05-11-2016, 02:54 PM | #1 |
Rep 943
Drives: 2012 328i Modern Line
Rear door panel removal?
I've searched but could not find any DIY for removing rear door panels in an F30. Does anyone know of one and can point me in the right direction?
:wave:
05-11-2016, 04:09 PM | #2 |
Rep 1,329
The inside door trim panel? If so, check bavsound.com they have a long detailed video to show how to replace the speakers which includes the door card removal.
2002 325i sport - sold 2009 135i M sport - sold
2009 550i M sport - sold 2005 M3 6MT Jet Black w/Cinnamon 2016 F30 320i ZSP 2003 E46 325it ZSP 5MT |
05-11-2016, 04:13 PM | #3 | |
Rep 943
:wave:
05-11-2016, 04:24 PM | #4 |
Rep 1,329
Did you watch the removal of the front?
Are you missing a screw or something?
05-11-2016, 04:27 PM | #5 |
Rep 1,739
Bavsound video is helpful, but they kind of gloss over certain things.
First you want to remove the trim cover on the door pull. You absolutely need plastic trim tools to do panel work. On the lower edge of the handle, there is a small gap. This is where you need to pry it off carefully. Use a tool to get it started and carefully pull the trim off. Use your fingers once you get started since they won't mar the surface. Once the cover is off, use your torx driver to remove the screws. Once that's done you pry the panel off. Start at the very bottom and get it started with a trim tool. Make a gap big enough to squeeze your fingers into than use your hands to yank out the lower plastic fasteners. Pull straight back away from the door. Once you get started, work your way around the panel. They literally pop out. Do the top last as it doesn't require much force and the connectors are different. Be careful not to lose the little rubber gaskets that are on the plastic fasteners. Sometimes they remain stuck to the metal surface of the door. Depending on what you're trying to do, you may not have to disconnect any of the wires between the panel and the door. If you do, the rear doors are the easiest to get off. The wiring harness to the front door window controls is a pain to disconnect and I would suggest working around it and leaving it connected. Ask any questions here...I've had mine off a couple times. It's not hard once you've done it. Worst step? Putting the handle covers back on. |
05-11-2016, 04:33 PM | #6 | |
Rep 943
:wave:
05-11-2016, 04:47 PM | #7 |
Rep 1,739
Haha...I'm doing the same thing once I get some time. I have the newer/brighter LED modules for the fronts. I'm going to experiment with the ones I remove...try different/brighter LEDs etc.
How does the shade attach? I've never seen them before? I would still say start popping off on the bottom. |
05-11-2016, 04:49 PM | #8 | |
Rep 943
:wave:
05-11-2016, 05:18 PM | #9 |
Rep 1,029
Drives: 2019 440xi Gran Coupe
For me the hardest part was to remove the door handle trim. Broken tabs on both trims and had to crazy glue some tabs when reinstalling. Bavsound video looks way too easy. Once the trim is removed, then the rest is as like the Bavsound video.
05-11-2016, 05:23 PM | #10 | |
Rep 943
:wave:
