M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Full Screen backup camera ?
      02-21-2017, 08:54 AM   #1
Ceeto
Drives: 2017 F87 M2 & 2024 G87(soon)
When I first picked up the car and I shifted into reverse, the backup camera was full screen. I reset the iDrive a few weeks ago back to the factory default or whatever you want to call it. And now I only get a partial screen when backing up. And I can't figure out how to get it back to full screen.... anybody know? Do I have to code it?
P.S- I have double checked and it is not in split view.
      02-21-2017, 11:45 AM   #2
jimmy9980
BMW DRIVER ///M
jimmy9980's Avatar
Drives: BMW 2017 M2 07/16 Build
Did you turn off the widgets window? Click the idrive twice to right and turn off the widget window
Current
Waiting 2022 G80 M3 AWD Comp Brooklyn Grey
2004 E46 M3 White
END OF LIFE = 2017 M2 07/16 Build, 2014 M5 05/14 Build, 2008 M3 ESS Supercharged, BMW 2003 M3, BMW 2001 325ci
      02-21-2017, 12:01 PM   #3
gmzanatta
gmzanatta's Avatar
Drives: LBB 6MT M2 # 660/713
This
      02-21-2017, 08:20 PM   #4
Ceeto
Sorry if I'm being thick here - But do you mean that when I am in reverse and see the camera screen, then I should twist the knob twice to the right and I will get full screen? because I did that and nothing happened. Also, what is widgets?
Here's all that I see:
      02-21-2017, 08:53 PM   #5
HawaiiG80Green
Drives: 2017 M2
Interested in finding out how to put in full screen too
      02-21-2017, 10:54 PM   #6
Prodigy.
Prodigy.'s Avatar
Australia
698
Drives: ///M2
Me 3.
      02-22-2017, 08:19 AM   #7
MZWIE
Drives: M2
Looks like you selected "split screen"
      02-22-2017, 10:10 AM   #8
Ceeto
Nah, as i said in my first post it's not in split view.
      02-22-2017, 11:12 AM   #9
gmzanatta
gmzanatta's Avatar
Do you have ID4 or ID5?
I have ID4 and will mess around with it after work today and post instructions tonight.
      02-22-2017, 11:49 AM   #10
jimmy9980
BMW DRIVER ///M
jimmy9980's Avatar
thats how mine is too in ID5 and I tried in ID6 and its the same.
Current
2004 E46 M3 White
      02-22-2017, 01:56 PM   #11
Ceeto
Thanks. Mine is ID5 (Week 38 build)
      02-23-2017, 10:19 AM   #12
Ceeto
Check out the video here at 0:06 it shows the camera going into full screen.
This is what I am looking for. If anybody else knows how to get this working please let me know.
      03-05-2017, 01:23 PM   #13
M2Seb
Drives: M2
Do you have a camera button in the centre console? Try pressing that and see if it cycles through he different views on the idrive.
      03-09-2017, 07:20 PM   #14
Ceeto
I do not. Not sure if that makes a difference? I don't know. The strangest part is it used to be full screen. Don't know what happened. Willl keep searching
Does anyone else here get a fulll screen backup camera view on the screen?
      04-25-2018, 12:17 PM   #15
cornercase
Drives: LCI M2
From what screen do you turn off the widget window? I'm aware of a Split View screen when I use CarPlay, but not a widget window.
      04-25-2018, 12:18 PM   #16
cornercase
Drives: LCI M2
Any luck?
      04-25-2018, 12:55 PM   #17
Ceeto
No luck yet. Was going to ask dealer next time it goes in, but so far I haven’t
      04-26-2018, 12:04 AM   #18
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
I am also interested in how you get a full screen on an LCI M2. Nothing I have tried works.
I only get the images Ceeto showed.
      11-05-2018, 08:35 AM   #19
ATL1234
Drives: BMW 740 2018
Rear Camera Display only half screen
I had a similar problem with the rear camera display being full screen then all of a sudden only being half screen with the other half being the outline of the car as others have illustrated. The BMW Genius said"[B]The large rear view camera view can be achieved when in reverse and the camera button to the left of your gear lever is pressed. This will change the display from the smaller rear view camera and Park Distance Control sensors to the full screen. They said they tested on their car and it worked. But it did not work on my 740. I assume it is a software problem but wanted to see if anyone has an idea.
      11-09-2018, 01:15 PM   #20
x7289155
Drives: 2018 BMW M2
Try to click on the checked Marked P sign, that should shut off the backup sensors and changes your screen to fulll screen. I'm referring the photo you show above
2018 M2 6MT
      11-12-2018, 09:21 AM   #21
ATL1234
Thanks for the suggestion. I tried it and the camera still did not display in full screen. Thanks.
      11-12-2018, 10:54 AM   #22
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
I have a '17 and the rearview camera was never full screen, It's always been that shitty half view from day 1. I've tried changing every setting known to man, nothing changes it.
m2
