M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > sport mode default
      03-27-2017, 01:19 PM   #1
MerlinPurple
MerlinPurple's Avatar
Drives: M2 LBB
Arrow sport mode default
Gents,
I thought I'd share a quick vid on a solution I've been working on for the past few months...
Note that I have one hand on the camera, other on steering wheel and no one else in the car (no buttons other than start pressed)
It's taken a lot of effort to get this far, nearly there just need to iron out some things and then I'll explain all in detail soon.
Hope you like!
///Mē282.50
BFLY78.50
bollinm25.00
Moris3.00
      03-27-2017, 06:21 PM   #2
PiK
PiK's Avatar
Poland
61
Drives: M2 6MT
Share the magic
      03-27-2017, 08:31 PM   #3
///Mē
///Mē's Avatar
Drives: 2017 BMW M2 6MT
2017 BMW M2  [0.00]
Originally Posted by MerlinPurple View Post
Gents,
Pretty cool!! Please explain the process, coding involved?
'17 BMW M2 LBB 6MT MPE
'13 BMW 335i Estoril Blue - sold
      03-28-2017, 07:00 AM   #4
MerlinPurple
Drives: M2 LBB
Sure thing!
Well, first off this isn't a coding option - it's hardware.
This coding option remains illusive and has been searched for by a lot of BMW F series owners over the years.
Given the "importance" of such a flag (coding switch) you'd expect it to be discovered by now...if it exists.
Don't get me wrong, it would be possible to enter sport mode by default if the engineers at BMW exposed such a flag to do so.
The 'Enable Eco-Pro as default' flag
While it's true this 'eco' flag exists, it does so for a good reason. BMW 'Efficient Dynamics' models use this flag to maximise their environmental ratings.
It likely makes sense at the factory to have such a flag available when configuring the car as an ED model.
Furthermore, you would expect a similar 'sport default' option to be found near this flag location, but it hasn't.
The reasoning for the lack of such a flag is unclear and when combined with the lack of M memory buttons (on the M2) makes it frustrating.
So I decided to do something about it...
Hardware Solution
I work as a software engineer by trade.
I have built an external module with a microprocessor that interfaces with the Integrated Chassis Management (ICM).
The ICM is responsible for configuring various systems in the car to match the intended profile (eg, comfort, sport etc).
It's packed full of sensors, a crucial part in any modern BMW.
The ICM uses a range of technologies for communication, including FlexRay.
Using my own custom firmware, when you start the car the external module instructs the ICM to set the desired mode (eg. SPORT).
Note that the ICM maintains full control and authority at all times over it's subsystems.
The module will not override it, it only makes requests.
Possible Configurations
Default Drive to SPORT: TESTED - OK
Default Drive to SPORT+: TESTED - OK
Default DSC to MDM: NOT TESTED Edit: 03-04-17: TESTED - OK
Default DSC to OFF: NOT TESTED Edit: 03-04-17: TESTED - OK
I intend to make the module configurable so that you can set custom drive and DSC modes. I will be testing the DSC defaults shortly.
Installation
No one likes tapping/splicing into their OEM wires. I've spent many hours trying to come up with a streamlined clean install.
The setup includes a custom made harness that sits in-line between the drive mode switch panel and the OEM cable. This is the most convenient route to the ICM.
Any taps will be taken from the custom harness. This also means un-installation is a breeze since you just remove the custom harness.
The module, once placed in an enclosure will likely sit inside the armrest and use the 5V USB for power.
I see no reason why the install could not be done in under 20 minutes.
Developments
I need to test the DSC modes and then downsize my prototype to fit into a smaller enclosure. Later if there is enough community interest we could look at a mini-group buy to build some units.
I shall continue to update you all with pictures and videos as development progresses.
Thanks for reading
///Mē282.50
banff151.50
mjsaville101.00
metrickid3030.00
bollinm25.00
Moris3.00
      03-28-2017, 12:46 PM   #5
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
Maybe its because my M2 is not a DD but is it really that big of an inconvenience to press a button every time we get into the car?
DrKevM52272.00
ried791.50
Aronis2270.00
      03-28-2017, 01:04 PM   #6
MerlinPurple
Drives: M2 LBB
I know what you mean, this isn't for everyone.
Definitely aimed at the daily driver in mind - many prefer the throttle response of sport mode for their daily driving.
Coming from an E46 M3 (with sport memory coded) it feels like a step backward to have to configure the car to your liking each and every time you get into the car if you use it everyday.
Dabozo624.50
bollinm25.00
      03-28-2017, 03:29 PM   #7
David1
David1's Avatar
Drives: 09 E92 09 X5
Yup, but its still cool.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
Aronis2270.00
      03-29-2017, 12:47 PM   #8
AngryBaby
Drives: Works
Subscribed. Let us know how things go, Merlin.
      04-01-2017, 12:39 PM   #9
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
With DCT better comfort as default because you will want to keep rpm low at cold start by early shift.
Lemania 2320
      04-01-2017, 01:01 PM   #10
zenmaster
Drives: '17 M2
Exactly. Would be good if your Sport or Sport + choice kicked in automatically when oil temp was optimal.
      04-03-2017, 01:32 AM   #11
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Any vehicles with BDC_Body can remember shutdown mode. Great you found hardware solution for those that also want option.
      04-03-2017, 04:19 PM   #12
MerlinPurple
Drives: M2 LBB
Well yes you would want to keep the revs low on a cold start - It's habit for me to manual shift when I'm in sport. This is from my E46M days when I had sport on by default and 'always' used manual mode because SMG Auto was awful.
Having sport mode kick in when oil temp is optimal is a nice idea but flawed. Oil temp would require a tap into the CAN or OBD2 port - my main goal is to keep this project simple with minimum wiring. Besides, to have a car shift into sport automatically would be dangerous if you were already in motion (bend, drive thru etc).
Thanks Almaretto, I have read many of your posts over at bimmerfest and 2addicts, very helpful!
So I did some research earlier today on the BDC_Body module. If my understanding is correct it can remember ECO, COMFORT and SPORT modes?
I'm struggling to understand which models have the BDC_Body module, the only model I keep seeing is the F15 (X5?) ... and some of those threads go as far back as 2014.
I could understand if the new 'G' generation were the only ones with BDC, but not sure why the F15 gets it and rest F2x, F8x, etc after 2014 do not?
Is it fair to say a modern BMW will either have 'FEM_BODY + REM_BODY OR BDC_BODY' ?
      04-03-2017, 04:20 PM   #13
MerlinPurple
Drives: M2 LBB
Well my first prototype (MCOM) is finished, here are some vids.
Here I test SPORT, SPORT+ and DSC MDM:
+ You'll see a large breadboard that houses components.
+ The prototype is being powered from the USB socket in the armrest.
Here I test DSC OFF
+ DSC OFF didn't work at first, I had some bugs in the code - no one is perfect
+ Managed to solve it, and was able to test it...
Debugging
+ Here I show debugging data coming through my macbook via usb serial.
+ About halfway through I'll switch on the ignition and you'll see more data come through.
+ Without this debugging tool I would be blind!
Going Forward
This was a fun project, I'd like to condense the prototype into into a small box that sits inside the armrest. This is what I'm currently focussing on now.
Thanks for reading!
metrickid3030.00
bollinm25.00
Moris3.00
      04-03-2017, 05:11 PM   #14
Almaretto
Almaretto's Avatar
2374
BDC_BODY vehicles:
  • CAFD_00017BE: X1 (F048), X5 & X6 (F15/F16/F85/F86), I3 & I8 (I001/I012)
    • This allows default driving mode (Choice of 8, but not all chassis support all like Sport or Edrive)
    • ICMQL (CAFD_000013D8) is only found in X5(M) & X6(M). Among other things, this ECU configures:
      • Supported Driving Modes
      • Remember Driving Mode (Choice of 4 = Mode 2, 4, 7, & 8) & Shutdown interval to remember
  • CAFD_000017BC / CAFD_000017BD / CAFD_00001DF7 / CAFD_00001DF8: Gxx-series
F001 (F001/F002/F003/F004/F007/RR04/RR05/RR06) + F010 (F006/F010/F011/F012/F013/F018) + F025/F026: CAS (CAFD_0000000F) + FRM (CAFD_0000106D)
FEM_BODY + REM = F020/F3x/F8x.
Not sure what the new F090 M5 will take, but my guess would be BDC_Body.
I need to post update through 3.61.1, but here is CAFD_ID's PDF.
      04-05-2017, 12:40 PM   #15
jimmy9980
BMW DRIVER ///M
jimmy9980's Avatar
Drives: BMW 2017 M2 07/16 Build
Is there a way to code this ? I thought there was't ? talking about F87 M2
BDC_BODY vehicles:
Current
Waiting 2022 G80 M3 AWD Comp Brooklyn Grey
2004 E46 M3 White
END OF LIFE = 2017 M2 07/16 Build, 2014 M5 05/14 Build, 2008 M3 ESS Supercharged, BMW 2003 M3, BMW 2001 325ci
      04-05-2017, 12:51 PM   #16
Almaretto
Almaretto's Avatar
2374
If car does not have BDC_Body (which F087 does not), then options are Comfort or EcoPro.
jimmy9980105.50
      04-05-2017, 12:53 PM   #17
jimmy9980
BMW DRIVER ///M
jimmy9980's Avatar
Ok thats what I figured
Current
2004 E46 M3 White
      12-11-2017, 12:35 PM   #18
bmw_fascinated
bmw_fascinated's Avatar
15
Drives: F22 228i
nice project, are there any updates?
What about a simple opto-coupler and 555 timers / cheap IC so that the electrical contact at the switch is closed for some milliseconds after the ignition is on for several seconds?
      01-02-2018, 04:18 PM   #19
bollinm
Old Guy
bollinm's Avatar
Drives: 2018 M2 LCI, 2019 X3
2018 M2 LCI  [10.00]
Update
Very interested in an update too.
Excellent work so far.
We appreciate you doing the R&D for this hardware fix.
      01-04-2018, 04:48 PM   #20
MagnusT
MagnusT's Avatar
Sweden
538
Drives: BMW M2
How are things progressing on this? Nice addon for the car!!!
bollinm25.00
      03-20-2020, 09:36 PM   #21
whoismorggan
Bimmer Nut + Software Dev
whoismorggan's Avatar
Drives: 2018 Audi S3 IE Stage 1
Interested! Any progress?
      03-21-2020, 06:03 AM   #22
MagnusT
MagnusT's Avatar
Sweden
538
Drives: BMW M2
I had a quick look at the drive mode panel and it looked like the switches were just connected straight to the cabling with no electronics whatsoever (par from pull up resistors). So it didn't look like there is any of the databuses available there. Now this is on my 2016 M2, I don't know if anything changed to the LCI or Comp.
Very interested to hear your feedback
m2
