BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis Winter Tyres for 550 xdrive
      08-28-2017, 10:09 PM   #1
Max1212
Drives: M550 G30
My current summer tyres is:
245/40 R19 - Front
275/35 R19 - Rear
Can I use this winter tires
Nokian Hakkapeliitta 8 245/45 R19 102T - front
Nokian Hakkapeliitta 8 275/40 R19 105T - rear
Looks like for rear tyres are bit higher. Is this will cause any problems with xdrive?
Nokian not making tyres 275/35 R19, but Hakka 8 is ideal for strong winters.
      08-29-2017, 10:56 AM   #2
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
245/40 R19 - Front
275/35 R19 - Rear
First of all, the new Nokian Hakkapeliitta 9 will be out this winter, so I'd check that out if you want studded tires.
I don't know how the xDrive will react to the larger 245/45 and 275/40 size, so I'd go 245/40/19 all around, even if the rear wheels are wider.
      11-02-2017, 06:42 AM   #3
MTHX
MTHX's Avatar
Drives: 335XI MPerformance edition
2018 F90M5  [0.00]
M550: Existing setup for 18" for winters? I saw on some review that's it's possible? Some people have this setup?
      11-03-2017, 05:55 AM   #4
NTTY
NTTY's Avatar
Switzerland
37
Drives: G30 M550xi
Yes, I tested an M5550xi with 18" winter setup.
Wheels were Multi spoke 619, 8x18 ET 30.
Three other 18" designs are available from BMW: 684 (V-Spoke), 632 (W-Spoke) and 634 (Double-Spoke).
Cheers.
2018 M550i Sepia-Violet
      11-03-2017, 10:33 PM   #5
MTHX
MTHX's Avatar
2018 F90M5  [0.00]
Cheers.
Thanks a lot for the info !
Do you remember the tire size?
E60 550 2007 - Grey //
F30 2015 335XI MPerformance edition - Lacuna Seca Blue //
F30 2015 335XI MPerformance edition - Grey black //
F90 2018 M5 - Donington Grey
      11-04-2017, 02:50 AM   #6
Delija
VIP
Delija's Avatar
41
Drives: G20 M340i xDrive
245/45 is standard for 18" - Style 619 wheels are non-staggered.
p.s. Keep in mind that the same wheels are offered for G11 in size 245/50.
Life is not measured by the number of breaths you take but by the moments that take your breath away...
      11-20-2017, 04:07 PM   #7
BGT3
Drives: M550ix
245/40 R19 - Front
275/35 R19 - Rear
You want a narrower snow tire than what you use for summer tires so they dig into the snow
I use the size you mention (in an A/S) on my M550 since I live in NY where the roads are bad and wanted a larger sidewall. The difference in height (from from to rear) is very small from the stock size and has not been a problem.
2018 M550ix
2019 X5 M Sport 40i
Porsche 997 GT3
Porsche 993 C2 Cab.
