08-18-2017, 01:56 PM | #1 |
Rep 2
435i F32 Instrument Cluster Display Issue
Half of my instrument cluster LCD display is blank most of the time. I performed the cluster reset test hoping that it would fix my issue but haven't had any luck. Before going to BMW I wanted to see if there were any suggestions out there.
https://ibb.co/mLS5Rk https://ibb.co/ighN6k Last edited by Gm_809; 08-18-2017 at 02:02 PM.. |
08-18-2017, 02:33 PM | #2 | |
No 55mph
1622
Rep 8,476
Have never seen that, did you retrofit a different cluster or is that the factory supplied one? Have you done any coding for the dash module prior to it looking like this?
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
08-18-2017, 02:41 PM | #3 |
Rep 2
This is OEM display from what I know. I purchased used so no telling what the original owner has done No coding has been done from my end.
Tags |
435, f32, instrument cluster, lcd, pixels |
