05-20-2016, 08:00 PM | #1 |
Rep 19
435i Trunk spring issue?
Hi guys, bought a used 435i and just realized the trunk isn't opening all the way...it pops up half way and just bounces at the top, not enough strength to keep it up , but if i hold it open in the very top position it sometimes does stay up...is this something to do with the springs?
I tried adjusting my springs but i'm afraid to pull it out of position 2 and the spring will collapse and i won't be able to get it back...would make it easier if i remove the lining but i'm having trouble doing that... This is the maximum it will stay up on it's own. View post on imgur.com Also here is a video with the sound when manually moving it back up If i quickly move it up and let go it will wobble back and forth into that same position while making some springy noises from the left side Can anyone help? Thanks much. Last edited by dcastx; 05-20-2016 at 08:05 PM.. |
05-20-2016, 09:33 PM | #2 |
Rep 1,560
It should stay up. The springs do need to be adjusted. Since you just got it, take it back to where you bought it and ask them to make the adjustment.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
05-20-2016, 10:54 PM | #3 |
Rep 741
Drives: 22 M4c vert
You don't need to remove the lining, just pull it down. Also, the springs are trivially easy to adjust. Pull out of the slot, and just pop right back in to the new one (just make sure you do both into the same slot.)
05-21-2016, 01:32 PM | #4 |
Rep 19
just tried it, it now stays up but opening is not very graceful, opens fast and hits the stoppers at the top quite fast...is there some kind of dampener?
This is a minor issue, might consider taking it somewhere to fix later if i can but right now i just wanna drive it |
05-21-2016, 04:02 PM | #5 |
Rep 1,560
I would be a bit careful of having it hit the open stops very hard because of how close to the rear windshield the points at the front corners of the trunk lid come to the glass when the trunk is open all the way.
05-22-2016, 03:06 PM | #6 |
Rep 47
you could also adjust the little bump stop things on the edge of the trunk door... the less they protude the less forcefully the trunk 'pops' up
screw them more in for less pop and screw out making them 'longer' to make the trunk pop more~ if you screw them into too much then the trunk wont self-open when you hit the button on remote |
05-22-2016, 07:44 PM | #7 |
Gettin It Figured Out
1820
Rep 2,669
If you can't get it dialed in...consider purchasing the F82 (M4) springs as the trunk lid is lighter than the 435i trunk lid. Spring weight will be a little more forgiving...
06-11-2016, 07:42 PM | #8 |
Rep 19
I'm going to try take it to a dealer next week, as it seems it's opening dangerously fast. I tried dialing the stoppers in but still opens too fast. (i move the trunk all the way to the bottom without actually closing the trunk and let go of my hand without the popping effect of the stoppers and it still hits the hinges hard) I think it is a problem with the dampening struts but that seems too difficult to fix for me
06-11-2016, 09:31 PM | #9 | |
1820
Rep 2,669
Your bump stops have nothing to do with spring rate (how quickly it opens)...your springs will. Have you tried adjusting your springs to the bottom hole? .
06-11-2016, 09:45 PM | #10 |
Rep 19
that's how it was originally, if i do that though it wont stay open all the way at the top and it just slowly droops down... I also noticed some foam or something inside the springs, wonder if it's something wrong with those
06-13-2016, 05:47 PM | #11 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
Should be a free (warranteed) fix I'd think. With the GC, you can dial in how far you want the liftgate/hatch to open..1/2 way, 3/4, or all the way up.
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
06-06-2018, 03:58 PM | #13 |
Rep 1,637
06-06-2018, 10:19 PM | #14 |
Rep 1,487
Drives: 2108 X3 xDrive30i
Don't second guess it. Let the service center take a look.
06-07-2018, 07:41 PM | #15 |
Rep 14,115
Drives: G82 M4C X-Drive
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
Tags |
435i, trunk |
