05-02-2017, 08:32 AM | #1 |
Rep 1,772
Remote Radiator on 340i
Long story short car went in for a fog light swap and looks like dealer has replaced the fog light grill on the left hand side with a solid piece behind it.
The original piece was open. I'm guessing due to the remote radiator sitting behind it. I'm getting quite annoyed at having to go back to the dealer to have them fix their mistakes multiple times. So my question is can I just leave it like that or will that cause problems with cooling? Picture below to show which grill I mean. On another note I looked at realoem and it seems like there is a remote radiator on each side where the fog lights are. Is this correct? The right hand side grill though is blocked off from factory. |
05-02-2017, 12:52 PM | #3 |
Rep 2,387
I don't know about fog lights cuz I don't have them, but both grills are open in front of the remote radiators on my 340. Kind of makes sense, right? I wouldn't let that slide. They should correct this for you.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
05-02-2017, 11:04 PM | #4 |
Rep 1,772
Does anyone know how to remove the grills? By looking at the diagrams it appears to be clipped on so pull that out and then remove the backing plate behind?
Any DIY with pictures would be very helpful. I note all the cars (340i) in Australia have the right hand side grill blocked off. But if there is also a radiator behind there why is it blocked off from factory? |
05-03-2017, 12:13 AM | #6 |
Rep 1,772
I ran my car a little bit more aggressively today and the temperature is maybe 10 deg Celsius hotter than normal. Not full out just holding gears longer and revving higher to 5-6k.
Now running at 110 deg C or 230 deg F If I'm not tracking my car is it worth getting it fixed? Maybe just deal with it when service due in 12k km. So with the additional radiators but no airflow would the radiators be doing anything or would it now be as if there was no radiator there? |
05-03-2017, 01:23 AM | #7 | |
Rep 698
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake.:.H&R Sport.:.
Blubaron791433.00 |
05-03-2017, 03:18 AM | #8 | ||
Rep 1,772
05-03-2017, 12:46 PM | #9 | ||
Rep 3,622
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
05-03-2017, 08:14 PM | #10 | |||
Rep 1,772
05-03-2017, 09:00 PM | #11 | ||||
Rep 3,622
05-03-2017, 09:02 PM | #12 | ||||
Rep 3,622
05-03-2017, 09:10 PM | #13 | |||||
Rep 1,772
I'm guessing it makes little difference unless you are going to track your car. |
05-03-2017, 09:42 PM | #14 | ||||||
Rep 3,622
05-03-2017, 11:51 PM | #15 |
Rep 1,772
Well time to eat humble pie. My dealer had a look and to my surprise there is NO remote radiator on either side.
I looked at realoem again in detail and this is what I understand - up to feb 2016 all 340i with autos come with 2 remote radiators - from march 2016 you get one or both depending on trim level - from July 2016 no remote radiators! It appears that there is less coolant hoses and much simpler pipe work the newer the car. Last edited by x5mad; 05-04-2017 at 05:31 AM.. |
05-04-2017, 10:37 AM | #16 | |
Rep 698
05-05-2017, 02:22 AM | #17 |
Rep 14,115
Drives: G82 M4C X-Drive
I wan under the impression that the track handling package has the radiators. Does that mean that even those 340i after July 2016 with Track Handling don't have extra cooling?
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
05-05-2017, 06:49 PM | #18 |
Rep 206
Just guessing here, but maybe it's due to the new B58 engine as there is no longer an intercooler sitting in front of the main radiator, allowing it to operate more efficiently. Not sure about the oil radiator though - was this put in front of the main radiator where the intercooler used to be?
05-05-2017, 06:54 PM | #19 | |
Rep 2,387
The oil cooler is in the back of the engine with the oil filter.
05-05-2017, 07:58 PM | #20 |
Rep 206
08-22-2019, 07:32 AM | #21 |
BMW CCA Member # 561737
Rep 2
Drives: 2018 340xi M Sport
Looking at the dates on these posts, I know I'm just a bit late to the party but maybe someone here is still interested in this topic. I have a 2018 340xi M Sport. I have an aux. radiator behind the passenger side fog light. The driver side grill is blocked. Does anyone know what this radiator is used for? The intercooler radiator is in the center, The oil cooler is located with the oil filter. Is this a transmission cooler? thanks all
08-22-2019, 09:52 AM | #22 |
Rep 16,079
According to this it's a 'remote radiator', part of the cooling system.
https://www.realoem.com/bmw/enUS/par...MW-340iX&mg=17 Also known as the external radiator, according to this: https://www.newtis.info/tisv2/a/en/f...rts/1VnZ7ixG8l |
