F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Does the B58 440i have Active Sound?
Extreme Powerhouse
      01-13-2017, 08:03 PM   #1
stefan
stefan's Avatar
Drives: M2 Comp
Trying to solve a debate here. To my ears, there is definitely some ASD coming through the speakers. Some posters have referenced coding guides in N55 models mostly.
Does anyone have any proof or instructions to disable the ASD on B58 4 series cars?
///M Power
      01-13-2017, 09:24 PM   #2
JamRWS6
Drives: 2022 X3M Competition
Proof is connecting via Esys and seeing the module there. Your best bet is going to be checking with the F30 guys on disabling. I love the sound on my 340 and have no desire to change it so I haven't messed with it.
- 2022 X3M Comp
- 2021 X5 xDrive 40i
- 2018 F80 M3 (sold)
      01-14-2017, 12:57 PM   #3
stefan
stefan's Avatar
Drives: M2 Comp
^ Anyone done that yet?
///M Power
      01-14-2017, 01:09 PM   #4
Wires
Drives: 2016 340i xDrive
I checked esys on my 340, and it shows the ASD module, but it has no engine assigned to it.
So I have no idea if it's playing engine sounds.
      01-14-2017, 04:11 PM   #5
goj
goj's Avatar
Drives: 2016 EBII 340i 6-MT
Yes it does. At the same time I can't understand why people hate on it so much. Literally doesn't make the car any different with or without it
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04
Instagram: @brandons340i
      01-14-2017, 05:53 PM   #6
goj
goj's Avatar
      01-14-2017, 08:24 PM   #7
Wires
I love the sound my 340 has. Even if it's potentially 1/2 fake.
I have no complaints at all.
nozydog465.00
      01-14-2017, 08:27 PM   #8
RedKloud
RedKloud's Avatar
736
Drives: BMW i4 M50
The 340i definitely has ASD, and I have turned it off.
      01-15-2017, 03:24 AM   #9
jmg
jmg's Avatar
18705
Drives: G82 M4C X-Drive
2022 G82 M4C X-Drive  [9.85]
2018 F80 M3 CS  [9.87]
2019 i3 BEV  [0.00]
yes, the 340i has active sound, but I never turned it off. It's actually not that intrusive and annoying. The F8X active sound however... so annoying.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing
Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3
IG: Raging_G82
      01-17-2017, 03:03 PM   #10
335BOY
Drives: 2017 SQ5
I agree 100%. What is so terrible about it?
      01-17-2017, 03:06 PM   #11
insanecoder
Drives: 340isDrive
340 defn has it I would be surprised if 440 didn't.. no reason it'd be excluded
      01-17-2017, 06:11 PM   #12
nozydog
Driver
nozydog's Avatar
Drives: 2020 X2 M35i
Can you switch it off via the iDrive settings or can it only be done by coding?
      01-17-2017, 06:14 PM   #13
Maxdog
Maxdog's Avatar
49
Drives: 2014 335i xdriive msport
Are there no purists left?
      01-17-2017, 06:45 PM   #14
jmg
jmg's Avatar
18705
2019 i3 BEV  [0.00]
Coding only.
The 3/440i Active Sound sounds OK, but it gives a false sense of the car. If you are a purist who can hear an engine and tell what gear you are in and at what RPM, you want it off. Overrun is where it gets particularly overbearing and annoying.
Again, it isn't as intrusive in the F8X, but as soon as I coded mine off it was 100x better.
Plus, do you really want the equivalent of a bicycle with a playing card in the spokes on your $50k sports sedan?
IG: Raging_G82
otay826.00
      01-17-2017, 07:38 PM   #15
tlippold
Drives: 2014 330i Xdrive
Did this feature start with the 340? Did the prior 335 have it?
Zoks0.00
      01-17-2017, 07:56 PM   #16
ny325
Drives: Jet Black E90
I can't believe BMW, or any car manufacturer would have the exhaust note go through speakers.
Skyhigh1889.50
      01-18-2017, 02:34 AM   #17
nozydog
Driver
nozydog's Avatar
Originally Posted by jmg View Post
Coding only.
Anyone know if it is a simulation or the actual engine/exhaust note just amplified!? If it's the latter I won't be too bothered as I often open the windows in my Cayman so I can hear the exhaust note better! If, however, it is an artificial simulation then my question would be why? when the car has a great sounding engine & exhaust note anyway!! I also think it strange that the option to alter volume or even turn it off isn't available via the settings!
      01-18-2017, 03:56 AM   #18
jmg
jmg's Avatar
18705
2019 i3 BEV  [0.00]
Coding only.
From what I understand it is not just an amplification of your real engine sounds. It's entirely artificial. I have no idea why they would implement this. It's been a travesty since day 1 and BMW isn't the only one doing it. It also seems strange that the M3/4 have even MORE sound coming out of the speakers even while already sounding way more aggressive than the 3/4 series. In fact, even with the MPE installed on my M3, Active Sound is not disabled. Weird.
IG: Raging_G82
RoundelM31836.50
      01-18-2017, 06:45 AM   #19
nozydog
Driver
nozydog's Avatar
Does seem weird indeed, particularly as all the road tests I'm reading on the 340i say how wonderful it sounds.... are they describing the 'actual' sound from outside the car, or the simulated sound inside the car? I will be able to make up my own mind & comment further when I get mine!! Having said that I have seen some vids of it on the track and what the camera mic is picking up sounds pretty good to me.... so why the simulation?
      01-18-2017, 12:30 PM   #20
jmg
jmg's Avatar
18705
2019 i3 BEV  [0.00]
I have no idea. I will say again that ASD was less noticeable on my 340i than my M3 to the point where I wasn't even sure I had ASD at the time.
IG: Raging_G82
nozydog465.00
      01-22-2017, 11:03 AM   #21
Wires
It is odd. Porsche amplifies engine sounds and pipes it into the speakers, Ford uses a tube on their mustang to pipe sound into the cabin.
My 340 sounds great (even without the fake sound), so I'm confused as well. I think it's mainly used to fill in the overrun.
      01-22-2017, 12:36 PM   #22
nozydog
Driver
nozydog's Avatar
My Cayman doesn't have any sound piped in, but maybe that's because the engine is pretty much in the cabin!!
Beek707.00
f30post
