F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Oil temps all over the place
GetBMWParts
      04-13-2017, 07:58 PM   #1
2000Z3M
Drives: 2016 435i ZHP
19000 miles will bounce between this and 250. I run in sport 99% of the time. Any ideas? oil level is good
      04-13-2017, 08:23 PM   #2
AGONXF30
AGONXF30's Avatar
Drives: 2012 335i S-Line/Melbourne Red
It is good that it is all over the place. That means it's an actual gauge giving you an actual reading. When I am in comfort it does not get even close to 250 on cooler days. One warmer days it might be close. As soon as I go to sport+ it hangs around 250 if I push the car. If not, then it does not get too close to 250.
      04-13-2017, 08:48 PM   #3
nedmon
Drives: 1998 528i
Maybe the thermostat is going South and causing the oil temperature variation.
I just got a notice from BMW that the warranty on the thermostat has been extended to 100k on my 2013 CPO 328i.
There must have been problems with the stat to generate this advisory.
Nedmon
2015 535ix
2016 X3
      04-13-2017, 08:53 PM   #4
chiefneil
Drives: 2014 335i M-Sport
Working as intended. The engine runs cooler under heavier loads for performance, warmer under lighter loads for efficiency.
BMWZ41909.50
      04-13-2017, 10:48 PM   #5
2000Z3M
this just started last week
      04-14-2017, 12:02 AM   #6
chiefneil
See post #13. If you're going over 240 I'd be concerned. I'm pretty sure mine's never gone above ~230 even on days when the weather's over 115F.
http://f30.bimmerpost.com/forums/sho...emp+n55+engine
      04-14-2017, 10:42 AM   #7
paul e
Drives: 340i xDrive 6MT
Mine rises from cold and then stays put. I think you need to call in to your SA, maybe the sensor is shot/going bad.
      04-14-2017, 10:57 AM   #8
STR8-6IX
Drives: RWD 528i N52
oil temps become slightly less stable when you have a couple thousand miles on your oil change. it begins to degrade.
if you are worried about oil temps, remove your plastic engine cover + insulation and use 5w40 oil. the goal is to keep temps below 250 under all conditions. i do this and it works well for me.
f30post
