06-22-2017, 06:12 PM | #1 |
Rep 718
Coding: BDC_BODY2
Anyone have insight on properly reading BDC_BODY2?
With Esys 2.7.1 and PSDZ 61.4 it still only shows a bunch of periods next to everything and no details. Who has successfully gotten into this for coding? |
06-22-2017, 10:10 PM | #2 | |
Rep 8,364
View post on imgur.com Last edited by Almaretto; 06-22-2017 at 10:37 PM.. Reason: Added Image |
06-24-2017, 10:30 AM | #3 | |
Rep 718
There are 4 CAFDs in BDC_BODY2, (17BC, 17BD, 1DF7, 1DF8) the only one that shows periods and no functions is CAFD_000017BC_103_036_153, others load up fine. The CAFD shows up in my files. Last edited by cwhands; 06-24-2017 at 01:10 PM.. |
06-24-2017, 01:24 PM | #4 | |
Rep 8,364
I am aware there are 4 CAFD's and you should be able to read them all. Depending on I-Step, parts are unmapped, but the majority are mapped and you should not see only periods. For complete CAFD_ID list, see here. The only solution I know is using latest Launcher software (ie 2.7.1). Here are images from E-sys and NCD / CAFD Tool for what you should see: |
06-24-2017, 01:41 PM | #5 |
Rep 718
Thanks for your help Almaretto. Got the CAFD to stop showing periods after a couple attempts reconnecting to the car. That said, a lot of the values still come up as "unmapped value" Any idea what causes that? That CAFD list is helpful, too. Thanks again.
06-24-2017, 02:08 PM | #6 | |
Rep 8,364
Mapping currently is based on P3.59.4 I believe. We are left either making educated guesses and/or waiting for TM to update. |
cwhands640.00 |
06-29-2017, 11:59 AM | #7 | |
Rep 56
Drives: G05 X5 40i, F10 535xi, F26 X4
06-29-2017, 12:35 PM | #8 | |
Rep 8,364
FLC_Aktiv is present and can be found by reading comments or simply VO coding certain options. EDIT: Position 0 is DRL. Lighting is in FLM. Last edited by Almaretto; 06-29-2017 at 01:07 PM.. |
07-04-2017, 04:26 AM | #9 | |
Rep 67
Also, couple of times when I clicked on "Edit FDL" then E-sys crashed without any error messages. |
07-16-2017, 04:48 PM | #10 |
Rep 3
HI!
I am also having a problem with only the dots showing... I am using Launcher Premium 2.7.1 and data files 62.1... When i start the laucher i select G030 chassis, for coding i select S15A... What am i doing wrong ? Thanks, |
07-17-2017, 12:55 PM | #11 |
Rep 8,364
That should work. You can also try G11 or G12.
07-18-2017, 10:22 PM | #12 |
Rep 2
I am also having a problem with only the dots showing when I set high memory in launcher premium.
When I set medium it is ok. However when I set medium and then read 17BC@BDC_BODY2 of G30, edit, save and then code FDL there is be out of memory error. I'm using E-Sys 3.27.1, Launcher Premium 2.7.1 and PSdZ 3.62.1 |
07-19-2017, 06:01 PM | #13 | |
Rep 8,364
08-05-2017, 05:20 AM | #14 |
Rep 3
Does anyone know how to disable ASS ? I cannot find tcmaster values in BDC BODY... I compared the files with my brothers F15, but no luck... Any help would be appreciated.
Thanks, |
08-05-2017, 05:23 AM | #15 |
Rep 3
08-05-2017, 11:00 AM | #16 |
Rep 8,364
05-17-2019, 03:46 PM | #17 |
Rep 34
Hi guys,
I have been fighting with this BDC unmapped sections and it seems like I cannot get it to work. I have reinstalled java allowing the Launcher to run with 4GB ram (this solved the memory issue) but all of the folders are appearing with '.' (screenshot enclosed). I am using E-Sys 3.30 with Launcher Pro 2.8.1.155 with latest datens and success is 0. Tried dozen of times to restart (application as well as windows), reread the module, open the CAFD in the FDL editor - nothing worked. The rest of the modules are appearing fine. |
05-17-2019, 04:51 PM | #18 | |
Rep 8,364
05-17-2019, 07:55 PM | #19 |
Rep 34
Thanks, will go for the update.
I have read a lot of threads and I saw people with Launcher 2.7 even having the BDC mapped and was struggling why I cannot make it run |
05-18-2019, 12:44 AM | #20 |
Rep 8,364
