03-28-2016, 09:58 AM | #1 |
Rep 73
Coding out the double pull on the door handle
Hey everyone,
I know the double pull on the door handle is a child safety feature, but it drives me and passengers crazy. I asked the dealer to code it out and he said no (because of safety). Is this something I can do (DIY)? Thanks |
03-28-2016, 10:22 AM | #4 |
Lurker from behind
9
Rep 42
You can also press unlock button found just below hazards
"Understeer is when you see the tree you are hitting, if you only hear the tree then it was oversteer"
Walter Röhrl |
03-28-2016, 10:25 AM | #5 | |
Rep 5,262
Double pull is first to unlock and push the lock pin up, then to open the door |
MichalM240i145.00 |
03-28-2016, 11:06 AM | #7 | |
Rep 5,262
makes no sense as a safety feature either... you would think a kid would be smart enough to pull the handle twice anyway |
03-28-2016, 12:32 PM | #8 |
Rep 73
BMW genius not much help.
"I hope you have been enjoying your Ultimate Driving Machine. The vehicle seems to be functioning as designed. As far as I know, BMW centers do not have the ability to code the vehicle to perform otherwise." |
03-28-2016, 03:50 PM | #9 | |
Rep 314
I'm sorry if I sound pretentious or anything but make sure the lock pin is UP meaning it is unlocked before you try next time. |
03-28-2016, 08:55 PM | #10 | |
Rep 1,753
03-29-2016, 11:47 PM | #11 |
Rep 80
Ditto BentZeros experience - I coded unlock with engine off. When I hit the stop button, it only takes one pull to open the door. If the passenger tries to get out while engine is still running, it takes a double pull.
@Gabrola, very little in a modern BMW is a "purely mechanical mechanism", even things like this that you would absolutely think would be purely mechanical. |
03-30-2016, 02:40 AM | #12 | |
Rep 103
03-30-2016, 03:38 AM | #13 | |
Rep 314
However, the door handle (the opening mechanism not the locking mechanism) is purely mechanical. The door handle is simply a manual pulling mechanism on a Bowden cable, there is nothing electronic about it, not even a sensor. |
03-30-2016, 07:11 AM | #14 | ||
Rep 1,753
04-07-2016, 03:49 PM | #16 | |
Rep 52
Then the first pull of the door handle releases the latch because it's already unlocked. If the car is still running and you want to exit it's still a double pull.
'16 M4 Vert - San Marino Blue/Sahkir 6MT
04-07-2016, 04:03 PM | #17 | |
Rep 386
04-07-2016, 05:03 PM | #18 |
Rep 1,753
This and the speed in BC are my two favorite coding changes. Oh, and turn off radio when opening the door. Now i only press the stop button once.
04-13-2016, 03:02 PM | #20 |
Rep 1,753
And ride around with unlocked doors? :/ I believe someone has brought this up before. Idk. I've coded it and thus I'm a super happy boy.
04-13-2016, 05:58 PM | #22 | |
Rep 122
