04-17-2016, 11:29 PM | #1 |
Rep 251
What a day
So i was on the 73 (Newport, CA freeway) and the iDrive notified me of severe loss in tire pressure. I am running Pirelli PZN non-RFTs. So i exited the freeway and stopped at a gas station and the tire started to lose all the air till it became flat. There was a hole in the tire, i called Triple A. They Roadside assistant guy came and helped me batch the hole which was in a perfect place that make fixable. I re-calibrate it the TPMS and it help the pressure well for two day.
Tried to go to a pep boys and other tire shops wanted them to take the tire off and reseal it from inside and make sure its okay, they all tried to not do it saying that the can't roll the tire with the rim because my rim is too large (20") and it seems expensive and they don't want to risk it as long as the tire is "fine" What really pissing my off that this night i scratched my front lip when i was trying to left my car on the towing truck (H&R Sport springs & M Performance OEM CF Splitter) and it is ruined. Here is a picture of the batch the roadside assistance guy did. |
04-17-2016, 11:53 PM | #2 |
Rep 416
I've plugged many, many of my "M" cars' tires with no problem. Your AAA guy used a plug. If you're not losing pressure, there really shouldn't be any more problems.
But, it sounds like you want more piece of mind by taking the tire off the rim. It can't hurt, and if you feel better with a patch, find a tire shop that's willing to "risk" taking off a larger diameter tire. Your hole's location looks like the perfect place for a plug, though. |
04-17-2016, 11:53 PM | #3 |
Rep 210
Agreed. Run flats are the way to go.
2012 328i Sport Line - JB on Coral Red 2016 X5 35d M Sport Line - CBM on Ivory White and Black Dakota |
04-18-2016, 10:27 AM | #5 | |
Rep 210
The two or three times I've had a screw or nail in my tire and limped around for a couple days on run flats made me appreciate them... Especially when you read posts like this where there's the inconvenience of waiting for help and then dealing with the follow on issues of his car being damaged by the truck. That's all.
04-18-2016, 11:08 AM | #6 | ||
Rep 251
04-18-2016, 02:29 PM | #7 | |
BimmerPost Supporting Vendor
24198
Rep 190,805
04-18-2016, 03:22 PM | #8 | |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
Hope you get your tire issue squared away.
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
04-18-2016, 04:59 PM | #9 | ||
Rep 251
04-18-2016, 04:59 PM | #10 |
Rep 251
Here is a picture of the car after the "scratch" can you guys see it? Is there some kind of a "Carbon fiber repair kit" or do i have to change the whole thing?
04-18-2016, 05:12 PM | #11 |
Rep 3,622
RFTs weigh a ton. By switching to continentals ExtremeContact DW summer tires I will shed 6 lbs unsprung weight on the front and 8lbs from the rear axle. (Source: tirerack.com)
The rear stock Bridgestone S001s weigh as much as the wheel they are on!
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
04-18-2016, 06:15 PM | #12 | |
Rep 3,258
I can't see where the damage is....but you know where to look ....
25% 3M Tint| |
04-18-2016, 06:16 PM | #13 |
Rep 3,258
3lbs per tire? (I run square..so it'd be all the same). . 12lbs is 12 lbs!
25% 3M Tint| |
04-18-2016, 07:11 PM | #14 | |
Rep 3,622
04-18-2016, 07:13 PM | #15 | |
Rep 251
04-18-2016, 07:30 PM | #16 | |
Rep 1,472
Sure it's a bit scratched and you feel bad about it now, but soon enough, there'll be another one from stone chip or what not. Really not a huge deal in my opinion. Of course if there's a way to simply get rid of it, I'd do it, but it's far from "ruined". |
