10-20-2016, 12:23 PM | #1 |
Rep 981
Meth kit
Kit has never been used but the pump, lines, FSB, and solenoid were in the car. Rest has never been installed, just sat for a year or so on my bench
Meth Kit includes" Tank FSB Pump Solenoid brass inline filter brass check valve wires and meth lines up to the engine. I need to see if I have a few more feet to complete the connections 2x CM5 nozzles 1x CM10 nozzle 1x nozzle mount (was going to tap the post IC chargepipe) 1x Y if you want to go with the standard chargepipe connection low level sensor 2x 90* nozzle holders 1x straight nozzle holder In short this should be everything you need to run meth either pre or post IC along with the additional safety blanket that the low level sensor provides. Asking 400 |
