06-19-2017, 09:59 PM | #1 |
projecttechnik.com
108
Rep 215
Best switched 7.5/10/20A fuse for dash cam/Celllink B hardwire?
Hey All
I have the Blackvue DR650-2CH and Cellink B battery and am trying to find the best switched 7.5/10/20A to use my add-a-fuse. A lot of DIYs use 5A but trying to find a proper 7.5/10/20A switched fuse that is not an essential one like an engine fuse. Thanks -Pearson
06-19-2017, 10:57 PM | #3 |
projecttechnik.com
108
Rep 215
Looking for a fuse...in the fuse box. Do not want to splice into a wire.
06-20-2017, 07:23 PM | #4 |
Rep 267
I have the Cell-link battery for my dashcam, I used an add-a-fuse and powered it from the fuse box in the back of the car, and mounted the battery to the underside of the rear deck above the trunk. I'll see if I can post some pictures in the next day or two, I believe I tied it into the 20A circuit that powers the rear 12 VDC outlet. It shuts off about 5-10 minutes after the car is turned off.
2017 430ix Gran Coupe
06-21-2017, 04:23 PM | #5 |
Rep 267
Ok, had some free time this afternoon to take a few pics of my install....
First picture shows where I installed the cell link battery...right under the rear deck, attached with some custom brackets I made out of 1x 1/8" aluminum stock and some weatherstripping to cushion things properly. You really don't see the battery unless you're looking for it. I oriented it so that I could easily switch off the battery charging input when necessary. Second picture shows where I plugged the cell link battery into in the rear fuse compartment using an add-a-fuse plug (circled connection). The other two add-a-fuse connections are for my Bimmertech Power Trunk Retrofit. Third picture shows the fuse location...fuse 162 (circled), which is a 20A fuse that is switched off a short while after shutting the car off... Fourth picture shows what fuse 162 is used for, 12V power outlet, likely the one in the trunk. (circled)
zerofighter107.50 Solidjake945.00 |
06-21-2017, 07:00 PM | #6 | |
projecttechnik.com
108
Rep 215
12-28-2018, 11:08 PM | #7 | ||
Rep 1,696
So what is the best fuse that is rated at least 10 AMP that will shut off immediately when the ignition Orion is killed? |
12-28-2018, 11:51 PM | #8 | |
Rep 267
How so? The circuit turns off regardless. If you leave something plugged into the cigarette lighter socket after you have shut the ignition off, do you see it delay going into parking mode?
12-29-2018, 12:00 AM | #9 | ||
Rep 1,696
I called Blackvue and they said that when you hard wire the B-124 to the fuse box, when you are driving, it is the car's battery that is actually powering the dash cam. When you shut down to park, the car's battery is bypassed and the B-124 battery takes over to power the dash cam for parking mode. I read co flicking info about this as well, but I don't think Blackvue customer support would be wrong? Let me ask you this to prove this theory. What if you were to park for 10 days straight and you Cellink Neo battery is drained to 0%.—obviously your dash cam will be off since it has zero power. Then you go start your car. Will the dash cam instantly turn on (because it is being powered by the car's battery) or will it take a few minutes for the car's battery to charge the Cellink Neo, which then has sufficient power to turn on the dash cam a few minutes later? My concern really isn't about delaying parking mode or not. My concern is about having the car's battery charging and / or powering the B-124 / Cellink Neo while the ignition is off—that can hurt he car's battery life as there will also be draw from it without the alternator running. And this apparently happens with Fuse 162 (and I think same with Fuse 125). |
12-29-2018, 12:12 AM | #10 | ||
Rep 267
12-29-2018, 12:30 AM | #11 | |||
Rep 1,696
My issue is that if you use a fuse that has about 10 minutes of residual power running through it—that residual power is coming via the battery (and the car's alternator) is off. That means that the Cellink Neo hasn't kicked in yet to actually power your camera—your car is powering the camera! And we all know that you should not run any electronics off the car battery (if alternator is off). Do you see my point? |
12-29-2018, 12:41 AM | #12 | ||
Rep 267
12-29-2018, 01:13 AM | #13 | |||
Rep 1,696
However, doing it for maybe 3-4 times a day (depending on how many times you park) and to do it for a year, may start to cause premature wear and tear on the battery is all I'm trying to say. My point is if I can avoid it, I will. That's why I'm in search for a switchable fuse that is instantly off when ignition is off (none of this 10 min of residual power BS). But if our M3/M4 do not have such a fuse like normal cars do, then I can live with tapping into Fuse 162 or Fuse 125 is the other popular choice. |
12-29-2018, 11:21 AM | #14 | |
Rep 267
Nevertheless, if it makes you more comfortable, I'm sure you can easily find a circuit that shuts off at the same time the ignition turns off, simply get a meter and probe the circuits on the fuseblock until you find one. The little chart that comes with the fuseblock is helpful in giving you clues on what each circuit does eg. try one of the seat heater circuits, I'm pretty sure those shut off immediately when the ignition is turned off.
01-11-2019, 11:29 AM | #15 |
Rep 385
Which fuse is always active in the rear fuse box? Dont feel like sitting there an hour after car is turned off to find out. Trying to hardwire my cam for parking mode.
