10-25-2017, 02:56 PM | #1 |
Rep 2,069
Coding to turn off seatbelt chime & close boot with one fob press
Anyone know the coding in E-SYS to disable the seatbelt chime & to allow the boot to close by pressing the fob button once instead of having to hold the button down?
I'm using E-Sys launcher. Thanks |
10-27-2017, 06:20 AM | #5 |
Rep 2,069
I didn't know the cheat code feature existed. I found it and activated all the sets of cheat codes available when the program launches (one of them was yours actually Almaretto).
My FA was activated and I was able to code changes 'manually' without the cheat codes (although I didn't know what I was messing with so just tested it would code and reverted it back to how it was right away). However coding via the cheat codes wouldn't work - There was a cheat code for seat belt chime and another for seat belt warning display. I ticked the box to deactivate both and pressed apply but it said it could not apply the coding. I then tried them individually and it did the same. |
10-27-2017, 11:18 AM | #6 | |
Rep 8,364
10-27-2017, 12:10 PM | #7 |
Rep 2,069
06-09-2018, 01:41 AM | #9 |
Rep 78
Struggling to use cheat codes as looks like things might have changed a bit. Updated Cheat Codes to the most recent available on Github
CAFD_00001B29_006_004_018.ncd Attempted to turn off seatbelt (all available choices) |
06-09-2018, 01:47 AM | #10 |
Rep 8,364
The codes have changed.
axz1757.00 fichtenweg8.50 |
03-23-2019, 03:31 AM | #12 |
with love...
Rep 4
Dear Almaretto, i cant find the lastest cheat code. and i tried 1 by 1 still cant make it.
Finally done. Just learned Hex and decimal. hurrrray! Last edited by MONDAJ; 03-23-2019 at 04:25 AM.. Reason: problem solved |
03-24-2019, 12:50 AM | #13 |
Rep 8,364
05-03-2022, 11:00 AM | #14 |
Rep 2,399
hi could you tell me which codes you disabled to turn the seat belt chimes off? im struggling to find which one it is in esys
05-03-2022, 03:26 PM | #15 |
Rep 8,364
