F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > 340i JB4 warranty/dealership experiences?
ARMA SPEED
      06-08-2016, 05:50 PM   #1
Thus
Drives: 340i xDrive m perf & track pkg
I understand that many of you swap out your JB4 when taking your 340i to the dealer.
Have you heard any stories about the dealerships knowing about JB4 installs, even when they are removed, and causing warranty issues?
      06-08-2016, 06:06 PM   #2
Mike@N54Tuning.com
BimmerPost Supporting Vendor
Drives: 2007 335i, 2015 M3
Once removed the JB4 leaves no trace.
Mike
      06-08-2016, 06:18 PM   #3
insanecoder
Drives: 340isDrive
If I were BMW I'd track any anomalous outputs to the engine outside of norms ..
from their pov this is like overclocking a chip.. do at your own risk warranty no more
I dont see why they havent done that.. saves them money in the longrun y saving on warranty for guys who stress the engines
.. OR HAVE THEY ... da-dun.. (eyes back and forth)
      06-08-2016, 06:22 PM   #4
Mike@N54Tuning.com
The JB4 reports stock values to the ECU. The ECU never sees anything out of order.
Mike
      06-09-2016, 02:35 AM   #5
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
3002
Drives: 340 6MT, 50e, others
i think it lies to the ECU and the ECU doesn't know what it doesn't see.
      06-09-2016, 03:19 AM   #6
Eriphill
Eriphill's Avatar
2564
Drives: 340i
Bahahaha thanks professor
      06-13-2016, 10:31 PM   #7
Jrosh1223
Drives: BMW 340i xDrive/ BMW X5 35D
I heard that the JB4 leaves shadow codes on your ecu and a dealer can see these shadow codes even after the JB4 is removed.
      06-14-2016, 09:36 AM   #8
zinner
zinner's Avatar
559
Drives: `17 X5 35d/`15 335i/`18 M550IX
the jb4 is for the race course only. that should tell you all you need to know. read between the lines.
      06-14-2016, 09:43 AM   #9
G30 B58
Pace Car Driver
1547
Drives: '22 AW G30 B58 M-Sport
I heard the JB4 actually calls the dealership.
Appreciate 11
      06-14-2016, 10:23 AM   #10
goj
goj's Avatar
Drives: 2016 EBII 340i 6-MT
Don't know man, the only way to guarantee there will be no issues is to not do JB4. I have to say it's a compelling package but not worth it IMO.
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04
Instagram: @brandons340i
Polo088161602.50
      06-14-2016, 11:13 AM   #11
HitmanHearns
Drives: 14' Infiniti Q50 / 16' Audi A4
You literally made my morning. LMAO!
      06-14-2016, 12:36 PM   #12
Mike@N54Tuning.com
That is what the bluetooth addon is for
Mike
Sonic RR112.50
      06-14-2016, 01:53 PM   #13
jgoens
jgoens's Avatar
3788
Drives: 2013 335i msport
My car was at the dealer last week for brakes and oil change and they also did a full inspection for any codes, leaks or other warranty items. Left my jb4 in the car as well as DP. Put it on map 0 and hid the obd cable. They said everything looked great.
      06-14-2016, 03:16 PM   #14
soultraveler00
soultraveler00's Avatar
48
Drives: 2010 Bmw M5
Thanks for the info. Does map 0 take out the cel light from DP?
      06-14-2016, 03:43 PM   #15
Big Nodge
Drives: 340xi 6MT
I wouldn't take too much comfort from that, personally. They had no reason to hassle you over the JB4 in that scenario because everything was fine. If everything wasn't fine it might have gone down differently.
I'm not one of those rabidly anti-JB4 guys that exist on this board, but I strongly believe that you should go into this eyes wide open. You have to pay to play, so only go this route if you are financially prepared for the risk of having your warranty voided. This is coming from someone who has chipped multiple cars in the past, but is probably going to go the MPPSK route for my 340i because the engine is new.
      06-14-2016, 04:39 PM   #16
jgoens
jgoens's Avatar
3788
I don't think so, but I put it on 0 a block from the dealer--I have heard it takes a while to show.
I had a JB4 on my e90 and when the water pump went out I did remove it. I asked my SA a while back about mods and he said there would not be a problem with warranty unless the mod caused it. So, if my car has an issue relating to how it runs I will remove the JB4, but for things like brakes, oil change or water leak like I had two months ago I did not. Yeah, kind of lazy on my part, but there also is a law in place that does not allow them to not perform warranty work that is unrelated to a tune. Would I recommend removing a tune for any dealer visit? Yes, but I am giving my experience.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP
      06-15-2016, 08:58 AM   #17
mtx450
mtx450's Avatar
Drives: 2011 E90 M3 ZCP
2011 BMW M3  [0.00]
I know the catless DP will cause a CEL but the JB4 clears it automatically. The only outlying problem from that is the readiness monitors will never clear (meaning you will have issues getting an inspection, at least in my state of NY).
      06-15-2016, 09:59 AM   #18
RMNB
RMNB's Avatar
365
Drives: 2021 440xi CPE BSM
Funny you should ask. My car was at my dealership for a few days. I told them it was running funny (idling). Plus since my warranty was almost expired, had them do some maintenance items. My initial thinking was a coil or injector type issue like everyone else has had. I kept JB4 installed on Map 0,plus my Intake, CP and IC are clearly evident. Tech of course found it, ran some tests, uninstalled JB4, drove it and attributed the JB4 as the culprit. They cleared the faults, etc...long story short.... no big deal. Some SA and Techs are very cool about the JB4 as they all pretty much know about and can figure it out quickly. I guess the thing to know is if they can prove JB4 blew up your engine, turbo's etc. they will have to void the warranty. It has to be a major issue and they have to prove it without a shadow of a doubt. But there is Magnusson act, etc. people have mentioned. Most say uninstall before you go in which I would recommend if you don't have a cool SA and TECH.
      06-15-2016, 10:22 AM   #19
mtx450
mtx450's Avatar
2011 BMW M3  [0.00]
Was the JB4 defective? Have you reached out to Terry to try and figure out what was going on?
      06-15-2016, 10:24 AM   #20
RMNB
RMNB's Avatar
365
Not sure if the JB4 is defective but I will email Terry now...thanks!
      06-15-2016, 12:12 PM   #21
Mike@N54Tuning.com
My advice is never to take a modified vehicle to BMW period. Remove mods before going in. Takes like 15 min to remove a JB4 once you've done it before.
Mike
      06-15-2016, 12:31 PM   #22
soultraveler00
48
Drives: 2010 Bmw M5
Mike
That's the easy part but what do people do about their catless downpipe?
f30post
