BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Coding: Keep last driving mode
      06-29-2017, 02:04 PM   #1
Carbunkle22
Drives: M550i
Always reverts back to Comfort like we all know, but is it possible to make it retain the last setting? (For example, I have to set it to Adaptive everytime).
Alternatively, is setting a different default (like Adaptive) also possible?
Thanks
      06-29-2017, 09:28 PM   #2
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Yes, any car with BDC_Body can set to remember shutdown setting (certain choices) or default to any choice.
      06-30-2017, 11:49 AM   #3
Carbunkle22
Drives: M550i
Thanks. I really need to learn how to do BMW "coding" then. I've been putting it off as I've been feeling too lazy to do it, just for one single thing.
      06-30-2017, 05:08 PM   #4
Almaretto
Almaretto's Avatar
2374
There are lots of options, but coding choices are personal preference.
      07-24-2017, 07:08 PM   #5
hicksel
Germany
Drives: BMW G30 530d
I´m a relatively new coder and have just managed to code MSA Memory on my G30. Can you share your insight as to where exactly i can code to always default to sport mode in my BDC_Body?
      07-24-2017, 07:43 PM   #6
Almaretto
Almaretto's Avatar
2374
Search "Fes."
Douggie142.00
      07-28-2017, 04:36 PM   #7
hicksel
Germany
Search "Fes."
Thanks that was exactly the hint I needed.Quite obvious actually since it probably stands for "Fahrerlebnisschalter" which translates to Driving Experience Switch. Now I just have to figure out how exactly to set up the memory function.
      07-28-2017, 04:37 PM   #8
Almaretto
Almaretto's Avatar
2374
      02-15-2018, 06:03 PM   #9
bmwgcyr
Bimmerfest coding member since 2012
Drives: BMW m550i xDrive 2018
G30 m550
I cannot find the right parameter in the 4 CAFD files for BCD_BODY2, can yhou help. I would like to have adaptive as default
Thanks
BMW G30 m550i xDrive 2018
Born: 2017-09-11
Carbon Black, Black Nappa with Grey Poplar. Pkgs: Premium, Adv Driver Assist, Remote Parking, 668M 20 In, Adaptive suspension & Smartphone
Z1Q, ZC5, ZK9, ZTV, 29X, 2VW, 4LQ, 4161, LZFK
      02-15-2018, 06:05 PM   #10
bmwgcyr
Is this the one and which value should be set?
Born: 2017-09-11
      02-15-2018, 09:20 PM   #11
Almaretto
Almaretto's Avatar
2374
Originally Posted by bmwgcyr View Post
G30 m550
Thanks
You need updated mapping found in Launcher Pro 3.04
      02-16-2018, 09:31 AM   #12
bpbaud
Drives: 530i
Where do you get it?
      02-16-2018, 07:29 PM   #13
Almaretto
Almaretto's Avatar
2374
Directly from developer. You email for access to website to generate your own activation code.
      07-22-2018, 03:39 PM   #14
Who's on first
Who's on first's Avatar
Drives: A-10C
Did you figure it out?
      07-23-2018, 11:42 PM   #15
Almaretto
Almaretto's Avatar
2374
No.
      08-22-2018, 04:09 AM   #16
theend
South Korea
Drives: G30 520D
Talking
Thanks for sharing.
      08-23-2018, 04:52 AM   #17
drivethemachine
drivethemachine's Avatar
193
Drives: 2018 BMW 530e
Does anyone know if this particular option can be coded using BimmerCode? (And how?)
      12-06-2018, 02:36 AM   #18
kobluna
Drives: 320i
I'm trying to code this on M550i but I cannot find the right CAFD to do it. I'm using Esys 3.27.1 with Launcher Pro 3.2.1. Launcher doesn't seem to know about CAFDs as there is a lot of unknown parameters there.
There are 4 CAFDs under BDC_BODY2 but all of them gives me nothing when I'm searching FES. Is it so that M550i has something different than other cars or what is the problem? I cannot make any coding for BDC_BODY because of this.
      12-06-2018, 09:57 PM   #19
Almaretto
Almaretto's Avatar
2374
That is likely a memory issue because it is mapped with latest Pro Launcher.
Make sure to
1. install 64-bit java in E-sys directory
2. Increase memory in Launcher Settings to 4-8 GB
3. remove unneeded kiswb in Launcher settings.
      12-11-2018, 01:25 PM   #20
kobluna
Drives: 320i
Make sure to
Thanks, that did it I also managed to code off automatic headlights when light switch is in 0 position. Now it stays in DRL even if there is dark outside. The A mode puts headlights on depending of ambience lighting.
      08-22-2020, 11:28 AM   #21
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
On my f15 X5...it was doable using the Bimmercode app using coding selections found in the BDC & ICM modules. It did NOT require going to the EXPERT side. It was simple selections found in the aforementioned modules (BDC & ICM) under “DRIVING MODES”:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
      08-22-2020, 03:58 PM   #22
LuvMyBM
Drives: BMW G30
Connected Drive Services Help
Hi...I am new to these forums and looking for help on the activation of connected drive services. Any help would be really appreciated. Thanks
