05-03-2016, 08:01 PM | #1 |
Rep 1,476
Drives: 2022 G01 X3 M40i (Black/Black)
When I'm in Sport mode, is the drone sound my MPE or the Active Sound?
...my car has had MPE since day one of ownership, so I'm unsure if the "drone" sound under slight throttle/load is the MPE or Active Sound. In other words, does "Sport" mode modify my MPE in any way? I suspect what I'm hearing is the Active Sound changing output. Does anyone know?
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust 2006 E90 330i (Silver) 6MT, Sport |
05-03-2016, 09:07 PM | #2 | |
Rep 271
05-03-2016, 09:14 PM | #3 | |
Rep 1,476
05-03-2016, 09:48 PM | #4 | ||
Rep 4,724
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
05-03-2016, 09:53 PM | #5 | |
Rep 410
Drives: One car with good steering ;)
On another note, I have noticed that the drone does come from, at least in my experience, a mixture of the left exhaust valve opening in the MPE and the active sound amping up at the same time under increased partial throttle. |
05-03-2016, 10:19 PM | #6 |
2JZ-GTE
3042
Rep 3,996
My car had a drone and when I disabled active sound… It when away
05-04-2016, 06:14 AM | #7 |
Rep 4,983
I have a bit of a drone but only in Sport+. We've been over this a million times, and I know they should be the same sound, but they're definitely different from inside the cabin and out on my car. Became even more pronounced after slapping on the AA piggyback tune, so I'm assuming it's all from the exhaust itself, and not ASD. Unless ASD is robust enough to detect the boost difference and thereby alter the sound, but I doubt it.
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
05-04-2016, 06:36 AM | #8 |
Rep 191
Drives: '17 340i X-Drive M Sport EBII
I have a 435i and when coding it, I never saw the ASD which means I don't have it. Although it's a trend we noticed and can't really confirm officially, it appears that for, at least, the 2014 models N55 doesn't have ASD but N20 does.
05-04-2016, 12:04 PM | #9 |
Rep 682
Probably to compensate for the loss of two pots.
2017 440i Gran Coupe xDrive MPPSK M-Sport Estoril Blue II w/ Individual Golden Brown Full Merino & Fineline Anthracite Wood
Track Handling + Premium + Cold Weather + Technology + Driver Assistance Packages |
05-04-2016, 04:03 PM | #10 |
Rep 208
i thought our cars didnt have ASD?
but anyways i second that the drone is caused by the flap. If you put the engine under some load in a higher gear at a lower RPM and accelerate up the rev range, you'll hear the exhaust suddenly wake up around 2k rpm (when the flap opens), but below it, the drone disappears |
05-04-2016, 05:00 PM | #11 | |
Rep 1,476
05-04-2016, 06:42 PM | #12 | ||
Rep 376
Also, I used to notice droning if I was cruising at around 80, especially obvious when my revs were around 3k on the highway (6 speed manual, so revs in top gear on the highway are higher than an 8AT). After coding the active sound off, the drone is pretty much gone.
2014 BMW 328i, 6-speed Prem / Nav / Drivers Assist / Heated Seats / Lighting Last edited by chuckles01; 05-04-2016 at 11:40 PM.. |
