BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Low audio volume via wireless CarPlay
      10-03-2017, 11:19 AM   #1
Renalt130
Switzerland
15
Drives: G30 540i / F15 M50d
I have noticed there is quite a difference in audio volume between eg radio and music via the wireless CarPlay option. The volume toggles on the phone don?t do anything so I?m wondering where/how/if there is a way or setting for this?
B&W System for what it is worth.
      10-13-2017, 01:16 AM   #2
BMW_Sweden
Drives: 540iX G30
That is strange. In wired mode in other cars it's the same, the toggles don't do anything. But the volume is maxed from the phone as standard..
I didn't notice any problem when I tried it a few weeks ago, but I didn't compare to the radio.
If you turn up the volume in carplay mode and then switch to radio, is it very loud then?
Maybe it saves the volume for different inputs?
      10-13-2017, 01:52 AM   #3
emre
emre's Avatar
Turkey
85
Drives: G30 540i xDrive
I have the Harman Kardon sound system and I am having the same problem.
When playing spotify via wireless carplay, volume is remarkably lower compared to radio and saved music collection.
And yes, if I turn up the volume in carplay mode and then switch to radio or saved music it is too loud for me.
I don't like to play music loud in car. I keep the volume around 40% when listening to radio. If I switch to carplay I need to turn up the volume to around 60% and when I switch back to radio 60% is too loud for my taste and I have to turn it down.
G30 540i xDrive M Sport MPPSK / BM3
      10-13-2017, 03:22 AM   #4
ADS-UK
ADS-UK's Avatar
Drives: G30 - 530d M Sport
This has been the case in my current F32 too. Volume level between radio and either wireless or wired audio from iPhone is quite different. I just turn the volume button up when I switch to the phone.
      10-13-2017, 08:22 AM   #5
Renalt130
Switzerland
15
Yes, if I switch to radio it is much louder
Also note I?m referring to CarPlay wireless. Not Bluetooth music streaming. With the former the volume buttons on the phone don?t work, with the latter they do (and then yes, you can correct this but not if you?re in CarPlay).
      10-25-2017, 04:46 AM   #6
Renalt130
Switzerland
15
Is there a way how I can make the CarPlay go WIRED only instead of wireless? That should be a good test?
      10-26-2017, 09:44 AM   #7
en1gma
en1gma's Avatar
Drives: G03 X3
I would like a wired-CarPlay option also: this is how I've used it in other cars - including an Opel Corsa hire car!
In the G30, CarPlay only seems to work with Bluetooth AND wi-fi enabled on my iPhone.
      10-26-2017, 01:06 PM   #8
ADS-UK
ADS-UK's Avatar
G30 is one of the first cars to offer wireless CarPlay. This is also the reason why Apple showcased wireless charging of iPhone 8 in a G30.
      05-20-2018, 01:14 AM   #9
Renalt130
Switzerland
15
Solved
The trick that did it for me is to disable sound check and volume limit in the music settings of the iPhone. This limit basically noticeably attenuates the volume. I've also noticed that for most of the music, you don't really need this volume limit and i haven't experienced any variance in volume from song to song so far, except for maybe some real oldies. Read: it typically gets them less loud and you don't have to worry that suddenly things get much louder.
There is a similar setting in Spotify (audio normalization I believe).
Solved.
      05-20-2018, 02:37 AM   #10
ZigmundUK
ZigmundUK's Avatar
Drives: I20 IX M60 Oxide Grey
I find 50% volume on CarPlay is very loud music. Not a big difference between CarPlay and DAB for me.
Previous cars - auxiliary inputs were always lower volume...
Running: G30 530d M Sport (B57) Mediterranean Blue
Running: I20 IX M60 Oxide Grey
Gone: F15 X5 40d M Sport (N57) Glacier Silver, E61 520d SE Auto (N47D20) Titanium Silver, F31 330d M Sport (N57D30A) Estoril Blue, E87 120d SE Auto (M47TU2D20) Sparkling Graphite
      05-22-2018, 08:50 AM   #11
en1gma
en1gma's Avatar
Drives: G03 X3
It would be great if BMW reintroduced different sound settings per input, like they used to (in e39, for example).
Audio normalisation in Spotify is a bit of a sledgehammer implementation of trying to get all songs to output at the same volume: it might be ok in the car environment, but significantly affects overall sound quality when listening over decent headphones or on a home HiFi. All dynamic range disappears...
It's a bit like the compromised sound of compilation albums vs the original source LPs/singles.
Which is a shame, as there are 'smart gain' features in a lot of the home streaming devices that read the metadata (artist, track name, date, music genre, etc) that is held in all digital songs and automatically increase/decrease volume of each individual song to match your chosen volume level instead of squishing all to the lowest common denominator. An example is the now sadly defunct Logitech Squeezebox family...
