12-04-2016, 06:01 PM | #1 |
Rep 36
minor crack paint crack
Hi Guys,
had an unfortunate situation happen about 2 weeks ago. My front bumper has a slight crack above the grill and the paint has chipped off. As winter is approaching my worry is that it may rust or get worse. Should I get the exposed area fixed before winter starts or am I fine to leave it till Spring |
12-04-2016, 06:24 PM | #2 |
Rep 3,622
It's really hard to tell the severity since the car is so dirty.
Did you buy the car used? That looks like it could be clear film peeling up
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
12-04-2016, 06:47 PM | #4 | |
Rep 36
Here is a better pic, there is also a slight crack to the right and left of the emblem. And yeah it has 16000km when I got it. A little bit of the paint definitely came off as there is a crack. Just worried about taking it through car washes in the winter as well, as the water pressure might take off more paint.. https://s17.postimg.org/7slvmb66n/IMG_7131.jpg |
12-04-2016, 06:58 PM | #5 |
Rep 470
Anytime you see exposed metal means you need to paint it asap otherwise rust will start. once Rust start it is pretty hard to stop it since the metal becomes porous.
12-04-2016, 07:11 PM | #6 | |
Gettin It Figured Out
1821
Rep 2,669
Touch up paint to "seal" the edges, may make you feel better....but ultimately, you're looking at a new bumper .
12-04-2016, 07:15 PM | #7 |
Rep 3,622
If it were me I'd have the bumper repainted an put clearfilm on it. This looks like the bumper was repainted due to a fender bender or other reason. Factory paint doesn't chip like that.
12-04-2016, 08:48 PM | #8 |
Rep 36
Ugh the place I got a quote from said the same thing that the bumper was damaged...dealer didn't mention anything and there was nothing on the car proof
12-04-2016, 10:06 PM | #9 |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
Is this your 428i? If so, that picture you've shared looks like it's right above the passenger side kidney grille... if so, you have nothing to worry about because it won't rust; that area is all plastic...
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
12-05-2016, 11:04 AM | #10 |
Rep 11,845
Drives: MY24 G01 AW Msport
i would get it fix, the paint will chip away due to weather conditions.
it will only get worse |
12-07-2016, 05:49 PM | #11 | |
Rep 36
Appreciate all the feedback from everyone, thank you |
