11-15-2016, 06:22 AM | #1 |
Rep 2,856
Drives: BMW M2 CSL Turbomeister
Winter storage - Do's and Dont's
Guys,
My M2 is not going to drive much during the winter. I am not putting it on winter wheels, but instead I am buying a MINI GP2 on winter tires. New project car.... Question now is what to do and what not to do when it comes to storing your car for the winter. Any input is welcome. My intention is to take it out (if the weather allows) once every one or two weeks and take it for a short spin around the block. Additionally, I want to get those holders that protect your wheels from becoming square. I also have a car cover to protect it when it is parked inside the garage. What else should I do? Lower tire pressures? Where can I get the best anti square wheel holders? Any suggestions? (or whatever these things are called ) MR |
11-15-2016, 06:24 AM | #2 |
Rep 27
Dont drive the GP when it snows the underpan acts like a snowplow
CommitConfirm474.50 |
11-15-2016, 06:57 AM | #3 |
Rep 486
Based on your earlier pictures, I'm assuming garage.
Do the following:
If you do take it for a spin, make sure you let everything get up to operating temperature before you store it away again. But if you do have the chance to drive it every week, you'll be fine. I basically only drive mine weekly (wife and I carpool to work) and never have issues. |
11-15-2016, 07:36 AM | #4 | |
Rep 790
Any recommendations on fuel stabilizers? Battery tenders? Also, is there a risk of the interior dessicants drying out the leather too much? I am in Canada so likely don't need dehumidification anyway, but am considering it. Maybe will go for it anyway and do some leather treatment just prior to storage. I have read that the flat spots are not much of an issue on radials with low profiles. I usually just move my car a quarter turn every few weeks through the winter, and have not noticed much bumpiness in the spring. Jacks seems kind of over the top given this. |
11-15-2016, 07:46 AM | #5 | |
Rep 2,948
I've never had issue with the leather drying out when keeping silica inside - I usually would keep a few packets up front and a few in the trunk, always in a Tupperware dish since you do not want those beads spilling everywhere. Keep in mind the M2 leather is also coated, so typical leather products don't work. As for the battery tender, I would recommend something that can do a jump as well, that way you have the best of both worlds in case you need it. Is it bigger and more cumbersome? Sure, but it can be a lifesaver. If you can rotate the wheels during storage, no need for jacks IMO. If you're going more than say a month without doing it, then I would recommend it. |
blackholescion272.50 |
11-15-2016, 08:18 AM | #7 |
Rep 3,005
Highly recommend using Sta-Bil or similar product. I had fresh gas in the lawnmower go stale in ~ 1 month this summer and it refused to start. Had to spray some carb cleaner to "jump" it.
11-15-2016, 08:21 AM | #8 |
Rep 709
I try to avoid taking my Lotus out when there's a risk of salt on the roads, even when the roads are dry. Otherwise you have to spray the underneath to get rid of it. Then it all freezes and the brakes lock.
2011 Lotus Elise SC, 2002 BMW 330d, 1990 Caterham Super 7 HPC (sold), 1985 Porsche 911 Carrera SC (sold), 1978 Caterham Super 7 (sold), 1972 Triumph TR6 (sold), 1972 Jensen Healey (sold), 1965 Triumph TR4A (sold)
11-15-2016, 08:50 AM | #9 |
Rep 2,924
Car cover: mostly for dust
Battery charger: any AGM compatible would do the job Fuel tank to max with fuel stabilizer Tire inflated to 45psi Oil/filter change in the spring to let sediment rest in the oil pan. No silicate required if the car is stored in a heated garage.
BMW ///M Club Montreal
BMW ///M Club Montreal Facebook Page |
MarkR26221.50 ParlorBoss19.50 |
11-15-2016, 04:20 PM | #10 |
Rep 2,856
Not sure mine is heated, but it never goes under zero in that place. It is often warmer in the garage than outside. Also people are driving in and out with cars and stuff. It is a massive place, not a single garage.
In the end, I learnt a lot from your comments. The car will have a service on 7th, and then I will try to drive it once a week minimum. Just through the city, around 14:00/15:00 in the afternoon when the temperatures are above zero and that is about it. I still need to go to my accountant once a month and my medical specialist, so I can use it for that. For the rest it will not leave my place, and so far I have only taken it out when the weather was brilliant so it is already more than a month clean enough so that the cover can go on. So by looks of it now, if I keep it static up max 2 weeks it should not be too bad and I do not need to get things like stabilizers, these plates under the wheels, put it on jacks, hang it on a battery charger or fill up the tank. Although for the future and the summer period when I have two cars, I might think about getting a battery charger connected to the car in the garage, just in case that I am not home for three weeks or so and the car just stands around. MR |
hypermatic12.00 |
11-15-2016, 06:38 PM | #11 |
Rep 86
i have been storing cars in several climates (maine & florida) for a few years and have learned a few things.
up north no real need to put on jack stands, but do use flat stoppers if you are not using the jack stands. battery charger needs to be a 'smart' charger protect your car from rodents. i use dryer sheets in the engine compartment and passenger cabin. put mothballs on the garage floor as well as lots of mice traps. cover the ends of the exhaust pipes to mouse proof, i use AL foil. on this one i knew i was screwed when i first started a car after taking it out of storage and found mouse $hit about 2 feet behind the exhaust....for about 2 months when the exhaust got warm, it would smell like mouse piss..... down south, i found that you have to put your car on jack stands. at least when stored in a garage that is not climate controlled. the tires, especially these softer compounds will get flat spots that you will never fully get back out. i have never used stabilizer in cars that were stored for up to 8 months. i just fill them up prior to storage and have never had an issue. i do use it in small engines that don't get used (lawnmowers/generators). i wash/wax and dry prior to parking. and generally use a car cover.
2020 M5 ??????? next in stable??
2017 M2 (sold) 2016 991TTS Cab (sold) 1989 M491 Targa 1935 Ford Model 50 Pickup |
11-15-2016, 06:51 PM | #12 |
Rep 37
Battery charging
For an extended period of time I would recommend a battery tender over a trickle charger. The tender will maintain the proper float voltage and stop charging when it is reached. The trickle charger as the name implies will continually apply current to the battery with the possibility of damaging the battery by overcharging.
midwest 340xi 6sp359.50 |
11-15-2016, 07:28 PM | #13 |
Rep 549
Drives: The Bus
Garage List 2017 Ford Focus RS [0.00]
1971 Mk3 Austin Min ... [0.00] 2013 MINI R56 GP [0.00] 2013 MINI R55 Clubvan [0.00] |
Sorry dude can't add anything not already said other than lovin' the GP2 ideal. I just swapped to winters on my GP2 this weekend. You'll love it
11-16-2016, 12:24 PM | #15 |
Rep 36
Car cover
Full tank of gas Battery tender Max tire pressure Rodent proof NO fuel stabilizer NO engine start until it comes out of hibernation in the Spring |
11-16-2016, 02:57 PM | #16 | |
Rep 3,295
Dam mice get into cars that are just Stored overnight D'ooh. Had mice eat wires (oxygen sensor wires) and make nests in cars just sitting for a few days! People put Mint in the Cabin Air filter things to keep the mice out. Mint Tea bags are easiest, can't smell much in the car. I have the same problem with my lawn tractor and my larger front end loader/back hoe tractor. It's a pain. Dam rodents.
2018 M5 and 2019 Porsche Boxster GTS Prior. '94 325is, '97 M3 Lux, '16 M2 |
11-16-2016, 03:45 PM | #17 | |
Rep 571
I actually really miss mine. The Gp2 is best enjoyed on a dry day, in my opinion.. |
11-16-2016, 09:39 PM | #18 | |
Rep 230
11-17-2016, 05:11 AM | #19 |
Rep 86
i haven't had any rodent problems in FL and have never protected for it there.
11-17-2016, 05:42 AM | #20 | |
Rep 581
11-17-2016, 06:30 AM | #21 | |
Rep 790
Fortunately, my garage is quite new and hopefully mostly rodent free for now. But I will be blocking the exhaust. |
12-06-2016, 06:02 PM | #22 |
Rep 790
Reviving this thread as I have a related question... and winter is upon us.
I seem to be finding mixed (i.e. opposing) advice/opinions on whether you should start your car periodically when stored. Some say yeah. Others say (including some in this thread) no way. I would appreciate further comment on this specific question. I know that if you start it is very important to let it run until up all the way to operating temp - so that you don't leave condensation to settle in various spots. But I am still not clear on the bigger - to run, or not to run - question. Thoughts? |
