2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Code Seats To Move Back...
      06-06-2016, 07:58 PM   #1
ajh77
Drives: 2010 328i coupe
I am trying to code to get seat to move back when engine is off and forward again when I start car....
I have a 2016 M235i got 2 weeks ago.
When I was trying to code below, :
SM2 -> 3000 SM_GLOBAL -> EINAUSSTIEGSHILFE = Modus_FA_SLV
SM2 -> 3012 EAH -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 28
SM2-> 3012 EAH -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 3C
I don't have Modus_FA_SLV as an option to choose
      06-06-2016, 08:18 PM   #2
Kolyan2k
Drives: 2006 S2000
Modus_FA_SLV is one of the parameters when u click edit
2 other lines are not really necessary, it depends how far u want seat moved. I just used 1st line.
      06-06-2016, 08:18 PM   #3
tux2005
Drives: 2017 M2
Try the other SM2 tree, the Modus_FA_SLV option only existed in one of the two SM2 trees when I coded by 2014 over the past weekend.
      06-06-2016, 08:26 PM   #4
ajh77
What do I need to right click to edit so I can find the word Modus ?
I tried both trees, could not find it.
      06-06-2016, 09:20 PM   #5
Kolyan2k
Drives: 2006 S2000
right click or double click "nicht_activ" in SM2(d)
      06-06-2016, 09:29 PM   #6
ajh77
Ok...thank you I will try that and report back
      06-07-2016, 12:23 PM   #7
ajh77
It worked!! Thank you!
      06-27-2016, 09:55 AM   #8
Cjnj
Drives: 2016 228i xdrive
worked for me as well...only used first line
      06-27-2016, 11:37 AM   #9
BentZero
BentZero's Avatar
Drives: 6MT Mineral White M235i
Also keep in mind that if your driving position is too far back the default values won't work. There's a safety feature that won't let the chair go back too far.
That said, can someone translate what the movement settings are? I had to bump my driving position forward a tiny bit in order to get the defaults to work.
I rev-match from neutral to first
6MT Mineral White on black M235i coupe
Build thread
      06-27-2016, 12:33 PM   #10
Cjnj
From what I understand from some other posts around the forum:
SM2 -> 3012 EAH -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 28 [this is the amount in mm the seat moves back]
SM2-> 3012 EAH -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 3C [This is the amount in mm from the back stop it allows the seat to move back; to leave room for the rear passenger]
You'll probably have to increase the EAH_VERFAHRWEG_SLV_PHYS amount but also decrease the EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS value
***Someone else, that has changed these values, could confirm my suggestion as it is only a suggestion as it works on the default settings for me***
      06-30-2016, 05:52 PM   #11
Grentz
Grentz's Avatar
58
Drives: X5 40i G05
For me just changing:
Worked perfect. With only the first change it did not work in my normal driving position (further back, I have long legs).
Current
19' G05 X5 40i
03' e46 M3 Convert.
Past09' e90 335d, 11' E70 X5d, 16' F22 M235xi
      06-30-2016, 06:22 PM   #12
pz619
Drives: F87 M2C 6MT, Tesla 3
Out of curiosity, is it possible to code the side bolsters to open when the car is off and close up again when the car is on? I remember older bmws used to do this.
Mawaz0.00
      07-01-2016, 03:16 AM   #13
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Surprisingly, not all seat adjustments are saved to individual key profiles. I believe side bolsters is one of those that is not.
1more144.50
      07-06-2016, 11:01 AM   #14
isthar
Drives: M235i xDrive
Doesn't this feature make it a bit tricky to start the car? If you're too far back, holding the brake can get tricky...
//M235ix Alpine White
      07-06-2016, 11:25 AM   #15
Grentz
Grentz's Avatar
58
Drives: X5 40i G05
Not at all for me, you definitely feel further back but I can still reach all the controls fine. Its not THAT much of a difference.
Current
19' G05 X5 40i
03' e46 M3 Convert.
      07-06-2016, 02:54 PM   #16
BentZero
BentZero's Avatar
If you close the door and press the start button the seat will move forward. I always put my car into sport+ before I start the car, so it's just part of my "launch sequence".
      07-18-2016, 02:53 AM   #17
Almaretto
Almaretto's Avatar
2374
Not if you are 6'2" and you actually like to sit close with back vertical. There is more room for easy entry/exit, but then slides forward.
      12-21-2019, 11:50 PM   #18
kenhoteh
kenhoteh's Avatar
Macau
70
Drives: F30 M-Sport 320i
Smile
Hello all, anyone know the up and down seats setting coding how to do?
KenHo Macao S.A.R.
      12-22-2019, 09:39 PM   #19
bluesman8266
Drives: M240i
I've definitely got that problem. I have to hold on to the steering wheel and push the brake, which sometimes messes up the seat trying to move forward. I then have to push the side button to get it in my position. I know you can have it not go back so far but unless I see the exact steps for bimmercode.
2addicts
