Go Back   7Post - 7 Series Forum > BMW 7-Series Forums > (F01) 7-series General Discussions
      04-14-2008, 07:03 AM   #1
mapezzul
Special Agent
mapezzul's Avatar
Drives: Depends on the day!
F01 7-series to get 8 speed automatic transmission.
In order to keep up with the Jones’ BMW has had to think a bit outside the box. Our sources indicate that the transmission BMW will utilize takes up the same amount of space as the current 6 speeds and will not use additional components. This has been made possible by a completely new transmission concept. We have learned that it utilizes four planetary gear sets and five transmission clutches. Two transmission clutches are unlocked per gear, thus resulting in greater efficiency and a higher overall transmission ratio.
It is touted as being smoother and will reduce fuel consumption by almost six percent; way to go Efficient Dynamics! Since it is the same size as the current 6 speeds, a larger hump or other invasions into the passenger cabin space is not necessary. The gear selector will also return to the console from its previous stalk location; a well welcomed change for many.- Bimmerfile (the original source)
There has been some new info obtained about the particulars of this transmission. Specifically it uses an new approach to autos in order to obtain higher efficiency in a package the same size as current 6 speeds. It will be used in all application, hybrid and x-drive further indicating the 7 will see these variants.
BMW explored other options but the 8 speed was the most efficient.
http://www.bimmerfile.com/2008/04/14...eed-automatic/
[SIGPIC][/SIGPIC]
      04-14-2008, 02:29 PM   #2
Year's_End
Year's_End's Avatar
Drives: 2020 Shelby GT350
8 speeds is definitely one too many. Six speeds are fine, and I guess a seventh gear could be used for cruising, but eight is just overkill.
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT
Current: '20 Shelby GT350|6MT
      04-14-2008, 02:32 PM   #3
KonigsTiger
Racying Dynamics
KonigsTiger's Avatar
118
Drives: E92M3 RS46 Club Sport, others
God I hope not, imagine all that shifting!
      04-14-2008, 02:42 PM   #4
mapezzul
Special Agent
mapezzul's Avatar
It is an auto and is going to be extremely smooth shifting. The 7 is not a performance model but a luxury car. The idea is to keep gas consumption down and ride quality up the transition between ratios will be smoother. I guess people just do not get it.
[SIGPIC][/SIGPIC]
      04-14-2008, 03:11 PM   #5
x5love
Drives: 08 E92 335i
What 7 series driver is really that intenresnted in shifting? You can't even shift in the current 7 unless you use the button paddles on the steering wheel which are a major hassle to use anyway...
The shorter wheel base 7 will get the X5 shifter (as the spy pics show) and I'm assuming the 6-gear trans, that will shift fine. But the longer wheel base 7 with the 8 speed isn't meant for sporty drivers.
As many reports indicate BMW is really going to differentiate the short wheel base and long wheel base 7--mostly through interior design and execution. One will be the sport 7, and the other the luxury 7.
E92 335i|Jet Black|Black Dakota|Alu|Step/paddles|ZPP|ZSP|6FL|Navi|Heated Seats|CA
      04-14-2008, 03:48 PM   #6
Year's_End
Year's_End's Avatar
I still think 8 is overkill. Unless it can solve the endless shifting for the proper gear problem (like in the Lexus LS), I would expect 7 to be just enough. Even if you're not shifting, the computer still has to sort out which gear to be in.
      04-14-2008, 04:28 PM   #7
Imola.ZHP
Imola.ZHP's Avatar
Drives: 2014 BMW i3 BEV EE
lol, here is an easy fix, don't buy an F01...
Problem Solved!
Wouldn't bother me though, uh, if I could afford one; however, if there were a manual option, it would be the first pick...
- 2014 CPO i01 BEV Electronaut Edition Capparis White Tera World, '17-
- 2015 CPO i01 BEV Laurel Grey Tera World, '17-
- 2015 i01 REx Laurel Grey Tera World, '15-'17
- 2003 CPO 330i ZHP Imola Red Build 03/03/03, '06-'15
      04-14-2008, 04:58 PM   #8
Dascamel
Dascamel's Avatar
48
Drives: 2008 e92 M3, 2010 e91 328i
Hmmm, imagine trying to rebuild the transmission.
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options
2007 Montego Blue 335i (retired)
      04-14-2008, 05:24 PM   #9
Bluesummer
Bluesummer's Avatar
Taiwan
588
Drives: slower than Ayrton Senna
2017 BMW X5M  [0.00]
2015 M4  [0.00]
2011 E82 135  [0.00]
2011 M3  [0.00]
2007 335  [0.00]
manufactures need to stop putting more gears than needed on new cars
IG:d.violet.m3
      04-14-2008, 08:41 PM   #10
Minimization
Minimization's Avatar
Drives: 2006 BMW M5 Sedan SMG III
People do not get it. In a perfect world, a transmission would have an infinite number of gears. The problem with this is the finite time it takes to shift between gears and the finite room in the housing that each gear takes up. As technology progresses more gears have become standard. CVT are trying to achieve infinite gear ratios but they are only currently available for low torque/rpm applications.
I remember when people were claiming that 6 speed manuals were overkill and 5 speed manuals were just fine. They were not, actually. My '86 Scirocco GTX 16V cruised at 4,000/min at 80 mi/hr in fifth. It could have used six or seven gears back then.
You have lots of gears to optimize acceleration and a couple of overdrive gears for minimal fuel consumption in the 60-100 mi/hr cruising range.
Sportiness is not necessarily lost with eight gears. The M5 has 7 in the SMG III now, it's very sporty, and could probably use an eighth gear. They could crowd the first seven together to enhance accelerations all the way to Vmax (not just for 0-60 mi/hr) while putting an eight gear in to replace the existing top gear for cruising. I think ideally a car should redline in top gear right at the speed where it gets drag-limited (Vmax).
2006 BMW M5 Sedan
SMG III
Silverstone Metallic/Black Perforated Merino/Aluminum,
X2/4MA/610/322/453/655/416/465/261/496
      04-14-2008, 08:41 PM   #11
Etnies
Etnies's Avatar
Drives: .
Hope it works...
      04-14-2008, 09:35 PM   #12
335destroyer
335destroyer's Avatar
Drives: black 335i
that'll be pretty cool, but doesnt the isf have 8 speed auto
      04-14-2008, 09:54 PM   #13
lux.sh
missing two turbos.
lux.sh's Avatar
Drives: fast around corners.
For those saying 8speed is overkill...
Im sure those smartass BMW engineers know way more than you do.
it did say "they explored other options, but 8spd was most efficient".
06 AW E90 330i ZPP/ZSP/Step/Expired Warranty
: Prior Design Front : ACS Rear : ACS Roof : BlackLines : Simota Intake : Carbon Fiber Interior Trim :
: MTEC V3 : 24% Charcoal : V1 Hardwired : Solaris Invisibulbs/LED interior :
      04-14-2008, 10:32 PM   #14
Year's_End
Year's_End's Avatar
Wow, I never doubted the "smartass" BMW engineers. I'm just sayin that the Lexus LS has troubles with the amount of gears it has, and that it's continuously sorting through them.
I'm not saying that that will dictate the future of this transmission.
      04-14-2008, 10:55 PM   #15
lux.sh
missing two turbos.
lux.sh's Avatar
yeah, I remember reading an article about 7spd tranny causing some trouble.
Im sure BMW is aware of such problem. lets see how they work it out.
      04-14-2008, 10:56 PM   #16
Year's_End
Year's_End's Avatar
The LS actually uses an 8spd.^
      04-14-2008, 11:03 PM   #17
ianbiz
Back in a BMW
ianbiz's Avatar
Drives: 2015 335i Msport
they need 10.
Ian
      04-14-2008, 11:07 PM   #18
BK
Smiling politely
Drives: 330i
2006 330i  [9.00]
I feel like 8 gears is too many, too. Although, I read a review of the DCT M3 that mentioned the author was cruising in 7th gear at 65 mph and was at... I don't know, maybe 3.5K RPM? Whatever it was, it seemed awfully high in the RPMs, even for an 8400 RPM car. Maybe an 8th gear would be worthwhile for saving gas on long highway trips.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
      04-14-2008, 11:08 PM   #19
lux.sh
missing two turbos.
lux.sh's Avatar
thank you for correcting. I went back into my bathroom where all my magazines are to confirm.
      04-14-2008, 11:18 PM   #20
Year's_End
Year's_End's Avatar
LOL^
      04-14-2008, 11:42 PM   #21
mapezzul
Special Agent
mapezzul's Avatar
You are correct in stating the LS, ISF has issues with "hunting" for gears. The Aisan sourced unit those cars use is just the same old transmission with a few extra gears.
BMW specifically did not want this issue to occur and that is why they have not had more than a 6 auto until well... this is released. The new design is more efficient and the shifting will be smoother and decisive, they would have it no other way.
The gearing will be specific to the car, as well as the programs.
[SIGPIC][/SIGPIC]
      04-15-2008, 12:33 AM   #22
jhv
jhv's Avatar
1695
Drives: G80 M3
...? yes.
7post
