04-17-2017, 07:33 AM | #1 |
Rep 138
340i Tire Question - Continental ContiSport Contact
This is a weird one; bear with me.
I recently took off my winter wheels/tires and put on my factory set. 18" Style 400 wheels, Continental ContiSport Contact RFTs. Immediately noticed how much rougher they rode. Chalked that up to the harder compound and semi-cooler temps. However, there's a sweet spot around 35-45 mph where I've been getting some harmonic roughness; seemingly from the front drivers side corner. It's not quite like a steering wheel shake when a tire is out of balance, more like a steady 'humm- humm-humm-humm' that can be felt in the pedals. Seems to smooth out at highway speeds. So the dealer did me a favor and balanced the set, said they were a little out of balance which was weird since this set of tires has less than ~3000mi on them. Anyway, the problem wasn't solved, despite confirming that the tires were balanced, round, no flat spots, etc. Just visually inspecting the tires I noticed the tread seemed to be backwards on the drivers side. I checked the sidewall, sure enough they all say "outside" and do not have a directional arrow on them. This is the odd part, since they are not symmetrical. Basically, relative to rotation, the drivers side and passengers side have different slanted directional tread (highlited by the pink lines below). In person the slant is more pronounced, but the pink hash lines show what I am talking about. Also, the first picture below shows the tread is raised on the drivers side tire - as if it is fighting the direction of travel. These peaks can be felt if you run your hand over it. So here's where my question comes in. Other 340i owners with these tires: Are yours the same way? Do they make passenger side and drivers side tread patterns, yet only have markings for Outside/Inside of the tire and not directional arrows? Do these tires just suck? The factory already shipped this car with the incorrect rear end, I would not be surprised if they put 4 passenger side tires on the car as well... Last edited by gkmunch; 04-17-2017 at 07:42 AM.. |
04-17-2017, 07:39 AM | #2 |
Rep 718
I have the exact same issue with the exact same tires on my 328i. Planning on ditching the run flats and getting an alignment soon with hopes I have better luck.
Mine: 2019 Mini Cooper S / Moonwalk Grey / Black Interior
Wife's: 2018 X2 XDrive 28i / MSport X / Mediterrean Blue / Mocha Dakota Leather Previous: 2008 E92; 2014 F30; 2016 F30 M Sport; 2011 E82 (Man I miss the 1er!) |
04-17-2017, 07:53 AM | #3 |
Rep 4,318
looks like feathering. caused by improper toe, caster or camber, combination of.
also sounds like the onset of cupping Last edited by alohasurftoad; 04-17-2017 at 07:58 AM.. |
04-17-2017, 08:21 AM | #4 |
Rep 15,858
Heel and toe (saw tooth) tread wear. Quite common on many tire types, not particularly a Continental tire issue.
Can be geometry, (needs checking) but also can be made worse by incorrect tire pressures. Setting pressure is often too low and the shoulder tread blocks distort more as tires rotate, causing the heel and toe wear pattern. One way to wear the tire shoulder more evenly, is to swap wheels "side for side" and wear the tread blocks in the other direction. Will change the harmonics, as the wear changes its pattern towards the opposite direction. |
BMW11279.00 |
04-17-2017, 08:27 AM | #5 |
Rep 15,858
04-17-2017, 08:33 AM | #6 |
Rep 138
Thanks for the feedback! At least the tread pattern is normal, and they do not make driver/passenger side tires in this model. (I didn't think so, since there are no rotational arrows). It was just so strange to me that relative to rotation, there are differences (even as slight as they are) between sides. It's good to eliminate variables though...
If anything, I err on the side of a bit higher tire pressures. I'll have the alignment checked, and probably swap "side for side" to at least even it out. |
04-17-2017, 08:42 AM | #7 | |
Rep 15,858
04-17-2017, 08:46 AM | #8 | |
Rep 138
04-17-2017, 09:47 AM | #9 |
2020 Z4 M40i - 2022 M4C Convt
3127
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Try getting some white liquid shoe polish & paint some stripes across the tread & slightly up the side wall.
Do a hard run & check the polish line. Middle gone but outside still there too much air in the tire. Outside gone but middle still there not enough air. Line continuous but shoulder part gone the tires are rolling under when you turn need a bit more air but not enough to bow the middle out. Also could indicate poor alignment. That is the hardest one for a quick & dirt check to solve.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
