04-10-2017, 11:26 AM | #1 |
Rep 48
Jack pads need for a quick-lift jack?
As I understand you need Jack pads adapters if you're using a car Jack to raise the vehicle.
When I see the vehicles raised by the 2 post lifts there doesn't seem to be an adapter. I have a quick-jack and I'm not sure if I should get these pad adapters. Here is a link to what I have. https://www.quickjack.com/ Thanks in advance! |
04-10-2017, 12:52 PM | #2 |
Rep 16,086
There's no place under the car to place a lifting device other than where the pads go, and if you don't put the pads into the lift points they're easily damaged. It's an odd arrangement but it's what we have to deal with. There are four lift points, so with your rig you'd need four pads.
04-10-2017, 02:08 PM | #3 |
Rep 1,056
Do they use the pads in the dealership lifts?
04-10-2017, 05:02 PM | #4 |
Rep 165
Cut some out of hard wood. Work great, been using them for a decade or so.
IndotagSwizz524.50 |
04-10-2017, 10:12 PM | #5 |
Rep 2,387
Ok first off you can use the center jacking point just near the front axle. Also you can place a jack under the diff, just make sure to avoid the cover plate and jack only in the diff. Lastly, I've been placing a jack without jack pads for years with no trouble. The problem with jack pads is that they're a PITA. They don't say in the jack pad insert so I find them difficult to use.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
04-11-2017, 01:44 PM | #6 |
Rep 48
As Hollandog asked about if the dealer using pads. I don't remeber seeing pads at the dealer or another other place that has raised a bmw on a 4 point 2 post lift.
I don't have a problem buying or making the pad adapters but would prefer not to if I don't have to. |
04-11-2017, 05:32 PM | #8 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
Wife's X3 looks like pads weren't used and it crushed the plastic...ugly as hell now when/if you look for it..
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
04-11-2017, 05:52 PM | #9 |
Rep 456
I own and use a QuickJack as well. Get the pad adapters as they will make using your QuickJack safe and easy. You can order them on eBay for a decent price.
04-11-2017, 11:33 PM | #11 |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
When your quickjack lifts the car, does it make contact to all 4 points roughly the same time? If it does then I don't think you'll need the pads.
Reason I say this is if it starts lifting one corner earlier than another corner, you're putting stress on that plastic piece where the jack point is as there's uneven loading. You'll need the pads (all 4) in the case it's not lifting all the points evenly/at the same time.
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
04-12-2017, 12:25 AM | #12 |
Rep 48
I was going to make them out of hockey pucks as madmonkey has mentioned. Thanks zcspec for adding, which model did you go with? I have the 5000 model. Really don't want to crush those jack points. Thanks everyone!
04-12-2017, 04:35 PM | #13 |
Rep 153
$9 each: Slotted Polyurethane Jack Pad
04-13-2017, 08:53 AM | #16 | |
Rep 536
Drives: 2013 335xi Alpine White
Buy a bucket of pucks to share with friends!! |
04-13-2017, 09:35 AM | #17 |
Rep 1,232
+1 did this because I needed them to lift my car and didn't feel like waiting 2-3 days and paying for something that took 10mins to make...to be honest the first entire year of ownership I lifted them up without it and never had an issue, I just kept reading about people having messed them up and just wanted to be safe
04-13-2017, 10:01 AM | #18 |
Rep 1,055
I must be missing something here - why would a hockey puck help by itself compared to a bare jack? I'd only see a benefit if the jack has a very small pad like in madmonkey's picture.
In the Soobahru's case, he's still lifting with a flat surface at the edges of the plastic jack point... the whole point of the jack pad is to evenly distribute the load - it's using the additional surface area within the rectangular cavity, especially if the car isn't completely level to the ground.
04-13-2017, 11:04 AM | #21 | |
Rep 1,329
Commercial lifts often have flat feet that seem to work ok, so garages don't always need to use pads. Hockey pucks sit in or on the floor jack foot and spread the load pretty good. Inserts put the load inside the cars liftpad which I guess is ideal, plus can't slip off, but sort of overkill probably. I have the ECS aluminum insert, but I wouldn't buy 4 of them probably, plus they might be a PITA to align properly when lifting by yourself. 1 insert on a floor jack is enough hassle for me.
2002 325i sport - sold 2009 135i M sport - sold
2009 550i M sport - sold 2005 M3 6MT Jet Black w/Cinnamon 2016 F30 320i ZSP 2003 E46 325it ZSP 5MT |
04-13-2017, 11:17 AM | #22 |
Rep 16,086
+1. Wood discs work fine, because they're softer than the plastic that the lift points are made out of, so the wood gets damaged, the plastic doesn't. The only problem with wood is they only last for a couple of uses.
