XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 DIY (Do-It-Yourself) Discussions
Register FAQ Calendar Today's Posts
      06-02-2016, 07:40 AM   #1
themishmosh
Drives: BMW X1 xDrive35i
Carly connection
Just wondering if anyone has issues connecting the Carly wifi adapter to their iphone like I am.
Just seems like the wifi adapter sometimes wigs out and the app then times out. The adapter will have LEDs will be stuck on red, orange, rapid flashing, orange, blank when this happens.
Even the coding won't work because it says the connection is not good enough and strangely will suggest trying the original Carly wifi adapter. My 1st wifi adapter (Gen2) keeps freezing up and won't even connect most of the time. I bought another one and it is less flaky but also freezes up. Starting to think it's my car! The Carly people are no help and have not responded to my messages.
What are people doing to get a good connection? Special settings or procedures?
      06-02-2016, 08:06 AM   #2
m3_tristan
Be Original.
m3_tristan's Avatar
Drives: 2011 E90 M3
I have mine on all the default settings and it works just fine.
      06-02-2016, 08:12 AM   #3
themishmosh
Do you turn the car on or just ignition (double start presses)?
      06-02-2016, 09:27 AM   #4
m3_tristan
Be Original.
m3_tristan's Avatar
Drives: 2011 E90 M3
just the ignition, never code with the car on.
      06-02-2016, 10:04 AM   #5
themishmosh
Gotcha. Thanks!
      06-13-2016, 09:59 AM   #6
Mirko
Mirko's Avatar
Drives: E86 Z4M, E90 328i, E84 X1
I had issues the first time I tried to code as well. Was able to read from the car no problem but it wouldn't write anything regardless of what setting I had the ignition in. Tried a second time a few days ago and it worked flawlessly. I did email the programmers the issue I had and they asked me to log a session and send them but I didn't have to as it worked.
I have both the bluetooth dondle and cable. Worked fine with dondle second time.
08 M Coupe • Ceramic Black Fabspeed Headers • MCS 1WNR • Poly FCAB • Stoptech BBK • Vibra-Tech • Epic Tune • Apex EC7 • RPI Scoop • Eventuri • Stromung • Rogue X Pipe • Varis Diffuser • CF E92 GTS Wing • CF Roof
      06-13-2016, 10:46 AM   #7
vstolpner
Drives: 2019 F39 X2 m35i
Is there a difference between the Bluetooth dongle and the cable in terms of coding? Different coding options available? Faster write times?
      06-13-2016, 11:21 AM   #8
Mirko
Mirko's Avatar
The cable is faster. I also need to use the cable for my z4m as it won't respond to Bluetooth.
      06-25-2016, 05:12 PM   #9
Riche3
Riche3's Avatar
Drives: X Drive , Jet Black Shines
Carley wifi connection works fine in my car with just ignition on or with engine running
For just ignition on only - operate with coding features , use a battery charger
Also use the back up features before coding
      08-07-2016, 11:11 AM   #10
themishmosh
Finally solved my wifi dongle connection issues. Someone in another thread said to set JB4 to stock. It worked fine when I did that.
Even better, used the Carly wifi dongle with Carista app (similar to Carly except for VAG) to code setting on my wife's Q5.
      08-19-2016, 11:49 AM   #11
thestimp
Drives: 22 X3MC MBB - C-17 Globemaster
2022 X3mC  [10.00]
2016 BMW M3  [0.00]
When doing anything set JB4 to Zero.
xbimmers
