05-01-2017, 07:47 PM | #1 |
Rep 108
Another N20 failure...
Add my fiance's daily driven 2012 F30 328i to the list. Car went into limp mode, no CEL or anything...slowed to a crawl and a low oil pressure light came on and a knock. Shut it down and towed it to a shop, but it was too late - bad rod knock around 2k rpm. Pulled filter to find a TON of metal particles. We think the last oil service neglected to change the filter because this thing is plugged up. Was at about 10k miles after the oil change, FYI. Two bad rod bearings and one overheated/warped conrod. We don't believe the low oil pressure was the cause, rather the symptom of the metal particles f#@$@ng up the oil pump. Car is about 6 months out of CPO and still just 46xxx miles on it. This is my fourth BMW, and second to have rod bearing issues. I'm done with BMW. Too many catastrophic issues on too many engine platforms. Might as well spend a little extra and get a Porsche.
05-01-2017, 08:34 PM | #3 |
Rep 536
Drives: 2013 335xi Alpine White
What interval were you using for oil changes?
05-01-2017, 08:36 PM | #4 |
Rep 5,089
There is a lot of metal particles. Even if the filter had been changed, the engine failure might have still occurred. What is the cause of so much metal in the oil?
05-01-2017, 08:46 PM | #6 | |
Rep 108
Regardless, this is clearly a case of super premature bearing wear, and there likely is something that caused it (e.g., blocked journal oil passage being most likely). |
05-01-2017, 08:47 PM | #7 |
Rep 108
05-01-2017, 09:32 PM | #9 |
Rep 108
Called and asked them, and they said they would need the car to be taken and diagnosed by their staff before they would even consider discussing goodwill. That would mean paying them to drop the subframe, re-verify, and then tell me they aren't going to help. From my S65 experience, I'm not willing to take that risk. I found an N20 out of a 2014 528i on eBay with 15k miles about 150 miles from me, so I bought it and will swap that into the car.
05-01-2017, 09:48 PM | #10 |
Rep 3,406
Sorry to hear about your bad experiences. You seem to be a really knowledgeable guy about cars so you probably know that the other German auto makers, including Porsche has had their share of premature engine failure problems. You can spend a little money and get a Porsche but that doesn't ensure you of anything except getting a great ride and higher monthly payments. After doing a bit more research it turns out that other brands like Hyundai and Dodge have class action suits against them for premature engine failures. So, just leaving German brands does not help either.
I'm not suggesting you stay with BMW. If you're fed up, you're fed up. Just know that the grass is not always greener. A possible consideration, whatever brand you buy is to sell it before its out of warranty or get an extended warranty. My personal experience is exactly the opposite. I've been driving BMWs since 1988 and they've been in the family since 1972. Never once have we had an engine issue on any of them. We are lucky I know. My turns coming! Good luck with the N20 engine swap. All the best. |
05-01-2017, 09:53 PM | #11 | |
Rep 5,089
Portadown9556.00 |
05-01-2017, 10:33 PM | #12 | |
Rep 108
As far as Porsche, that was a bit tongue in cheek. Despite my S65 woes, I loved the car. Last edited by acslater; 05-10-2017 at 06:10 PM.. |
05-01-2017, 11:09 PM | #13 |
Rep 689
sorry to hear this news. I can not believe that BMW expects their customers to accept that the engine could die at 46k miles and we should be happy and just buy another one. I would get a lawyer and push BMWNA to pay for a new engine warranty or not. BMW is not ethical saying NO to fix a MANUFACTURER DEFECT at such a young life of 46k miles. I just can't believe it. Makes me so mad.
05-02-2017, 12:29 AM | #14 | |
Rep 5,089
My worry is that what if this happens without mod nor track? Will BMWNA good will the repair or not? It feels as if BMWAG engine design these days are spec'ed for leases that won't go above 50k miles or something. E.g. the N20 timing chain issue, even if very rare, is still somewhat worrisome, how can BMWAG keep messing up basic bread and butter engine tech?!? This is very discouraging. Mine is a N26 SULEV, hopefully those are built tough enough to last 15 years and 150k miles per warranty. |
05-02-2017, 04:01 AM | #15 |
2JZ-GTE
3038
Rep 3,992
Ouch.
05-02-2017, 07:44 AM | #17 |
Rep 1,342
Arrggh, that really does suck. N20 looks to be about $4k? Plus the labor...even if you can do it yourself, it's a crap ton of work. I think I'd press BMWNA a bit more, tell them they have to pay for the diagnosis. Engine failure at 46k miles is total BS.
Good luck! |
05-02-2017, 07:55 AM | #18 |
Rep 1,659
Drives: 2022 WRX World Rally Blue
There's always a Mercedes. Maybe an AMG C63.
Rick
05-02-2017, 08:32 AM | #19 |
Rep 108
Luckily for the S65 I had it checked before a failure because everyone was talking about the bearings being problematic. Had them replaced for <$3k (again, mainly labor...) and the car was totally fine.
I was able to talk the guy into selling the motor for $3k, but yea it's in no way a DIY job. Front sub-frame has to come out with the engine in it, you HAVE to have a lift to do it economically. Labor per BMW is 16 hours, but realistically its more like 20. All-in, should be around $6-7k so I'm thankful that the motor is such low mileage, I can pretend that I'm buying back some of the depreciation on the car. |
05-02-2017, 08:40 AM | #20 |
Captain Crunch
168
Rep 548
Only 46k miles? What a load of shit. It sounds like the N20 engine is a problematic engine unless you have the new chain design, after January 2015 I think. Sorry to hear about your troubles OP.
On Order (in transit): BMW iX 50, Oxide Grey
Retired: BMW Welt Delivery 4/14/16: European Delivery - 2016 340i EBII/Saddle - ZMP | ZCW | ZDA | ZLP | ZTP | M Adaptive | Rear Shades | MPPSK Before and After Dyno Retired: 2011 335D Space Grey/Black - ZSP | ZPP | ZCW | 6FL | Sat Radio | Nav | $600 Base Audio Upgrade |
05-02-2017, 09:50 AM | #21 | |
Rep 108
In the interest of mitigating any bias I'm showing, my E36 M3 was the most reliable car I have ever owned, and I loved both the E90 M3 and the 228i M-Sport; I feel particularly bad about this situation because I helped my fiance pick the car and I assured her they WERE reliable. I also ended up selling my 228i to my own mother because she loved the car so much! I will likely buy her an extended warranty when hers goes out in late 2018. |
sygazelle11366.50 |
05-02-2017, 10:00 AM | #22 | |
Rep 3,947
I've found that sometimes the price for the extended warranty is different depending on who you talk to at the dealership. At the dealership that I bought my extended warranty, the finance department would mark it up. The service department, however, was selling the warranty at invoice. |
