M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Anyone fitted a Dashcam yet?
      04-20-2016, 12:25 AM   #1
Prodigy.
Prodigy.'s Avatar
Australia
698
Drives: ///M2
It may be a bit soon but has anyone fitted or have plans on fitting a dascam anytime soon?
Am planning on installing a Blackvue DR650GW -2ch when my car arrives. I believe the fuse box on the 2 series is in the boot so was wondering what peoples recommendations are for running the wires from the front to back?
Had a quick look on the 2 series forum and running them along the top of the window trim appears popular but i'm weary of the airbags, i'm a bit concerned about just tucking the wire behind the top of the A-pillar trim as they may foul the airbags if deployed so does anyone know how to remove the trim safely, i'm a bit concerned with the Airbag being behind there..
      04-20-2016, 02:03 AM   #2
MR.
MR.'s Avatar
Drives: BMW M2 CSL Turbomeister
I will be doing this upgrade and installation in a couple of weeks from now. I will keep you all updated on how it was installed.
MR
      04-20-2016, 02:11 AM   #3
Prodigy.
Prodigy.'s Avatar
Australia
698
Drives: ///M2
MR
Thanks MR.
      04-20-2016, 03:11 PM   #4
supersam
Da Baus
supersam's Avatar
Drives: F87 6MT, RA, E46
I got the same blackvue unit, will do the install after I get the car back from xpel/tints. I also got the MotoPark multi-safer so it keeps running for a couple hours after the car is turned off. Check out this DIY for the f30, our install should be near identical
http://f30.bimmerpost.com/forums/sho....php?t=1183385
also, there is no harm in tucking the wires just past visibility. you don't even need to take the a or c pillars off to do the install. If you did, i'd at least unplug the battery.
M2 LBB/6MT/VFstg2/V1 stealth/JRC valve delete/Dinan/
Fabspeed/Wagner/ER/Eibach/UCP/RTD
RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID
E46 330ci --> S54 M3 xplant vzv 3bananas (retired)
      05-15-2016, 09:41 PM   #5
Prodigy.
Prodigy.'s Avatar
Australia
698
Drives: ///M2
Have you had chance to install the Blackvue, if so how did you go?
      05-16-2016, 12:46 PM   #6
supersam
Da Baus
supersam's Avatar
Ahh in the middle of vacation plus moving, still haven't gotten to it
m2
