06-13-2016, 10:56 AM | #1 |
Rep 109
Enabling video in motion MY16
Hey guys I can't seem to find the SPEEDLOCK_X_KMH_MAX or MIN on my 2016 M235i. They both exist in a different module on the same ecu for I think navigation 3006 when I use the search function but its already set to not active and seems like it would only effect nav anyway. I found everything else needed to disable the different locks but this has my stumped.
Has something changed in the newer cars? Any help would be appreciated! Thanks! |
06-14-2016, 10:49 AM | #3 |
Rep 109
What do you mean? I have done quite a bit of other coding with no problems and everything else has worked fine. I also have tested video in motion and it works right up until I move a few mph and then stops.
06-14-2016, 10:56 AM | #4 | |
Rep 5,262
06-14-2016, 11:58 AM | #5 |
Rep 109
That's what I'm saying I can't find. It doesn't even seem to be there so I can change the values.
I already changed the handbrake/gearbox in P to none and the handbrake lock is set to not active Just simply can't find the SPEEDLOCK_X_KMH_MIN/MAX lines to edit. |
06-14-2016, 01:39 PM | #7 |
Rep 109
Man I can't find it for the life of me. Even if I use the search function neither one comes up except for in the 3006 Nav section so its not the correct ones I want.
I don't know where else to look! When I get home tonight I'll give it another shot Thanks for the reply guys |
06-14-2016, 04:26 PM | #8 | |
Rep 8,364
If you cannot find, feel free to PM me your *.ncd and I can take a look. |
06-20-2016, 11:04 AM | #9 |
Rep 109
Man I'm telling ya, I searched line by line down the whole thing and didn't find the speed lock lines. They only exist like I said in the NAV section but are already set to not active. I don't know where to go from here.
06-20-2016, 12:14 PM | #10 |
Rep 5,262
what values can you set for that ? what do you see on the right window where it shows comment and possible values?
06-20-2016, 03:10 PM | #12 | |
Rep 8,364
It sounds like you have HU_NBT_EVO, rather than HU_NBT. In HU_NBT, SPEEDLOCK_X_KMH_MIN is found in 3000 HMI, with some navigation parameters. In HU_NBT_EVO, SPEEDLOCK_X_KMH_MIN is found in 3006 Navigation (As shown). Either way, in those Function Data Lines (FDL's), there are three predetermined, drop-down values (nicht_aktiv, 8_kmh, and 3_kmh). Changing the werte value, will show parameter as UNKNOWN = FF. With that modification along with other parts of this multi-step coding, gives you Video in Motion. Last edited by Almaretto; 06-20-2016 at 06:08 PM.. |
06-20-2016, 06:46 PM | #13 | |
Rep 109
Yes its HU_NBT_EVO, and yes it's found in 3006 Navigation. I didn't know I was supposed to change the werte value as it already says not active so I didn't think much of it! When I get a chance to play with it again I'll give changing the value a try. Thanks so much for the help! |
06-20-2016, 06:54 PM | #14 | |
Rep 8,364
06-27-2016, 02:40 PM | #15 |
Rep 109
Ok, finally got it working yesterday. I changed the werte value to 1 first but that didn't work so I changed it to 99 and boom, works.
Thanks so much you guys for your help!! |
06-27-2016, 05:06 PM | #16 | |
Rep 8,364
07-04-2016, 08:57 PM | #17 | |
Rep 74
I have the same HU_NBT_EVO on my M235i 2016.I'm new to coding.So far I deleted the seat belt reminder.My question is,how do I change the Werte to FF?Thanks for any help. |
07-04-2016, 10:34 PM | #18 | |
Rep 8,364
08-03-2021, 09:21 AM | #19 |
Rep 11
Many Thanks
I have been coding on my 2017 330i and appreciate the utility of cheat codes created and shared by you.
I am still attempting to enable VIM, and missing something in either coding Werte values, or subsequent speedlock deactivation. Any additional insight will be greatly appreciated. |
08-05-2021, 10:35 AM | #20 | |
Rep 3,056
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
