2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) Driver Side Seatbelt Scraping Against Plastic...
      06-14-2016, 10:27 AM   #1
ajh77
Drives: 2010 328i coupe
So my driver side seatbelt has scraped along the plastic piece where it rests above when not being used. This scrape is similar to a shoe scuff mark on the door plastic
Has anyone else experienced this and if so, how did you remove the scrape ?
      06-14-2016, 08:20 PM   #2
BentZero
BentZero's Avatar
Drives: 6MT Mineral White M235i
If it's just a scuff try Mr Clean magic eraser. Then I'd just use some clear packing tape to protect the area.
I rev-match from neutral to first
6MT Mineral White on black M235i coupe
Build thread
      06-15-2016, 11:09 AM   #3
ajh77
Here is a pic, I know not that big of a deal, but I want to get rid of it if I can...
I am assuming its a scratch from the seatbelt metal on the plastic
(hit plastic too hard one day when I took off seatbelt when it flung back)
Will a magic eraser help or no ?
      06-15-2016, 04:58 PM   #4
BentZero
BentZero's Avatar
Scuffs yes, scratches doubtful. Only one way to find out. Even if it doesn't work you'll have one for home use at least.
Build thread
      06-15-2016, 05:38 PM   #5
ajh77
Thank you...do I just use hot water with the magic eraser to a cleaner like 1z cockpit premium or deep plastic cleaner ?
      06-16-2016, 08:16 AM   #6
BentZero
BentZero's Avatar
Pretty much. Just get it damp, squeeze out excess water and rub.
Build thread
      06-16-2016, 11:38 PM   #7
Taunto
Car Enthusiast
Taunto's Avatar
Drives: 2016 BMW M235 X-drive
is your seat belt twisted?
the Male end should be facing the inside - towards the seat.. usually u have the other half of the seat belt to help from this happening.. not always but for the most part
      06-27-2016, 01:49 AM   #8
Michael415
Drives: 2016 M235i Coupe
One suggestion instead of packing tape is to use some satin finish screen film protector typically used on phones/tablets. I found the satin/matte finish blends in a bit better on surfaces that are not glossy.
2addicts
