
The 245 40 20 and 275 35 20 FITS PERFECTLY!
      01-10-2018, 07:36 PM   #17
is_niice
Drives: Everything
My car with 40/35 profile tires on 20" 7-Series wheels.
[IMG]
View post on imgur.com
[/IMG]
Not dropped yet but my springs are on the way.
UKF302524.00
Mr.blue223.00
      01-10-2018, 07:39 PM   #18
is_niice
Drives: Everything
People in this thread are so worried about rolling diameter etc..those days are over. I have to ask how old they are. You have people doing Liberty Walk kits and Air Ride.
My speedometer reads exactly the same as Waze because it's all digital. This isn't the 90s anymore.
      01-11-2018, 11:03 AM   #19
AP
AP's Avatar
2762
Drives: G30 M550
Aren't the speedos getting their info from the abs sensors so rolling radius must be key to it ( with a little margin for error to allow for tyre wear)
Does the tyre settings in idrive then influence the speedo in that case?
      01-14-2018, 03:31 PM   #20
UKF30
UKF30's Avatar
Drives: BMW G30 LCI Black Saphire
[IMG]
[/IMG]
Thanks for posting the pic and you have answered my question mate
I am getting 669M allloys and wanted to fit tyres same size as yours because 20" OEM G30 tyres are 35/30 profile which look not much tyres and I need more types so not hard on the back .
I know I could get 19" but bigger the better
      02-24-2018, 08:45 AM   #21
bimmer_335
Drives: 540 mSport
[IMG]
[/IMG]
Did you notice any difference in ride quality or handling with this
      03-09-2018, 03:05 PM   #22
is_niice
Drives: Everything
[IMG]
[/IMG]
It is exactly the same with the exception of the pirelli tires being louder than my stock Michelin's.
