XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 DIY (Do-It-Yourself) Discussions
Register FAQ Calendar Today's Posts
      03-24-2017, 11:44 PM   #1
b2schulte
Drives: bmw X1
turn signal burned housing again
Looking for some advice on an inexpensive fix. My right turn signal would intermittently work for awhile and then it stopped. I had BMW look at it, they replaced the turn signal bulb housing, (about $350). I had the same problem come back, and my SA says I need to change out the entire headlight assembly. Any thoughts on how to get the right front turn signal to work? My side view mirror and rear signal work fine, it is just the front right signal that won't work. My car is a 2013, Sdrive.
      03-25-2017, 01:39 AM   #2
vstolpner
Drives: 2019 F39 X2 m35i
If it's physical damage due to heat then you can go to LEDs. Though I would get it permanently fixed. It might be due to various wiring issues, etc.
      03-25-2017, 05:57 PM   #3
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
I know it's not a fix but you can code out the side markers while the headlights is on. That way the blinkers will be on minimum time only for turn signal. I doubt the dealer to perform that so you need to look for Carli app or computer coding setup.
      03-26-2017, 11:28 AM   #4
d1saster
Bulgaria
60
Deleted
xbimmers
