BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis Bolt pattern on G30
      05-23-2017, 08:23 PM   #1
pkancel
pkancel's Avatar
Drives: BMWs
Bolt pattern on G30
I should have read up on this before but just found out the bolt pattern has changed. I was trying to test fit my rear M4 wheels/tires on the rear of my G30 540 and after removing everything discovered the difference.
Damn what a pain in the ass. Now it limits what wheels we can put on until the vendors get caught up with the bolt patterns and offsets.
      05-24-2017, 01:57 AM   #2
ZigmundUK
ZigmundUK's Avatar
Drives: I20 IX M60 Oxide Grey
Sad but true.
Running: G30 530d M Sport (B57) Mediterranean Blue
Running: I20 IX M60 Oxide Grey
Gone: F15 X5 40d M Sport (N57) Glacier Silver, E61 520d SE Auto (N47D20) Titanium Silver, F31 330d M Sport (N57D30A) Estoril Blue, E87 120d SE Auto (M47TU2D20) Sparkling Graphite
      05-31-2017, 03:57 PM   #3
richb811
richb811's Avatar
455
Drives: 2020 G20 330i M Sport
Annoying at the moment, but the 5x120 is a dying breed. The new pattern will open up a lot more options for BMW fitments going forward
      06-16-2017, 04:51 PM   #4
drmlee
Drives: F06 650i
its 5x112 like the new 7 series now. which is what mercedes and audi have been using forever. im not sure what the center bore is on the bmw, but audi and mercedes uses 66.56/66.6, i was hoping to be able to reuse my 21" HRE on my next car, but that doesnt look like its happening now.
      06-23-2017, 01:29 PM   #5
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
66.56mm (+/- 0.03mm) is the CB.
      06-23-2017, 02:22 PM   #6
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Originally Posted by lemetier View Post
66.56mm (+/- 0.3mm) is the CB.
+/- 0.3mm? Seems like a lot, that be from 66.26 to 66.86. :
      06-23-2017, 02:26 PM   #7
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
Oops thanks for catching that. +/- 0.03mm is the required tolerance.
      07-03-2017, 07:11 AM   #8
manilae90
Drives: 2017 520d G30
2006 320i  [0.00]
Audi and Merc wheels are usually 66.6 to fit the 66.5 hub, Im sure that will work for the G30 as well
      07-03-2017, 02:44 PM   #9
matbl
Drives: G31
Any info on ET?
Guess that depends on rim width right?
      07-04-2017, 11:07 AM   #10
remmib
remmib's Avatar
Norway
1568
Originally Posted by matbl View Post
Any info on ET?
I'd say pretty much same as F10.
      07-04-2017, 12:18 PM   #11
matbl
Drives: G31
Which is?
      07-04-2017, 12:44 PM   #12
remmib
remmib's Avatar
Norway
1568
Which is?
You mean a flush fitment on aftermarket wheels? On 20" I'd say 20x9 ET25-30 is normal in the front, and 20x10.5 ET35-40 in the rear.
