04-21-2017, 08:27 AM | #1 |
Rep 302
How important is upgrading your Charge Pipe?
How important is upgrading your charge pipe? I heard a few folks who disregarded and still has their stock ones on and others who upgraded their charge pipe fairly quickly.
Thoughts? |
04-21-2017, 08:33 AM | #2 |
Rep 252
Is your car stock? When I had my 435 I was running jb stage 1 and intake for 2.5 years and had 0 issues with my CP. If you plan to run higher boost I would change the CP.
04-21-2017, 08:53 AM | #3 |
Rep 4,983
Stock, no. Stage 1, highly recommended. Stage 2 and above, absolutely.
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
Fade_The_Public48.00 |
04-21-2017, 09:23 AM | #4 | |
Rep 191
Drives: 2013 BMW 335i M-Sport
I I don't think additional boost has anything to do with the breakage as stock cars are breaking them. My theory is it's a hard piece of plastic that heat cycles allot in it's lifetime and becomes brittle. I also think the constant shake of the motor turning on/off when the car is in ASS mode adds to it. I base this theory on where mine broke, at the top.
2013 335i M-Sport 8spA
2011 M-B GLK350 2000 Dodge Ram 2500 QC 4x4 CTD Last edited by fhlh; 04-21-2017 at 09:26 AM.. Reason: adding |
04-21-2017, 09:30 AM | #5 |
Rep 302
Appreciate everyone's response! Yes, my car is stock except for an intake which shouldn't have an impact. Car has 30k miles and is still under warranty. Just trying to assess if an aftermarket charge pipe is still needed even if the car is stock with no additional boost.
04-21-2017, 09:59 AM | #6 |
2020 Z4 M40i - 2022 M4C Convt
3127
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
If it does not blow off or break stay stock. If you have issues with it get an alloy one. Mine was stock on the 335is till 18.5PSI & it blew off twice. Got a BMS piece as a replacement.
135IS & 435 have stock pipes.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
04-21-2017, 10:03 AM | #7 | |
Rep 302
04-21-2017, 10:15 AM | #8 |
3127
Rep 5,264
Car runs but no boost feels like ECO mode. Will not leave you stranded. If it pops off & you don't lose the clip you can put it back on yourself.
Stock 335 most likely under 10PSI max.
Kevin
04-21-2017, 10:29 AM | #9 | |
Rep 302
04-21-2017, 10:50 AM | #10 |
Rep 5,776
You may get a CEL and limp but might not. You will hear a loud pop and then the RPM's will climb but the power will be really low. If you are not going to raise boost and still under warranty I would not get one.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
06-06-2017, 10:14 AM | #11 |
Rep 84
Mine broke around the lip at 50K miles... totally stock. It's a crappy plastic part. I had to pull over and duct tape it to hold it in place. Driving in limp mode now until I get the aftermarket part ordered. I would replace the dang thing no later than 50k mi on stock cars.
06-06-2017, 10:20 AM | #12 |
Rep 5,997
I have the stock charge pipe no issues so far. I drive pretty spirited and so far no issues, will see in 50K, I do have 100k warranty so it would be covered.
06-06-2017, 10:36 AM | #13 |
Rep 2,957
It's not about being covered, it's about breaking down on the side of the highway as you're on your way to work or picking your kid up from school. I know you can still drive if it blows but I wouldn't risk shards of plastic being sucked into my engine.
2015 335i Msport/6 JB4/EWG/E30/VRSF DP/ER CP/ VRSF Race Exhaust/ Injen Intake/Verde Axis 19x8.5/9.5 245/35/275/30 Conti Extreme CS/ H&R Sports / Motorsport Hardware Stud Conversion
Bluebeasty77.00 |
06-06-2017, 11:15 AM | #14 |
Rep 955
+1.
Its not really about being stuck as with no boost you will still be able to drive the car... But my main concern would be if / when it blows pieces of plastic being sucked into the motor. I upgraded mine as im JB4 Stage 2. My understanding is that as soon as you throw any tune on the car you get a CP right away. Usually the same day as the tune as all the plug and play tunes really do is alter the boost. I ran my JB4 for 2 weeks on Map 1 as I had a bit of a wait for the CP to come in. If you are stock treat it as any other part of the motor. It will eventually fail, could be 100k miles though. That being said, its one of the weaker parts of the motor. BTW: I am surprised that the MPPSK OEM tune BMW sells does not include an upgraded CP. Seeing as its rewriting the DME and all, its probably alot closer to Bestmod / the real tunes (eg: remove DME and ship it over to the tuning company) as in, does more then just raise the boost so maybe BMW decided the stock CP was sufficient. Anyone know what kind of max boost a stock f30 n55 + mppsk pushes? Probably quite a bit lower then the JB4 maps? |
06-06-2017, 08:16 PM | #15 |
BimmerPost Supporting Vendor
24190
Rep 190,805
If your car is tuned, i strongly recommend upgrading the charge pipe.
Some dont and have not had any issues, that being said its not worth the risk and hassle.
06-07-2017, 12:03 AM | #17 |
24190
Rep 190,805
So far no issues with the B58
06-07-2017, 11:38 AM | #18 | ||
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
I don't think it should be as bad of a problem on a B58 engine as the air-to-water intercooler is also mounted on the engine itself (intake). Theoretically this would mean less movement or dislodging of the pipe over time to expose a weak point. Only time will tell if the material they used is strong enough to handle the boost over many kms - doubt anyone would know that except for the engineers at BMW. But I suspect they would have made is stronger vs. older engines with the additional boost, though (I read 20% more somewhere IIRC).
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
03-18-2020, 06:52 AM | #19 |
Rep 919
Drives: F30 328d Sport Line
Are the diesels susceptible to the failing charge pipe? 328d here with 48k miles and just a Dinantronics Sport Tuner for the last 1k miles. Probably won't do too many additional performance mods, possibly a KermaTDI tune in the future.
