11-29-2016, 12:51 PM | #1 |
64-bit
598
Rep 814
Drives: 2018 BMW 340i xDrive
B58 Billet BMS Intake | MPG
Anyone that has the B58 Billet BMS Intake noticed any MPG gains? I've installed it last night and on my way to work, 30 Mile cruise in Comfort Mode noticed i'm getting 39.4 MPG lol.
Highest i've gotten before the install was around 32-34 MPG. |
11-29-2016, 02:34 PM | #2 |
The Wolf
247
Rep 987
Drives: stuff
probably because it skews the maf which in turn skews the mpg calculation
-2019 BMW m850i convertible
-2021 Dodge Charger Hellcat Redeye Widebody |
11-29-2016, 07:34 PM | #6 |
The Wolf
247
Rep 987
Drives: stuff
11-30-2016, 01:58 PM | #7 |
Cheapskate
4450
Rep 4,993
miles/gallons = change in odometer/change in fuel level
maf may impact the instantaneous mpg calculation (but more likely using something like throttle position and injector timing/pressure) but it doesn't make sense to calculate the long term from maf readings. understand now? |
11-30-2016, 02:00 PM | #8 |
The Wolf
247
Rep 987
Drives: stuff
yeah that's not how it works at all, try again lol.
11-30-2016, 07:45 PM | #10 |
BimmerPost Supporting Vendor
24193
Rep 190,805
I highly doubt the intake will get you another 9mpg but it would be awesome if it did
ErkanTR16598.00 |
12-01-2016, 08:17 AM | #11 |
Cheapskate
4450
Rep 4,993
ok, so explain how it works? how does the car knows your mpg goes to infinity when you're rolling to a stop in gear if the maf readings are the same as idle? how does it know that a maf reading in 1st gear is getting less mpg than the same maf reading in 6th gear? how do cars without a maf calculate mpg?
12-01-2016, 08:26 AM | #12 |
Cheapskate
4450
Rep 4,993
you know what, i see where the disconnect is so i'll just stop it right here. I'm guessing you're talking about the actual mpg the car is getting vs the mpg readout on the cluster.
I'm *assuming* the OP is referring to the mpg reading on the cluster since he mentioned such a high number and cars are known for being generous with their calculation. Plus he is referencing a 30 mile stretch of highway vs his last fillup. i agree the maf will affect actual mpg whether it's the wrong size or dirty or whatever. but intakes are known for giving a 1-2 mpg bump (when you can stay out of the throttle) |
ErkanTR16598.00 |
12-01-2016, 08:28 AM | #13 | |
The Wolf
247
Rep 987
Drives: stuff
12-01-2016, 08:54 PM | #15 |
The Wolf
247
Rep 987
Drives: stuff
12-02-2016, 05:01 AM | #16 |
Rep 369
Maf or a map+intake temp are input sensors. Dme bases its calculations on the information gathered from the input sensors + engine load to achieve the desired power output by the consumer (you pressuring the gas pedal). So whatever sensor you have on the vehicle (map/maf) the air volume and air temp is the single most important input of which all calculations are based off of including mpg.
12-05-2016, 11:15 PM | #18 |
64-bit
598
Rep 814
12-06-2016, 04:54 PM | #19 |
Rep 140
Same here, it sounds amazing.
2016 340ix M Sport /// Mineral Grey Metallic /// AWE Exhaust & Midpipe /// BMS Intake & OCC /// JB4
12-06-2016, 05:34 PM | #20 |
64-bit
598
Rep 814
12-06-2016, 07:10 PM | #21 |
Rep 369
Bms intake was my first mod, and it was worth the $$ for sure. Love the in cabin sound.
Pair that with a downpipe and tune and you're golden. Or just leave the intake on and enjoy |
12-06-2016, 07:14 PM | #22 |
Rep 418
I need this in my life!!!
///MPPSK///MP FRONT SPLITTER///MP KIDNEY GRILLS///CF MIRRORS///CF SPOILER///CF TIPS///HUPER OPTIK 20%///NBT///AC SCHNITZER///M4 437M///ZMP///ZTR///iND///
