10-12-2017, 07:42 AM | #1 |
Rep 986
sway bar options
Im looking to upgrade the sway bars on my m235xi. I do alot of track days, and would like to improve the car more.
There are sooo many options. Dinan, H&R, EIBACH, Meghan Racing, etc All are different front and rear diameters. How to choose ?? Limited by xDrive, only a few companies that do xdrive. H&R 72878-3 (28mm/20mm front 2 holes, rear none) Dinan D120-0595 (25mm/19mm front 3 holes, rear none) Stock bar on the m235 is 23.5mm front, and 12mm rear. -Paul Last edited by zipphreak; 10-12-2017 at 02:10 PM.. |
10-16-2017, 10:49 PM | #2 |
Rep 525
Do those companies list how much stiffer/softer their settings are compared to factory? There's no defined answer as far as settings are concerned, though, so you'll have to do some testing to see what works best.
10-17-2017, 09:58 AM | #3 |
Rep 1,541
The labor to install them is pretty high since you have to drop the sub-frames. ROI is not worth it in my opinion.
~6 hour job.
10-17-2017, 11:28 AM | #5 |
Rep 2,860
It has been a looong time since I was shopping these parts separately, but IIRC, the key metric for sway bars is rotational force (inch/pounds, I think, or pounds/degree). If they all have the same dimensions/shape, then diameter is a proxy for this, but only a rough estimate.
There are 2 main camps about sway bars - one is that they are the key element for handling (need to be stiff), the other is that they are just to fine tune front/rear balance or transitional behavior (often just one, and smaller). My experience is that it isn't as different as they would suggest - theoretically big bars give better compliance, but only when you hit something with both wheels evenly, like an expansion joint. Since these are so hard to get at, I've decided to adopt position 2, and any future upgrades will look at springs/shocks first (camber plates, race tires obviously part of this, and not until I'm ready to ditch the warranty). |
10-17-2017, 10:33 PM | #6 |
Rep 986
i looked at upgrading struts and options are severely limited for xdrive, basically kwv3 for 2200 or mcs 2way remote reservoirs for 4500.
My buddy is a great mechanic and can do the sways with me, so labor will be minimal. |
10-24-2017, 11:19 PM | #7 |
Rep 2,214
Doing mine along with KW CS coilovers and full bushing replacement in the new year.
Went with Hotchkis F&R Sway bars and their uprated end links. Didn’t dig too much into other options, but liked that I could get them through my work, so saved a few dollars there as well. Have access to a 7 bay full service shop so I’ll be doing it myself over a couple of weekends..
10-25-2017, 08:46 PM | #8 |
Rep 986
Nice! Setup a post when you do the install. It would cool to see pictures of it in the process! I know it's a tedious task.
What are you doing for bushings. Rear subframe ? Are you going full solid aluminum or urethane, or just inserts ? xdrive m235s have way more limited track coilover options, no KW CS for us.. just KW v3. Bilstein Clubsports are an option (48-238946) or MCS 2W's. I'm totally eyeing a set of those MCS 2-ways for next year The reservoirs on their standard 2WNR's extend past the length of the normal strut, and into where the front-half shafts go into the wheels so I'm forced into remote reservoirs. |
10-26-2017, 03:21 PM | #9 | |
Rep 2,214
10-26-2017, 03:27 PM | #10 | |
Rep 525
I currently have KWs on my "track car" and want Ohlins next, personally. Well, that's because I can't afford the more expensive options. |
10-27-2017, 12:00 AM | #11 | |
Rep 2,214
10-27-2017, 11:36 AM | #12 | |
Rep 525
If I come across a set of Ohlins for the 2er for a reasonable price, however, I'm probably going to jump on it without much thought. |
10-27-2017, 01:51 PM | #13 | |
Rep 2,214
The Ohlins R&T priced in around $2500 iirc, if not less. Great deal, imo.
