F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > First problem with the 340i this morning at 14k miles
proTUNING Freaks
      01-14-2017, 08:53 AM   #1
mwh2009
mwh2009's Avatar
289
Drives: M2C
Low coolant warning. Took it in to top it off. Took a quart! Seems like a lot. Discovered the 2 sort-of-separate reservoirs. Not sure if they're completely separate or not?
The dude at the BMW service said that if you drain the big one, the little one will empty too, which i thought was either strange/wrong - why have two filler caps if they connect somewhere?
2021 M2C, HS / 6MT
2019 Mini Cooper S Hardtop 4 Door / 6MT
2022 Mini Countryman All4 JCW
No longer with me: 2018 Golf R, 2017 F80 M3, 2016 F30 340i xDrive
      01-14-2017, 10:18 AM   #2
Thus
Drives: 340i xDrive m perf & track pkg
I hit the same issue, but at ~8k miles. I filled up the big reservoir with BMW coolant and all was well.
mwh2009289.00
      01-14-2017, 05:46 PM   #3
CruzM3
CruzM3's Avatar
Drives: 2018 M3 "Velocity Edition"
It's common on the b58 to need coolant added sometime after purchase.
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s)
2017 340i w/ MPPSK & Many M Performance Parts (sold)
2016 328i (sold)
mwh2009289.00
Aberle74.00
      01-14-2017, 08:41 PM   #4
RedKloud
RedKloud's Avatar
736
Drives: BMW i4 M50
+1. Others have reported this issue too.
mwh2009289.00
      01-14-2017, 09:43 PM   #5
ErkanTR16
64-bit
ErkanTR16's Avatar
Drives: 2018 BMW 340i xDrive
There's a Thread on here about this. I've experienced this around 300 miles.
mwh2009289.00
      01-15-2017, 06:18 AM   #6
cmplaya
Drives: B58
i had this around 15K
mwh2009289.00
      01-15-2017, 01:11 PM   #7
kentgbr
Member
kentgbr's Avatar
Drives: 2016 340i Sedan
Got a low coolant warning at 12.5K miles after one year of driving, needed 2-3 cups to re-fill.
Present - 2016 340i, Alpine White, Black, M-sport, 6-spd, Track Handling, Tech pkgs
Past - 2011 E90 335i, Alpine White, Ivory, Sport, Premium, Steptronic
Past - 2008 E90 335i, Titanium Silver, Dakota Grey, ZSP, Steptronic, 6FL, Wagner FMIC, Bilstein B12 Pro-kit, M3 control arms, SS F/R brake lines
mwh2009289.00
      01-15-2017, 03:53 PM   #8
goj
goj's Avatar
Drives: 2016 EBII 340i 6-MT
I had this issue at 7700 miles. I have done numerous visual tests and now it looks like I am below the minimum marker in the tank again. I am at 13.6k mikes.
It looks like coolant is evaporating and drying out right below my coolant cap. I am on a business trip away from my car but when i get home i will snap a picture of it. BMW has done this before: a bad seal on the cap causes slow evaporation. Everyone reporting this seems to have an early production 340i. I'm thinking the batch of caps is bad. It makes no sense for an engine to burn coolant like this.
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04
Instagram: @brandons340i
      01-15-2017, 04:05 PM   #9
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
2 reservoirs
Larger one is for engine cooling system.
2nd smaller one is for water to air charge cooler integrated into intake manifold
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      01-15-2017, 10:32 PM   #10
kentgbr
Member
kentgbr's Avatar
I think you might be right, also saw signs of coolant evaporation around the cap. My 2011 N55 had a similar problem that was fixed with a replacement part.
      01-16-2017, 04:17 AM   #11
CruzM3
CruzM3's Avatar
I don't have an early production 340i. Mines was built in July 2017 and I have the same problem. I would be interested to know if the M140/240 guys have this issue also.
2016 328i (sold)
      01-18-2017, 10:18 PM   #12
SingleturboVert
Drives: E93 335i
Originally Posted by Bee Pee View Post
2 reservoirs
Good catch. What is the fluid comprised of for the A2W side?
      01-19-2017, 06:31 AM   #13
225
Drives: 340i
Same in the UK, mine was built march 16 and needed coolant at 6k miles.
      01-19-2017, 07:31 AM   #14
mwh2009
mwh2009's Avatar
289
Drives: M2C
2 reservoirs
It's the same coolant - the service guy at BMW topped off both reservoirs from the same jug
2021 M2C, HS / 6MT
      01-19-2017, 06:01 PM   #15
mookie45
mookie45's Avatar
770
Drives: 2017 AW 340i M-Sport
What are reasons why the car is "burning" so much coolant? I really hope there are no overheating issues
      01-19-2017, 11:01 PM   #16
kentgbr
Member
kentgbr's Avatar
I tracked my car at an all-day HPDE, seven 20min+ sessions. No signs of overheating and the oil temp didn't budge, unlike my previous N54 335I at the same track.
      01-20-2017, 06:32 AM   #17
CruzM3
CruzM3's Avatar
It's not burning coolant as what I been told by my dealer is that they just fill it up to the max level at the factory but that the system is not really all the way full until after some driving. Same as if you do a coolant flush on a car. After filling it up and driving for bit you usually have to add more coolant.
2016 328i (sold)
      01-20-2017, 08:43 AM   #18
mookie45
mookie45's Avatar
770
Ok that's good to know.
Hopefully that is the case. If not, possibly it is something as minor as goj stated about the bad seal on the cap.
      01-20-2017, 09:30 AM   #19
goj
goj's Avatar
My system was pressure tested and totally fine. No leaks. Therefore coolant is evaporating somehow. And the big cap looks to be the culprit.
      01-20-2017, 09:50 AM   #20
kern417
Cheapskate
4447
Drives: 2018 440i |2016 340i | 2010 X5
that's really not ok imo. if i do a coolant flush, it might take 2-3 thermostat cycles to get it topped off, and that's worst case scenario. 1000s of miles and some people having to do it twice indicates there is an issue, however minute it may be. i would not say that's typical or normal at all.
      01-22-2017, 01:26 AM   #21
pocky
Drives: E91
Happened to my 340i around 8-9k miles. Both tanks were bone dry.
mwh2009289.00
      01-24-2017, 06:58 PM   #22
Lionel_24k
340xi
Lionel_24k's Avatar
Drives: 2016 340xi mineral gray
refilled for a 3rd time at 12k miles
f30post
