04-25-2016, 08:16 PM | #1 |
Rep 315
Drives: 2013 335i M Sport
Jumper Cables
I am outfitting a small took kit to keep in my car and was looking for some booster cables. I found these supposed genuine BMW ones, anyone used them? Are they good quality?
https://www.ecstuning.com/ES200240/ They just look thin ha... Thank you
2013 335i l Estoril Blue | M Sport l MPPK | M Perf Exhaust | M Perf Brakes l Adaptive M Suspension l DAP | DHP | Premium | Tech
My Build -> Mod Journal |
04-25-2016, 08:31 PM | #2 |
Rep 6,241
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
I'd probably just get a set at Wally World.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
04-25-2016, 09:04 PM | #4 | |
Rep 16,082
Decent 4 gauge cables aren't expensive. For instance: http://www.amazon.com/Cartman-Booste...=Jumper+cables |
04-25-2016, 09:34 PM | #5 |
Rep 180
Battery powered booster pack jump starters mean you don't have to rely on another car for a jump start. They're also safer for your electrical system, they've just about the same price or a couple dollars more than cables, and they've come a long way in the past few years.
http://www.amazon.com/Best-Sellers-A...tive/318336011 Don't know who this guy is, but his video has a bunch of positive reviews: Part 2 where he starts a car with it:
Former BMWs: F80 M3, E46 330i, E34 525i
04-26-2016, 12:01 AM | #6 |
Rep 315
Cool thanks peeps
Anyone put a small toolkit together to carry? Or some stuff like that, or just rely on that SoS button? Does that expire btw? Lol
04-26-2016, 12:37 AM | #7 |
Rep 267
Not sure if I trust the output of those battery powered booster packs with the sensitive electronics in a bmw.
But having jumper cables in the trunk of your bmw does present an interesting dilemma....how do you open your electronically controlled trunk when the car's batteries are depleted and those jumper cables that you really need to boost the car are inside the trunk that you can't open?
2017 430ix Gran Coupe
04-26-2016, 02:12 AM | #8 |
Rep 1,502
So long as you use the posts in the engine bay and don't connect directly to the battery in the trunk it should be fine. I believe the posts are isolated from the rest of the electronics.
04-26-2016, 06:23 AM | #9 | |
Rep 267
From what I understand, these portable battery packs do not fare well stored in a car with the usual summer heat you would typically find them in, and likewise in the winter they are pretty much useless starting up a dead battery in the cold. But still, how do you get into a locked trunk without power so you can get at whatever devices/tools you need to jump start your car?
04-26-2016, 06:35 AM | #10 | |
Rep 230
That being said, I attempted to jump start a landrover and failed miserably. |
04-26-2016, 07:15 AM | #11 |
Rep 18
Isn't there a button in the driver's side footwell? My F32 has one. I will have to check to see if it is electronic or manual release.
04-26-2016, 07:20 AM | #12 | |
Rep 267
However if all your tools/jumper cables are in the trunk, and you have no power, you are unable to easily gain access to them to fix the problem!! Maybe crawl through the back seat and use the emergency release within the trunk?
04-26-2016, 07:36 AM | #13 | ||
Rep 16,082
04-26-2016, 08:03 AM | #14 | |
Rep 180
I apologize in advance for posting a Motorweek clip, and I"m far from the biggest Pat Goss fan (usually because the stuff he tells you is common sense) but these battery jump starters seem to be falling into the common sense category more and more.
04-26-2016, 08:42 AM | #15 | |
Rep 18
04-26-2016, 08:55 AM | #16 |
Rep 1,329
I too have heard good things about those battery things, but I guess I just expect to almost never need it, so in 10 years when something might come up, is it still any good. I'm sure I won't remember to charge or replace it.
I keep a thick and fairly long set of jumper cables. If your on the side of the road, you can't always safely get another car close enough for the shorter cables to reach. Cheaper ones are thin and short. With a good quality set you're covered. There is always another car around if/when you need it. Mine are 4 gauge 20 feet and they always work.
2002 325i sport - sold 2009 135i M sport - sold
2009 550i M sport - sold 2005 M3 6MT Jet Black w/Cinnamon 2016 F30 320i ZSP 2003 E46 325it ZSP 5MT |
04-26-2016, 09:30 AM | #17 |
Rep 16,082
Batteries have come a long way, but you still can't replicate your car battery with something that fits in your hand. These tend to run with about 10,000 mAh capacity, which seems impressive. But 10,000 mAh translates to 10Ah. A standard duty car battery capacity averages 50Ah. Mini-boosters may give you enough extra juice to get the car going if the battery is just low enough that it won't start the car, but if the battery is below 25% charge they probably won't cut it.
04-26-2016, 09:58 AM | #18 |
Rep 180
Personally, I just replace the batteries in my cars every 5 years as a precaution. We're on the third battery in my wife's 2004 X3. Keeping a battery pack sufficiently charged for when you need them does seem like a downside.
04-26-2016, 10:17 AM | #19 | |
Rep 6,241
04-26-2016, 10:50 AM | #20 |
Rep 1,342
The portable batteries work surprisingly well. Haven't used the one I have on my 3 yet, but it's started our completely dead Honda and a couple neighbors SUVs just fine.
Here's the one I have: http://www.amazon.com/dp/B00D42AFS8 |
04-26-2016, 12:29 PM | #21 |
Rep 18
04-26-2016, 04:30 PM | #22 | |
Rep 1,739
