05-17-2017, 09:50 PM | #1 |
Rep 47
2014 CPO at Dealer indefinitely <<Update>> REM Module failure
Not sure I'd like this to be my introduction but I need some support.
My car went in for service @ 55xxx km about 5-6 items serviced. Fuel pump recall (no part), cabin filter, oil, reset. I paid for alignment and windshield. Problems: HUD is clear but dim. Maxed out in the control display settings and maxed out dimmer (beside headlight controls). I can barely read in bright sunlight. Serious Problems: Week and a half later, my rear windows will not roll down. No rear signals but front and mirrors work. No indication on system check that they are inop. Tried to check fuses but trunk release doesn't work nor does the camera. Still have brake lights though. oh and CEL of course I work on cars every day but I couldn't be bothered to start with my own car. I meant to do a OBDll scan at work but i was super frustrated. @dealer and no evidence I'm going to see my car ever again. Anyone recall seeing threads with major electrical issues? Advice? Last edited by vsasesse; 05-27-2017 at 12:03 AM.. |
05-18-2017, 08:53 AM | #4 |
Rep 718
As far as the HUD goes, the car possibly had a windshield change. The OEM windshields have a flat spot where the HUD projects. Some non-OEMs do not, which will distort the image slightly, maybe making it appear less bright. But based on the other potential electrical issues you have, hmmm, probably not the windshield.
Mine: 2019 Mini Cooper S / Moonwalk Grey / Black Interior
Wife's: 2018 X2 XDrive 28i / MSport X / Mediterrean Blue / Mocha Dakota Leather Previous: 2008 E92; 2014 F30; 2016 F30 M Sport; 2011 E82 (Man I miss the 1er!) Last edited by X2 Monstah; 05-18-2017 at 09:07 AM.. |
05-18-2017, 09:56 AM | #5 |
Rep 1,342
I'd be frustrated, too. But if you've had the car for awhile, there's likely not much you can do but wait. Good news is that you have a decent loaner, right?
Windshield issue just come up? Or has it been like that for some time? Re: electrical issues on what sounds like the back half of your car?!? Almost sounds like a break/tear in a major cable somewhere? Run over or hit anything? Weird... |
05-18-2017, 08:10 PM | #6 |
Rep 47
So I did pay for the windshield replacement a week or so before this. They told me the glass is HUD.
My settings before I brought it in we're half brightness in the iDrive settings and rheostat turned halfway. After replacing it I couldn't see it at all with those settings. Not blurry though. |
05-18-2017, 09:39 PM | #7 | |
Rep 6,238
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
05-19-2017, 09:15 AM | #8 |
Rep 536
Drives: 2013 335xi Alpine White
I agree with tturedraider - doublecheck that the dealer installed the right glass. You can find the part number for your VIN at realoem.com. My opinion is that they did not use the right part since your HUD was working normally before. I'm finding that getting good techs at the dealership is difficult. My car was in for service 4 times in a row to fix the sticking door lock issue, which is an easy replacement of the actuator...but whatevs
With regards to your electrical issues. Did they occur after you brought in your car for service? To replace the fuel pump, your rear seats need to be removed. It's possible that a harness was pinched or damaged when that service was done. There are way too many systems affected for this to be fuses or relays and nothing runs under the car for these systems that could be damaged by hitting something like road debris - well, unless you hit something like a boulder...but I'm sure you would have noticed that. |
otay826.00 |
05-19-2017, 10:45 AM | #9 |
Rep 47
Is there a part number on the glass? I was told there should be "HUD" etched in somewhere. I couldn't find it when I had the vehicle.
Thanks for the reply, madmonkey. That helps to know about the fuel pump service. This electrical issue happened 10 days later. Could be related... |
05-19-2017, 01:16 PM | #10 | |
Rep 536
BMW Pilkington 43R-001622.....................I'm guessing a serial or part# AS1M1246-2DOT682.........DOT registration # for complaince |
05-19-2017, 07:52 PM | #11 | ||
Rep 740
05-19-2017, 09:45 PM | #13 | |
Rep 740
Auto high beams is a different sensor. |
05-26-2017, 09:20 PM | #14 |
Rep 47
Hey guys, update and good news. I have my car back
As a technician, I was super worried they'd be all up in my cars business and I'm very happy they were not. I received a call this afternoon suprised to hear my car was ready for delivery. Previously I was told a part was on order, three weeks away. So I can be ahppy I have my car back but still unsure if this was Factory defect or dealer fuck up. Puchasing extended warranty The correction: Scanned vehicle found puma measure for REM failure followed measure: unplugged reset and performed battery reset on REM REM awoke and due to production date no further repairs needed. All systems now operational. HUD is working 100% - Replaced rain sensor. I hope this helps for future diagnosis. |
05-27-2017, 11:24 PM | #16 |
Rep 838
Yep, REM is responsible for the lighting and window functions for the rear half of the car. That's why you saw the front half of the car working properly
05-28-2017, 01:02 PM | #17 | |
Rep 10,256
Tags |
electrical issues, indicators, trunk boot, windshield |
