Pre-LCI M3 rep front duct?
11-11-2016, 12:50 PM | #1 |
Rep 1,076
Just installed this used M3 rep front bumper yesterday. Bought it from a guy who had already cut out the brackets for the fog lights. It was already painted and I like the foglight-less look. Anyone install ducts so it doesn't look so hollow inside. BTW, I ended up zip-tying the original fogs out of the way. No errors as a result.
11-15-2016, 11:08 AM | #5 |
Rep 347
I've never taken any close up pics but i have some on my car, i got them off of ebay, they were direct fit. They funnel down into an opening on the other end for brake cooling, I hate they way fog lights look on the m3 rep too...
11-16-2016, 09:02 AM | #7 |
Rep 1,681
My OEM undertray bolts up to the M3 rep.
I run ducts designed for the rep. Got them on eBay but the seller is no longer there. If you message sellers of the bumper, they often will sell the ducts separately. Advantage of running the rep ducts is there isn't any cutting required like OEM and they line up with the brake cooling duct in the fender liner. |
11-17-2016, 12:57 PM | #8 |
Rep 2,084
The OEM undertray does bolt to the M3 rep but it's not great. The bottom of the bumper got kind of warped because of it, but you can't really see it.
My rep came with ducts. The driver side fit will with only a little cutting rerquired to get it to mate with the hold in the wheel well. Passenger side was tricky because I have the OEM oil cooler. The duct that came with the bumper doesn't work with this at all. I cut the duct it to physically fit but the duct only feeds air to maybe 5% of the cooler area. I got an OEM M3 duct and while it's not a direct bolt in and also requires cutting, it does a better job at directing air into the cooler. I have not installed it yet. I believe these are the ducts that came with my rep: http://www.ebay.com/itm/Air-Intake-D...ZYEHlX&vxp=mtr
2013 135is DCT Carbon Black Metallic |
11-17-2016, 04:38 PM | #9 | |
Rep 1,076
11-18-2016, 06:36 PM | #10 | |
Rep 285
11-19-2016, 08:22 AM | #12 |
Rep 1,076
11-21-2016, 05:21 PM | #13 |
Rep 2,084
I taped up the fog connectors and zip tied them out of the way. You can code out the bulb check for the fog lights although I haven't done this yet.
