05-15-2016, 03:17 PM | #1 |
Rep 8,942
Picked up a pair from Home Depot, $40 each and you can string up to 9 of them together. Just hang from ceiling and plug into garage door opener outlet. I also got the GE wireless outlet switch to plug lights into them mounted switch on wall so you don't need to use the pull chain, that was an additional $20. Anyway I'm posting here because it made waxing the car and doing the interior MUCH easier since the light is so much better. Going to add a couple more. Will put some wire mold on the power cord once I've got the rest installed.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
05-15-2016, 05:01 PM | #3 | |
Rep 8,942
2022 Macan S
05-15-2016, 07:08 PM | #5 |
Rep 1,931
one of the cleanest garages i have ever seen.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
05-15-2016, 08:35 PM | #7 | |
Rep 8,942
2022 Macan S
05-16-2016, 07:52 AM | #8 |
Rep 8,942
Here are the lights I used. I found mounting directly to the ceiling via the keyhole screw option to be VERY difficult. I decided to just shorten the chain to 6 links instead, much easier.
http://www.homedepot.com/p/Commercia...3161/205331022 The switch I used is this one, but anything similar should work. http://www.amazon.com/GE-18313-Outle...ilpage_o01_s01 |
05-24-2016, 11:58 AM | #9 | |
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
Jus the lights and their tombstones?
Did you think about using your old fixture, and just replacing the LED lights, and their tombstone? Thanks for responding. http://www.amazon.com/Hyperikon-equi...hts+for+garage |
05-24-2016, 03:33 PM | #10 | |
Rep 8,942
To answer where I think you are going with your question, I have no idea if what you linked would be better or worse if you have existing fixtures as opposed to getting all new lights. Wasn't an option for me so didn't investigate it at all. |
05-24-2016, 10:34 PM | #11 | ||
Rep 1,753
05-25-2016, 07:42 AM | #12 | |
Rep 3,523
I was assuming that you already had shop lights (florsent type) and were up grading. The link from amozon shows them, but I found Philips LED at Home Depot for $10. http://www.homedepot.com/p/Philips-4...6608/206278132 |
05-25-2016, 11:44 AM | #13 | ||
Rep 1,753
05-25-2016, 12:09 PM | #14 |
Rep 3,523
$10
For $10 bucks a tube you can't go wrong
05-26-2016, 08:40 PM | #15 |
Little Deuce Coupe
391
Rep 635
Drives: SO M2C
Thanks for the tip. I picked up one and really like it. I'll be adding another. I just had a single ceiling socket in the garage.
ex: 2004 Thermonuclear Yellow RX-8|6MT
ex: 2015 Estoril Blue M235i |6MT|slicktop|MP exhaust - PCD 2020 Sunset Orange M2C|6MT|Black 788s |
05-27-2016, 09:56 AM | #16 |
Rep 3,523
05-27-2016, 10:12 AM | #17 |
Rep 1,753
how much brighter were the bulbs? i have 5 dual bulb fixtures. thinking of upgrading two of them.
05-27-2016, 05:21 PM | #18 |
Rep 261
I went the DIY route and bought 12V LED strips off eBay, 5 meter 5050 60W for $10. I ripped some 2x4's into thin strips then stuck the rolls onto the strips. Each 5m roll will make 2x 8ft light strips. Then I bought a 12V 40A power supply for $50 and wired 14 of these light strips evenly through my garage ceiling. I now have 420W of super-bright and even LED lighting for less than $150 (have to buy wires and shit).
05-28-2016, 09:26 AM | #19 | |
Rep 554
I have 15 quantity of 4' T8 fixtures in my garage. I would consider upgrading to LED if the color balance is similar. Going to be pricey, though, even at $10/bulb.
The Stable
2015 BMW M235i | 2014 Porsche Carrera S | 2017 Porsche Macan GTS | 1996 Porsche Carrera 4S |
05-28-2016, 10:20 AM | #20 |
Rep 442
Just put three of the same lights as OP in my garage yesterday. They're much better than the two 60w compact fluorescent bulbs that were in there. Honestly, could probably do with putting in a few more.
05-28-2016, 11:31 AM | #21 |
Rep 3,523
05-28-2016, 11:40 AM | #22 |
Rep 1,753
I saw that. Unfortunately that doesn't mean anything to me. :/ I'm wondering if you noticed much of a difference and is it worth it?
