M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > F10 M5 DIY Guides
      06-07-2016, 03:28 PM   #1
apexlocator
Drives: 2014 M5
Question Removing plastic covering of center mirror wires?
Does anyone have any tips or pics? I want to hardwire my V1 via the wiretap to the center mirror wires.
I hate removing plastic panels when I dont know how they're connected underneath.
Thanks.
ap
      06-08-2016, 03:55 AM   #2
boots
Curve Thrasher
boots's Avatar
623
Drives: 2013 Bmw m5..White/Blk.
Ill look at mine tomorrow. I have the same kit to install but diff radar. Then I need to find the proper wire to tap into
      06-09-2016, 12:51 AM   #3
isakhnov
Drives: f10 M5 CP - SG/AB
You simply need to pull it apart. There is a DIY somewhere on the forum, search for hardwiring instructions.
      06-09-2016, 07:14 AM   #4
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
Drives: 2013 BMW M5 | MSR Stage 3
From a DIY I used
Front Dome Light: You have to remove the black cover and you should see 4 holes. You need to use a small flathead and push the clips that's in the L shape holes. (might require a bit of force) And then you just have to pull the surrounding clips around the dome light.
*** SOLD *** 2013 BMW M5 | Space Grey | MSR Stage 3 Tune | Catless Downpipes | MSR Intake and Charge Pipes | MSR Exhaust (Prototype) | Vorsteiner Rear Diffuser | RW Carbon Front Lip | RW Carbon Trunk Spoiler| Vorsteiner VS-310 Forged Wheels | Escort 9500CI w/Laser Jammers
      06-09-2016, 05:39 PM   #5
apexlocator
Drives: 2014 M5
Thanks. This is true, how it attaches. You would have to push on the right half of the housing at the clip locations and then gently pry apart.
      08-06-2016, 12:45 PM   #6
e90alpinem3
Drives: F10 M5
You can use a credit card as well to separate the plastic housing. Anyone have issues with the mirror tap wires staying connected to the harness? I'm on my second one because I snapped the connecter pin the first time as I couldn't get it to stay in the harness next to the other wire.
m5post
