05-03-2008, 03:24 PM | #1 |
Rep 319
Paintless Dent Repair
I just found a 1" dent under the small back window on the driver's side (between the door and the back wheel well). Paint looks fine, but there is simply a dent there. Apparently some a-hole opened a door into my car. Anyways, it's annoying the crap out of me when I see it (though most people probably wouldn't even know it's there). I called a dent repair shop and they quoted about $190. Does that sound reasonable?
The guy said something about the new M3 having aluminum side panels, making it bit more expensive - I'm not sure if that is true.... |
05-03-2008, 06:03 PM | #2 |
Rep 635
190 doesnt sound too farfetched at all. JUST make sure they use proper teqniques to get that dent out and double check the paint after because chances are there might be a TINY difference sorry to hear about that.
05-03-2008, 07:02 PM | #4 |
Rep 1,504
That only happens with metallic paints when the flakes shift from the pressure used to remove the dent. Alpine White and other non metallics are great candidates for this process. FYI, don't let them tell you they have to drill a hole to reach the dent. The experienced guys can glue a hook to the surface of your car and pull it out from the outside, and then tap it back flush. Good luck with the repair.
05-03-2008, 08:27 PM | #5 |
Rep 655
Drives: Gone- 08 DCT SSII, 2006 SMG
Location: Current: 2014 BMW 4-Series Convert for the fiance w M Package, F150, 06 S2000, 08 911 c4s
i just paid $175 for my 05 m3. worst part is one of my employees saw the woman do it. i called her out and she said my employee was lying. i said "i guess my employee is out to get you?" Talked to the police who said I can take her to small claims court. not worth my time.........
05-03-2008, 09:22 PM | #6 | |
Rep 635
05-03-2008, 09:27 PM | #7 |
Rep 655
they did mine from the inside. they use a long rod and push the dent out.
http://www.wefixuglydents.com/how_pa...air_works.html |
05-04-2008, 01:10 AM | #8 |
Rep 5,448
sounds high - my guy charges about $80-100 for an easy to get to dent.
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
05-04-2008, 04:06 AM | #10 |
Rep 319
Thanks for all the feedback. I might just go with it because these guys seem professional and they worked on another e92 M3 last week. Pisses me off to think of the person that caused the dent and how they probably didn't even think twice about it afterwards.
05-08-2008, 07:58 PM | #11 | |
Rep 319
05-28-2008, 08:54 PM | #14 |
Rep 3,071
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
I just had a 1" dent taken out of my E36 for $75. The rear quarter panel on the E92 M3 is indeed steel, not aluminum. I would be concerned if the place either didn't know that or was lying to you about it to make more money. Time to call another place.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
05-28-2008, 11:05 PM | #15 | |
Commander-In-Chief
2102
Rep 8,913
Drives: 2023 M2 Coupe, 2020 GLE 450
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
05-30-2008, 08:14 PM | #16 |
Rep 319
I called another guy who sounded like he knew what he is doing and it does not seem as if this repair is going to be easy. Basically, the dent is too far in front of the quarter panel to reach from the trunk with a rod. This guy suggested that there may be access points from the rear wheel well, but that would require taking the wheel out, and removing the wheel well covers. The guy also did not recommend doing any kind of dent removal from the outside. I'm not sure it's going through THAT much trouble to get this thing fixed. But it still annoys the crap out of me everytime i see it!
I'm posting a picture of the dent in case anyone else has any ideas. |
05-30-2008, 08:25 PM | #17 | |
Commander-In-Chief
2102
Rep 8,913
Dent removal access
Seems like it should be reachable by taking the rear seat side panel out?
05-31-2008, 08:13 PM | #19 | |
Replicant
Rep 199
05-31-2008, 08:49 PM | #20 |
Rep 3,071
The dent in my E36 was in the same location as the one in the picture. The dent guy tried to reach it through the wheel well and from the tail light with no luck. I finally assisted him by taking out the interior trim piece that is below the rear window, in the E36 it took 5 minutes to remove.
Since there's no service manuals out for the E92 M3 yet (that I know of) I'd recommend talking to the body shop that does the work for your local BMW dealer to determine how to remove that interior trim piece. It won't be that hard to do. On the E36 behind the interior trim was a metal access plate that gave us access to the inside of the exterior body panel, from there the fix was easy. Easier than removing the taillight in fact.
05-31-2008, 08:50 PM | #21 |
Rep 655
mine was in a similar spot on my 05. the guy fixed it from the trunk.
11-05-2008, 08:49 PM | #22 |
Rep 5
Hello I am providing this tipe of business for long time . the who quoted that price absolutely right. Also you driving expensive car . so before bying that tipe of the car you must to know how many expensives you have soon. BMW thats not a Ford Focus. In the body shop you must to pay 5 times more for repainting, but after thats makes you car value less. (also gone be problem claying aut owerspray.)
P.S. You can wisit my website : http://www.dentambulance.com |
