05-11-2016, 09:58 PM | #1 |
Rep 7
Re-considering the F30
I currently have a E90 330i, and while its a great car, age is starting to catch up, being 11 years old this year. Maintenance issues keep cropping up one after another. And I'm getting a little tired spending all my time fixing it instead of driving it. So that means I am contemplating a F30. Problem is, when I tested a F30 when it was brand new 4 years ago, it didn't really impress me as much as it should. It seem to lack the tactile steering feel that a 3 series should have. It seemed to be rather numb in terms of the road feedback which was disappointing.
Now that was an early model F30, so perhaps BMW has fixed those issues since then. So my question is, for someone coming from a E90, would I be disappointed with a F30? Last edited by Needforhandling123; 05-11-2016 at 10:03 PM.. |
05-11-2016, 10:14 PM | #2 | |
Rep 5,776
That being said I find the F30 to be better in every way. The interior has better space, is more modern and just has a better feel. The tech is superior. It probably depends on what options you get and interior choice as well as to how happy you will be.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
05-11-2016, 10:22 PM | #3 |
Rep 3,406
Congratulations on keeping your E90 so long.
Certainly the F30 has changed since it was first introduced. The question is whether the 2016 version is your cup of tea. Its a bit of a dilemma since the only way to know for sure is to do an extensive test drive in the model you want with the right options and packages. Problem is, these nicely-equipped cars are harder to find at a dealer to test drive. For example, I wanted to test drive DHP but I couldn't find an F30 that had it when I was shopping. I had to drive an F10 with DHP instead just to try out that option. It was not ideal but it gave me enough info to decide to order that option. I am really glad I did. Given your experience with the E90, I'd test drive cars with DHP or other suspension upgrades. They drive quite differently than the loaner F30s so options and packages do matter. I came from a 5 series to the F30 so I can't give you first hand long term experience. Compared to the E90's I've driven, a properly equipped F30 is a really nice improvement in most ways. The major downside is the lack of heft of the steering. It is absolutely less hefty, even when you put it in sport mode. If that is a showstopper, the F30 is going to disappoint. Personally I think its just fine and I love the F30. Others can't get used to the lack of heft and change in handling feel. You will get both reactions from those that respond to your post. Go test drive the sh*t out of one that is properly equipped and let us know what you think. Good luck! |
05-11-2016, 10:42 PM | #4 | |
Rep 1,476
Drives: 2022 G01 X3 M40i (Black/Black)
But, the short story is - in my opinion - that while the F30 is a great car, it's not a great driver's car. It's not just the steering, it's the whole chassis setup...competent, but not particularly rewarding. If sportiness, chassis/handling are the most valued aspects of your E90, prepare to be disappointed.
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust 2006 E90 330i (Silver) 6MT, Sport |
05-11-2016, 11:11 PM | #5 |
Rep 7
Hmmm..perhaps I should get a 2 series coupe instead of a F30 sedan? Haven't tested the 2 series coupe, but the reviews say it does retain the handling prowess of what the 3 series should have. Trouble is, with family, a four door sedan will be a lot more useable. But the C class, A4 doesn't really seem better than the F30 in the driving pleasure department. I wonder about the Jagaur XE. I've always been a closet Jaguar fan. But their reliability issues always kept me away. But now under Tata, they have turned over a new leaf, or so I'm told. How does a F30 compare to the Jaguar XE?
05-11-2016, 11:27 PM | #8 | |
Rep 1,476
05-11-2016, 11:27 PM | #9 | |
Rep 1,180
Yes, the initial versions of the F30 were in dynamic terms not as much fun to drive as the best E46 or E90 models. However, I was pleasantly surprised at the numerous dynamic upgrades that BMW has given to the MY2016 F3X chassis - front and rear suspension, steering and brakes have all been improved. To the OP, be aware that there is also a measurable difference in ride quality between a standard Sport suspension and the optional Adaptive suspension for MY2016. With optional 19" summer performance tires, the latter has a more compliant ride in 'comfort' than the non-variable Sport suspension has with its 18" tires. Of course, the advantage with Adaptive suspension is that you can 'have your cake and eat it too' by switching the setting from Comfort to either Sport or Sport+. For comparison purposes with 2016 F3X, I would suggest that the OP also consider test driving a 2016 Mercedes C300/C450. While many people would consider the C Class to have a much richer interior than the F3X, it does not measure up for dynamic handling, nor is it as much fun to drive. The Alabama built 2015/2016 C Class has also been fraught with quality control issues - just take a look at either Consumer Reports or Truedelta.com for its reliability stats.
on order: 2024 i4 eDrive40 M Sport, Tanzanite metallic with all options
05-12-2016, 12:07 AM | #10 | |
Rep 7
05-12-2016, 12:21 AM | #11 |
Rep 1,201
If you want a similar raw feeling of the 330i, I think you should be considering a F80. F30, while nice, has been designed to attract the general public, so the car became more civilized and upscale. It's a really nice car both inside out, but every part of the car is more muted and in a way, disconnected from the outside. Even the sport suspension won't give you the raw feeling that you are used to in your E90.
I've owned three F30 (two 328 and one 435), and currently drive a F80. There's no comparison between the two in terms of the raw feeling.
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD) |
05-12-2016, 12:27 AM | #12 | |
Rep 7
05-12-2016, 12:42 AM | #13 | ||
Rep 1,201
05-12-2016, 02:00 AM | #14 |
2JZ-GTE
3042
Rep 3,992
No the steering has not changed even with the LCI. No neutral feeling. Its still very broken and nobody should ever buy this car because of it. Read the car and driver. Read the road and track. Read the motor trend. Don't listen to people that own the car since all they will say is its the most awesome thing in the world. If you ask me, i think the VSS is awesome and love the steering feel, but what do I know?
05-12-2016, 02:56 AM | #15 | |
Rep 3,406
You've been given some good advice and your response is you are aware and still struggling? Have you actually gone and test driven a properly equipped F30 lately? If so, what did you think? If not, please go do it and then tell us you are still struggling or that you like it and plan to buy one. At least you will have done your homework. |
05-12-2016, 03:44 AM | #16 | |
Rep 7
05-12-2016, 03:47 AM | #17 |
Rep 7
05-12-2016, 04:33 AM | #18 |
Rep 3,291
You may well be able to swing a M235i and come in under 50k if you skip the tech package or something. Both the 328 and the 228 properly optioned might not be a bad car to test, too. I haven't driven one, but a RWD 228 does seem like it might be the sweet spot with the N26 engine.
05-12-2016, 06:10 AM | #19 | ||
Rep 1,472
Very true, I had one as a loaner for 4 days and agree with this, however, you mentioned that you have a family, so I cannot see how this can work for you. |
05-12-2016, 08:39 AM | #20 | |
Rep 3,406
05-12-2016, 09:20 AM | #21 |
Rep 710
I loved my E90's but am not disappointed with the F30. I'm on my second F30 and looking forward to a third.
2018 Mustang GT | Royal Crimson | Black Leather | 6-speed | Cold Weather | Premium Pkg | 20" Alloy Wheels | Tuned to 510HP | Less than $45K
Previous loves: 2015 F30 335i / 2013 F30 335i / 2009 E90 335i / 2007 E90 328xi |
05-12-2016, 09:30 AM | #22 |
Rep 3,161
Like others have mentioned, the F3x will not drive like the E9x. I had a E92 335i before my 435i and you'll eventually get "used to" the steering within a few weeks, just flip the switch to sport mode in the F3x.
2018 F80 M3 6MT ZCP
