02-04-2017, 08:59 AM | #1 |
Rep 413
What engine mod next?
Hey guys you can see my mods in my sig line. I'm wondering what I can do next without adding a meth kit. I want to keep it just 93 octane. It looks like the only thing else out there to make more power is the pure stage 1 turbo?
Should I wait or is it worth 1500$ to get 20-30whp? I'm ok waiting just want to know if I'm missing anything. Doesn't seem like there is a ton of stuff out yet for B58
340i M Sport Track Package | JB4 | Dinan Exhaust | BMS intake | CG catted 5" DP | HR sport springs | WMI | Zito Zf01 |
02-04-2017, 11:52 AM | #2 |
Rep 312
I believe you will be heavily limited on fuelling even with pure stage 1 as you are limited on fuelling on stock turbo as well. To take the real advantage for your car as is meth would be the best option. Others can chime in on the gains of Pure stage 1 on pump gas.
2021 M5 Competition | Imola red
2020 Z4 M40i | Misano blue Pure850/PI/LPFP Gone: 2018 M550i xDrive | DME Tuning BEF / JB4 / BM3 / DPs | 10.95 @ 125 1/4 Mile Gone: 2014 335i xDrive | Bootmod3 Stage 2 93 Map | 12.2 @ 113 1/4 Mile |
02-04-2017, 02:23 PM | #4 |
Rep 413
Isn't cost and install/maintenance in meth pretty high? Also is it safe for the motor. We're talking relatively obviously there is always risks with modding
02-04-2017, 03:23 PM | #5 |
Rep 698
I mean theoretically the concept of meth cools the intake charge which reduces chances of detonation. While cooling it also gains power. So yea probably one of the most safe ways to add power on a turbo car. The m4 gts has a factory meth setup....
"Snow explains, “On a simple level, it’s intercooling and race gas combined. When you inject water and methanol into the intake stream, you cool the air as the liquids evaporate. When you get into the combustion chamber, it slows the flame, acting just like octane.” The kit costs like $600 plus cost of the throttle body plate if you want it. And if you've installed the bolt ons and JB4 yourself, you should be able to do this easily. I read someone else say they go through a 3 gallon tank once a month ish. 5 gallons of boost juice meth is like $40-50 Last edited by Thisisdudewhoru; 02-04-2017 at 03:34 PM.. |
02-04-2017, 03:30 PM | #6 |
Rep 698
For reference
Meth kit $600 https://www.n54tuning.com/bms-3-gall...-meth-kit.html Meth spacer $100 http://burgertuning.com/B58_methanol_spacer.html Boost juice 4gal/45$ shipped https://www.ebay.com/itm/191900217737 |
02-04-2017, 03:33 PM | #7 |
Rep 698
Also from my understanding, once you hook it up, put JB4 on the right map and set a couple parameters, the JB4 basically automatically controls it. From there on out, you just gotta top up the tank every now in then. Somebody step in if it's not as easy as I think it is.
02-04-2017, 03:34 PM | #8 | |
Rep 413
02-04-2017, 03:36 PM | #9 | |
Rep 698
Who put on your other mods? |
02-04-2017, 03:40 PM | #10 | ||
Rep 413
02-04-2017, 03:41 PM | #11 |
Rep 413
Also when I take it into dealer for maintenance are they going to freak? I mean Intake is one thing this is a whole other.
02-04-2017, 04:22 PM | #12 |
Rep 698
It's pretty basic install from looking at the directions.
The dealer on the other hand may or may not notice it. Could wrap all the lines in black tape or something lol. |
02-04-2017, 07:32 PM | #13 |
BimmerPost Supporting Vendor
24137
Rep 190,687
Honestly meth is the best option for you .. Another mod would be Pure turbos
02-04-2017, 08:05 PM | #14 |
Rep 698
Until they get the fuel unlocked I'll probably do meth myself. Have we even fully determined the limits of the stock turbo? Seeing as the stg 1 only currently jumps up 30whp. Imo it may be worth it to just wait til fuel is unlocked, Then just jump to whatever stage 2 will be depending on limits of the stocker vs the stg 1. All considering these motors hold as much as we think they will with closed deck and all. Honestly I'd be ecstatic with a very reliable 500whp car which is almost achieved already with the pure stg 1 and meth.
02-05-2017, 03:50 AM | #16 |
2JZ-GTE
3029
Rep 3,991
Agreed, meth or the turbo upgrade. That's pretty much it for this motor. If that's not enough, dump it and get an ///M.
02-05-2017, 12:40 PM | #17 |
Rep 401
As others have said. Fueling is the limitation...we haven't clearly identified the stock turbos limit yet. Until fueling is resolved upgrading the Turbo is a waste of money imo. Meth is the best option. Hopefully the fueling issue is resolved soon...
As for the Pure Stage 1....i don't love the option, for the money and the work involved for 20/30hp, I say wait until the offer something a bit more substantial that is worth it. A Turbo upgrade that could get us into the mid 500whp range with proper fueling is where I would deem a turbo upgrade worth it. For 30hp?? It's kind of bananas really...it's less than 10%, I say pass. |
02-05-2017, 05:40 PM | #18 |
Rep 316
02-05-2017, 06:48 PM | #19 |
Rep 413
0-60
Pretty happy just did 2, 0-60 runs. One with second gear launch and other with traditional first gear. Both about the same roughly ~ 4 seconds. I used a stop watch and started it right after hitting start in the video. Obviously not precise so no need to correct me. It's definitely faster than when I got it though!
02-06-2017, 11:47 AM | #21 |
Rep 498
Meth actually makes the engine run safer, the piston crowns run cooler, you have to worry less about getting bad gas, and the B58 motor has the most stout bottom end that BMW has offered in the N54, 55 and b58.
Meth will put you at about 450 wheel horsepower. Its HIGHLY doubtful that it will cause any problem in your car that would warrant a dealer visit thats related to the meth injection. It can be installed in your garage without a lift fairly easily and it is well supported by Terry and BMS. you basically install it and just make sure you keep the tank topped off. There are safeties built in to the JB4 so that even if you run the tank dry you won't hurt the motor. There is basically no reason not to do it in my opinion. I am doing mine once it gets warmer outside. |
02-06-2017, 02:06 PM | #22 |
4911
Rep 115,980
