BMW 5-Series (G30) Forum Engine, Exhaust, Drivetrain, Tuning Modifications 530e ipeformance tune?
      10-31-2017, 08:40 PM   #1
Ph0zenstone
Ph0zenstone's Avatar
325
Drives: 2018 530e X-Drive
Is there currently a tune out there made for the 530e iPerformance? Any dinan or BMS tunes compatible?
Edit: found this in ECS’ website which says it’s compatible https://www.ecstuning.com/b-dinan-pa...d440-0012~din/
However it doesn’t list the 530e on Dinan’s own website
      11-05-2017, 05:35 PM   #2
weissja
Drives: 2014 BMW 550i
Anyone?
      11-12-2017, 12:33 PM   #3
Ph0zenstone
325
Found this https://www.ecstuning.com/b-dinan-pa...d440-0012~din/
      11-15-2017, 11:03 PM   #4
guelphman73
guelphman73's Avatar
Drives: 2023 m340i
Originally Posted by phozenstone View Post
That would be awesome. Anyone actually installed one yet on a 530e and able to share some feedback in terms of performance uptick in hp and torque?
Thanks
      11-16-2017, 10:47 AM   #5
Ph0zenstone
325
Thanks
I called ECS and they said it was an oversight. They just updated their site to say it is NOT compatible with 530e since Dinan has not tested it on a hybrid yet
      11-16-2017, 07:26 PM   #6
guelphman73
Drives: 2023 m340i
Thanks
Ah ok good to know. I'm hopeful there will be a Dinan tested module eventually. Would be nice to have the best if both works to get that machine up to 340-350 lbs. ft of torque
      12-31-2017, 08:02 AM   #7
Ginuwine209
Ginuwine209's Avatar
39
Drives: 2024 BMW iX 50
Anybody find out if there is a compatible 530e tune yet? Since the 530i and 530e engines are the same with the only difference being the 530e is detuned would it be right to think the engine output will go up significantly more on the 530e since it starts at a lower hp rating 180hp vs 248hp?
      03-01-2018, 12:18 PM   #8
lakerholic
Drives: 2018 530e M-Sport
Confirmed with Terry (yesterday) at BMS that both the JB+ and JB4 B48 tunes ARE COMPATIBLE with the 530e! Excited to get my hands on one and try it out!
They're saying 25-30 WHP gains...
      03-03-2018, 04:55 PM   #9
Ph0zenstone
325
I've yet to see any proof of this that there would be no errors....or dynos for that matter...any luck?
      03-05-2018, 04:21 PM   #10
lakerholic
Sorry for the double post but another forum member is running the JB+ with no issues. I've purchased one to try out -- figured it couldn't hurt the car that badly and is reversible. Will post my findings.
      03-07-2018, 07:28 PM   #11
lakerholic
Update:
Installed JB+. No issues. Just follow the directions and it's a 10 min job including waiting the 5-7 min for the ECU to go to sleep.
I turned on my sport display yesterday and floored it and it pegged out at 240hp and 300lb/ft torque
Today, my sport display showed 300hp and approx the same torque. Easiest way to check this is for someone with a stock 530e to turn on their sport display and floor it and see if it'll peg to 240/300 like mine was doing pre tune.
At any rate, I'm very satisfied and can feel a difference!
      03-07-2018, 08:58 PM   #12
guelphman73
Drives: 2023 m340i
Update:
Hi! This is really fantastic to see!
As a newbie to this can you please
Elaborate on where to purchase this JB+ Tune, how much, what is involved to install and how much of a difference you feel?
Thanks!
      03-08-2018, 04:05 AM   #13
csm7djs
Drives: G05 X5 3.0d M-Sport
I've got a 520i on order and that is running the same engine as the 530e. Which is as others have said the same engine that is in the 530i but just detuned.
Going to order a JB+ for mine as soon as it arrives.
      03-09-2018, 04:13 PM   #14
Tengocity
Tengocity's Avatar
Scotland
8566
Drives: 911, Cayenne Turbo, Disco 4
I have a tuning box on my 330e, which showed 290bhp on the Dyno, and has been great to use. The drivetrain is much the same so I'm sure it will be available for the 530e.
I find it most useful to maintain performance when the batteries are dead, and especially at higher speeds.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
      06-14-2018, 12:03 PM   #15
chris_sd
Drives: 530e
Update:
Hi lakerholic, any update on experience with the JB+? HAve you checked 0-60 times?
Chris
      06-17-2018, 07:04 PM   #16
sanjuvarma
Drives: 2018 BMW 530e / 2017 BMW x1
Installation of JB+ B48 for 2018 530e (USA)
That's great to hear this works on a BMW 530e, I have a 2018 BMW 530e. Not sure what the installation is like. Can you help? I have attached some photos of what it looks like under the hood, and I'm wondering if it's the TMAP connector I am holding? Newbie here!!
      06-20-2018, 10:26 PM   #17
sanjuvarma
JB+ Post Installation experience.
Ok guys - I just installed the JB+ on my 2018 530e this evening. I was a bit nervous but I saw that this will go only in one of the map connectors and was also worried if I fitted it losely but it came out to be a snug fit. Also, I don't think the engine would have fired if I had connected it losely so all is good. I also maxed out the psi level all the way clockwise to the right (5 o-clock).
So then I took her for a spin up and down the hills, about 10-12 Miles round trip, and quite frankly, didn't notice much of a difference. I had gauged with the sport displays before the JB+ and it had tapped out at 240/300 and I had similar results after the JB+, maybe around 250/310. I drive efficiently most of the time so flooring the gas l is not what I do usually but I did most often in my "test drive" post JB+ installation, but it didn't go past 245-250ish.
Is there a break in and learning period for the JB+? Am I going to feel the difference on the freeway when I pass other cars? Tell me more ...
      07-08-2018, 05:33 PM   #18
Ph0zenstone
325
If you pop open the JB+ box itself, there is a small dial to turn up the PSI
      10-05-2018, 10:03 AM   #19
Mcmanus1806
Drives: Sapphire Black F36 420D
Just ordered and waiting for my 530e,
In the UK where can you order the tune from? What is the most reputable place to buy it from?
Cheers
      01-21-2020, 02:50 PM   #20
Bebe03
Drives: G30 530e
Does the 530e make 292hp with ExtraBoost?
