05-19-2017, 08:27 PM | #1 |
Rep 2,653
What's Next?
I will be pulling the trigger this weekend on a Dinan Sport tune for my '14 320i XDrive and was wondering what you guys thought might be prudent in terms of hardware. I've been reading that an intake and intercooler should follow a tune, but wanted to hear from you guys. A lot of knowledgeable peeps on this forum and your help/recommendations would be greatly appreciated.
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Tune Stage 2 - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI
05-19-2017, 08:30 PM | #2 |
Rep 1,425
Intake isn't going to do much good in terms of making power. And if all you have is a tune, then a new FMIC isn't likely going to benefit you much. Next best bag for your buck will be a down pipe. JMO.
05-19-2017, 08:32 PM | #3 |
Rep 2,653
Thanks for that. What I'm basically trying to do is "reinforce" the car after the tune is installed. The Sport tune is pretty conservative based on what I've read, but I want to make sure the other components aren't jeopardized in any way, if that makes any sense?
05-19-2017, 10:30 PM | #4 |
Rep 14,115
Drives: G82 M4C X-Drive
Suspension, tires, then brakes. THEN maybe exhaust, intake, and intercooler.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
05-20-2017, 05:48 AM | #5 |
Rep 2,653
So with the added boost and additional HP, the stock turbo and other bits can handle it?
05-20-2017, 10:01 AM | #6 |
Rep 14,115
They can handle it more than a car with poor traction, soft suspension or poor braking.
